Question about Kenmore 659 Electric Dryer
I have a roper dryer and need to replace the thermal fuse, where is it located?
    Scholar:
  • 58 Answers
Remove the rear panel the thermal fuse is mounted the the exhaust duct left of the vent hole held in be one 1/4 nut
Posted on Jan 14, 2009
Where is roper thermal fuse, its an older dryer
On older Whirlpool brand dryers(roper is made by Whirlpool) the thermal fuse is usually always in the blower housing..to get to it ya would need to remove the back panel.
This video shows who to replace the thermal fuse http://www.youtube.com/watch?v=aUQQJAxkZ0g
GENE
Sep 16, 2011 | Roper RES7646KQ Electric Dryer
Dryer won't start
This usually caused by a blown thermal fuse on the blower housing located behind the rear access panel. This thermal fuse is wired in series with the motor and if it blows, power to the motor is terminated and the motor cannot run. No dryer function works when the motor cannot run.
Unplug the dryer or disconnect power then remove the rear access panel. Locate the thermal fuse then bypass it for troubleshooting purposes.
Bypass the thermal fuse by disconnecting the wires and joining it together. Insulate properly and plug the dryer back in. The thermal fuse is indeed blown and needs to be replaced if the dryer starts. Do not use the dryer with the thermal fuse bypassed due to fire hazards.
Clean the lint filter and make sure the vent system is not restricted then replace the thermal fuse including the cycling thermostat (thermistor for other models) as a standard operating procedure and preventive measure. The thermal fuse usually cuts out due to a failed cycling thermostat(thermistor for other models).
Jul 19, 2011 | Roper REX3614KW Electric Dryer
Amana dryer model YNED7200TW will not start. there is power, but start button does nothing. Resetting breaker did not work. Any ideas?
Thermal Fuse
Item #2986 (OEM Part)
$10.70
Thermal fuse. If the dryer overheats, this device stops the flow of electricity to the heat source and/or the entire dryer. It is located on the blower housing and cannot be reset. The most common cause for overheating is a vent tube clogged with lint, a birds nest or other debris.
Manufacturer Number 3392519
More
  • Admiral Dryer Thermal Fuse
  • Amana Dryer Thermal Fuse
  • Crosley Dryer Thermal Fuse
  • Estate Dryer Thermal Fuse
  • Kenmore Dryer Thermal Fuse
  • Kenmore Refrigerator Thermal Fuse
  • Kenmore Washer/Dryer Combo Thermal Fuse
  • KitchenAid Dryer Thermal Fuse
  • KitchenAid Washer/Dryer Combo Thermal Fuse
  • Magic Chef Dryer Thermal Fuse
  • Maytag Dryer Thermal Fuse
  • Roper Dryer Thermal Fuse
  • Roper Washer/Dryer Combo Thermal Fuse
  • Whirlpool Dryer Thermal Fuse
  • Whirlpool Washer/Dryer Combo Thermal Fuse
In Stock
Quantity: http://www.repairclinic.com/PartDetail/Thermal-Fuse/3392519/2986#repairHelpVideoTabs
Jun 08, 2011 | Amana Dryers
Roper Dryer # RED 4440, will not heat. Where are the fuses? What are other possible solutions.
The dryer will not heat then it is the thermal fuse that is bad, you can test it with a voltmeter before replacing. This fuse is located inside the rear panel and it cannot be reset.
Hope this will help....
Dec 31, 2010 | Roper Dryers
MY ROPER DRYER QUIT HEATING STILLS WORKS NO HEAT
The thermal cut-off , which is the small t-stat looking piece located at the top of the element housing ( on vertical mount elements ) or the far front of the element housing ( on horizontal mount elements ) , is usually the cause for no heat .
Aug 02, 2010 | Roper REX4634KQ Electric Dryer
Need to replace the heating element. Where is it located
It is on behind the back cover on the bottom right. Make sure to check the thermostat and thermal fuse which are common to fail on these dryers. If the thermal fuse is bad be sure to check the dryers vent system for any obstructions. The thermostat and limit are mounted to the tube the element is in and the fuse is made of white plastic usually located to the left. check these for continuity including the element. If any are open replace them.
Jun 23, 2010 | Roper RES7646KQ Electric Dryer
Dryer tumbles, no heat
its a gas dryer it doesnt have ,,heating element...replace thermal fuse
Dec 28, 2008 | Roper RGX4634KQ Gas Dryer
Dryer does not start but timer works, although it tics in the OFF position
Hi thanks for the question. On that dryer In the back you will find a thermal fuse located on the air duct. A small plastic piece with 2 blue wires to It . Replace the thermal fuse
Dec 16, 2008 | Roper REX3614KW Electric Dryer
Roper dryer again
Hi here Is the thermal fuse located In the back Of the dryer On the air duct 00208689.jpg
Feb 24, 2008 | Roper REX3614KW Electric Dryer
Roper dryer again
if its a thermal fuse located on rear bulkhead of dryer, youll find it by removing back cover of dryer, little white thermo,if bad there will be no continuity through it
Feb 24, 2008 | Roper REX4634KQ Electric Dryer
Kenmore 659 Electric Dryer Logo
222 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal De
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
