Question about Dell Dimension 8200 PC Desktop
Wireless communication to printer from pc is lost
I reconnected the usb from pc to printer said found eachother and it worked for about 24 hours then lost it again ?????
  • 80 Answers
You may be having an issue with an usb hub try connecting it to another usb port. If this is a notebook and you are connecting it through a port replicator disconnecting the notebook from the replicator can cause you to loose connection to the printers.
Posted on Jan 14, 2009
Communication error
2 possible probs on this depends on if you are using Wireless or cable If wireless it basically means that your laptop or desktop computer is not receiving instructions from printer and thats why there is a communication error coming up, try just testing wireless port on another laptop to see if its a fault with the one you have,
If its a Usb cable issue try reconnecting in another Usb port sometimes some ports are usb 2.0 or 3.0 and will not be powerful enough for your printer, In addition try using another cable it could be faulty also printer cables are sometimes similar to scanner cables swap them round this depends on the male fitting though if they are the same,
another method is disconnect printer from computer and run a self diagnostic on its own to see if its working alright if ok reconnect but before you do make sure your computer is up and running first with Usb it cable plug and play which means your computer should recognise it and install software required if a disk is required make sure thats ready
Or could be something real simple like your usb or connector is not connected correctly take them out clean and put back in reboot and retry
hope this helps
Aug 12, 2014 | Epson Office Equipment & Supplies
I cant get my 4650 to scan it keeps saying downloading application list but it never does anything
If you are scanning documents to edit or save as PDF file, you will need to install the OCR scan software on your computer. The Lexmark OCR scan software is available only on the installation disc that came with your printer. If you lost the disc, please contact Lexmark Technical Support Center to request for one.
If scanning from your printer to your computer was working previously, then it could be just a slight communication problem. A quick fix for most communication errors can be achieved by resetting the printer and/or rebooting the PC. Simply disconnect the printer from your computer (if USB connected) > reboot your pc > unplug and re-plug the printer into the power source to reset it. When the printer turns on, reconnect it to your computer. Then try to scan again once the computer fully recognizes the USB connection (if USB connected). If printer is connected wireless, wait until the WiFi light on the printer turns on solid green before trying to scan a document.
Dec 28, 2011 | Lexmark X4650 InkJet Printer
Lexmark pro705 lost ms word scan application on new pc with windows 7
A quick fix for most communication errors can be achieved by resetting the printer and/or rebooting the PC. Simply disconnect the printer from your computer (if connected via the USB). If printer is wireless, simply power cycle the printer. Reboot your pc. Unplug and re-plug the printer into the power source to reset it. When the printer turns on, reconnect it to your computer. Then try to print again once the computer fully recognizes the USB connection.
Let me know if this helps.
Nov 26, 2011 | Lexmark Office Equipment & Supplies
Do i need software like ocr so that the lexmark x6650 scanner can work
If you are scanning documents for editing or saving them as PDF, you will need to install the OCR scan software. The Lexmark OCR scan software is available only on the installation disc that came with your printer. If you lost the disc, please contact Lexmark Technical Support Center to request for one.
If your scanner was working before, it could be just a slight communication problem. A quick fix for most communication errors can be achieved by resetting the printer and/or rebooting the PC. Simply disconnect the printer from your computer (if USB connected)> reboot your pc > unplug and re-plug the printer into the power source to reset it. When the printer turns on, reconnect it to your computer (if USB connected). Then try to print again once the computer fully recognizes the USB connection or when the WiFi light on the printer turns solid green (if WiFi connected.).
If that doesn't help, try the steps below:
  1. Disconnect the USB cable connecting the printer from your computer.
  2. On your computer, go to Control Panel > Printers and Faxes.
  3. Delete the Lexmark print object.
  4. Reboot computer.
  5. Re-brick your printer by pulling out the power supply - black box where the power cord is plugged into on the back of the printer, and re-plug after 30 seconds.
  6. When the printer turns on, reconnect it to the computer.
  7. Wait until your computer fully recognizes the USB connection. To check, go to Control Panel > Printers and Faxes. If you see a new Lexmark print object in the list, try to scan a document again to verify that the problem is fixed.
Nov 02, 2011 | Lexmark X6650 4-In-One Wireless InkJet...
Cant scan on my lexmark x4690 it does print
A quick fix for most communication errors can be achieved by resetting the printer and/or rebooting the PC. Simply disconnect the printer from your computer (if USB-connected). Reboot your pc. Unplug and re-plug the printer into the power source to reset it. When the printer turns on, reconnect it to your computer (if USB-connected). Then try to print again once the computer fully recognizes the USB connection.
Sep 12, 2011 | Lexmark X4690 Wireless InkJet Printer
My lexmark x6650 printer will not connect back online
A quick fix for most communication errors can be achieved by resetting the printer and/or rebooting the PC. If your printer is connected via USB cable to your computer, simply disconnect the printer from your computer, reboot your pc and unplug/re-plug the printer into the power source to reset it. When everything turns back on, reconnect the printer into the pc. Wait for the computer to fully recognize the USB connection. Try to print again.
If you're printer is wirelessly connected to your computer through your wireless network, please refer to this article for a more comprehensive instructions on how to identify and fix the communication problem - Wireless & Network Communication Issues with 2008 Lexmark Inkjet Products
Jul 06, 2011 | Lexmark X6650 4-In-One Wireless InkJet...
After power outage the printer won't power up.
The printer is dead, the surge got thru and fried it. Replace it and the surge-protector.
May 08, 2010 | Dell 922 All-In-One InkJet Printer
Communication error
Remove and rthen reistallthe printer driver from you PC and select the USB connection option.
Sep 24, 2009 | Epson AcuLaser C900 Printer
Dell Color Printer 725 - Communication Not Available
I have seen that in most of the cases (with lexmark and dell printers) it is fixed by reinstalling the printer software. Be sure that you completely remove the older drivers using the cd or using add/remove programs.
Mar 14, 2009 | Dell Inkjet 720 Printer
Dell Dimension 8200 PC Desktop Logo
46 people viewed this question
Alun Cox
