Question about Philips Magnavox 50ML8105D 50" HDTV DLP TV
Switching from cable to antenna
I have a Magnavox MWD 2206 Combo I can not figure out how to switch it from cable to antenna. Any suggestions?
    Sergeant:
  • 227 Answers
Should be done with your remote. Go to menu and then setup. It should have a selection for cable or antenna.
Posted on Jan 14, 2009
I have a Magnavox dvd player/ vhs MWD 2206. It does not switch between dvd and vhs play modes. It stays on the dvd screen no matter what I do. The light goes on to indicate which is supposed to be in use...
Software issue since unit is not recognizing the tape. Try a hard reset and see if that clears up the cobwebs. U might also check to see if there is something in the vhs tape path that sends a signal to the main board for switchover.
Aug 25, 2017 | Televison & Video
How to hook up a vcr/dvd player to a cable box
Cable box RF output to Combo antenna input. Then use menu in combo to search for cable stations.
Jan 26, 2012 | Magnavox ZV427MG9 DVD Recorder VCR
Magnavox vcr/dvr. insert vc tape, machine loads and plays tape for about three seconds then stops and ejects tape. tape will not stay playing. thanks, larry
Mine does the same.It's basically junk.A new VCR/DVD player goes for around $80.If you were to call to ask about getting your VCR repaired,they would tell you that it is FAR cheaper to simply purchase a new one.Same Magnavox I bet almost too.model # for mine is MWD 2206.Labor alone is easily at least $60/hour and it would take that just to disassemble and reassemble the VCR section just to get at the problem.Greg
Feb 10, 2011 | Televison & Video
Would like to record from my tv to my magnavox dvd/vcr combo box
If I understand your request right, You do not have cable or satellite box.
You can not record from your TV. You use the TV as a monitor from the dvd/vcr combo box. What the box receives is what shows on the TV. So you will have to have a digital convertor hooked to the (antenna in) dvd/vcr combo box, (antenna out to the tv antenna in) Depending on the antenna you are using that is on the other end of your cable-in coax connection this will hook to your antenna in on the digital convertor box. If your cable is hooked up and operating correctly and directly to the tv that is digital ready you probabbly have a good picture. When the vhf/uhf signal was transmitted you could go from the dvd/vcr to the tv with no problem. But now that the signal is digital and the tv is set for digital the dvd/vcr will not pass a digital signal to the tv. Best suggestion, you have to get a digital dvd/vcr receiver. If you have more question please contact me.
Mike
Jul 25, 2009 | Philips Magnavox DVD/VCR Dual Player
DVD/VCR Combo
your model is "tuner free" that means it does not have the RF screw in connector. Buy one that has a tuner, preferably both ATSC(USA digital) and NTSC(USA analog)
Jul 17, 2008 | Philips Magnavox DVD/VCR Dual Player
My vcr won't play back
I have a Magnavox zv457mg9 DVD&VCR combo ,and the vcr records for a short period(10minutes) and then cuts off. This happens each time I try to record on the VCR. Any suggestions??
Feb 26, 2008 | Philips Magnavox MWR20V6 DVD Recorder/VCR
Magnavox mwd 2206 dvd vcr player....shuts off with eject word across screen.
On a unit I checked with this same symptom, removing the top cover allows the unit to stay on and operate normally. There is some sort of sensor at the left middle of the chassis, which, when unblocked by any opaque object, allows the unit to remain on. A temporary fix (not advisable) would be to replace the top cover with a piece of clear plastic or taut saran wrap (no vent holes needed). It's unclear exactly where/what that sensor is from a cursory test. This is a work in progress on someone else's machine that I lack full access to.
Oct 27, 2007 | Audiovox VE1020 10.2 in. TV/DVD Combo
DVD VHS recorder
It sounds like your cables are connceted ok, but what you neede to do is to be able the switch from one video mode to the other so lets go through the cable and vrc conncetions again just to make sure. From your cable set top box connect your component video (RGB) video out to your TV (RGB) video in via the (RGB)cables. From your VCR connect your composite video (yellow) out to your TV composite video in withe the composite video (yellow) cable. From your VCR (Left & Right audio out)connect your left and right audio connections (White and Red) to the Audio in of the TV (Left and Right). Whith this setup you should be able to use the TV to switch between the two A/V inputs using the remote control.
Sep 03, 2007 | Philips Magnavox 27MS343S 27" TV
Philips Magnavox 50ML8105D 50" HDTV DLP TV Logo
121 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
