Question about Yamaha HTR-6130 Receiver
Can't get audio from HD TV to run through Yamaha receiver speaker
Both TV and receiver/speakers are new. I've connected the cables from the TV audio out to the receiver audio in. The receiver and speakers work on radio setting but will not produce sound from the TV.
Any suggestions appreciated....
  • 1 more comment
  • rkinser Jan 26, 2009
    Actually, I finally figured out that it was the programing of the received that was causing my problem. The hookup was fine, but the yamaha manual is very difficult to understand on the programing/operation portion. BTW... the TV sounds great thru the receivers and speakers.
  • rynester Feb 10, 2009
    On my receiver it shows I have only my front left & right speakers hooked up. I hear sound through all of my speakers when using analog cables. I went and purchased the top of the line optical monster cable to run straight from my receiver to my samsung 23" LN-T23454H. I am just trying to get my 5.1 digital surround sound and I am about to throw the thing through the window. Super simple. Optical cable plugged into DTV/CBL going straight into my TV's Digital Optical Out port. HELP!
  • hlucas12 Feb 21, 2009
    I have my tv and reciever hooked up by HDMI and I have optical audio cable running from the tv straight into the reciever. The sound cuts out for a second and then comes back on...is there anyway to fix this or have a I wasted my money on the optical cable???
    Problem Solver:
  • 6 Answers
Be more specific!...how is the tv hooked up? hdmi, component, straight to the tv, or into the amp then tv?....what audio out? optical, digital? also what are you trying to view? local programming? cable/sat? dvd? your best bet is to ignore video on the amp and go straight to tv. can't help u more until i have more specifics.
Posted on Jan 23, 2009
How do i connect my JVC screen tv so that i can hear out of my speakers
If your JVC TV has AUDIO OUT outputs on the rear and a provision in the initial set up screen to disable the internal speakers, you can connect to your Yamaha receiver and enjoy improved sound.
Dec 14, 2014 | Yamaha RX-V471 Receiver
Yamaha rx-v2500 receiver how to hook up speakers
HI,
Follow these steps to connect a powered sub woofer to your receiver: You typically have two options when connecting a powered sub woofer. Input (1) on the rear of the sub woofer would be used when connecting the sub woofer to the receiver using speaker wires. You would then connect the main speakers to the opposite end, or output or the sub woofer to the main speakers. Option (2) would be using RCA line level output jacks, input (2) on the rear panel of the sub woofer directly to the single sub woofer output on the back of an AV receiver. blank.gif
Oct 06, 2008 | Yamaha RX-V659 Receiver
Humming coming from the speakers
From all speakers?
How is the audio connected to the TV (be specific)?
Keep in mind that a TV is not generally an audio source as its programming always comes from something higher up the audio food chain than itself. Get the audio to your receiver from whatever THAT is, not the TV.
May 29, 2010 | Yamaha HTR-5730 Receiver
Yamaha RX-V365 unable to receive 5.1 audio from TV with HDMI
If you're expecting multichannel sound FROM THE TV instead of from the source you're watching, it's not gonna happen. TV's are notoriously poor sound sources. This one is no different.
Multichannel TV-related audio is best found at its source - cable / sat / dvd / bd....
I run video-related audio from my video sources directly to my TV and their audio directly to my receiver. Specialization yields best results.
I'd recommend skipping the Receiver for video, too, as it adds a lot of opportunity for HDMI-related incompatibilities and sound syncing problems. The more interconnects in the path, the more distorted it will become and the more opportunities for problems. Plus you can bypass the receiver and listen to lo-fi programming like news and weather through the TV's speakers if you like. Save a buck on electricity.
Just curious, which HDMI on the receiver is connected to your TV? Input or Output?
This note is on Page 11 of the manual:
Audio signals input at the HDMI jack are not output from any speaker terminals but output from the connected video monitor. To enjoy the sound from speakers connected to this unit,
-- make an analog or digital connection besides the HDMI connection (see page 13).
-- mute the volume on the connected video monitor
"Check SP cable." -- The unit is perceiving a short circuit. Are your speaker impedances sufficiently high? Disconnect the Front Right speaker and try raising the volume again. The speaker may be blown or the cable shorting.
Apr 30, 2010 | Yamaha Rx-v365 A/V Home Theater Receiver
TV/DVD surround sound through receiver
Try running digital audio from the source - cable/sat - to the receiver. The fewer intervening connections and entities, the better. TV's are NOT considered sound sources for high end purposes or we wouldn't have Yamaha HTR-5860's and better speakers, would we?
Apr 22, 2010 | Yamaha HTR-5850 Receiver
Yamaha HTR-6130 sound only from centre, rear or front speakers
its not how there connected its in your settings. rehook up all your speaker connections properly,then make sure you proram the reciever to recieve fiber optic,hdmi,digital coax etc in the reciver.
May 18, 2009 | Yamaha HTR-6130 Receiver
Yamaha RX V463 AV Receiver-I have an LG digital LCD tv and hooked up the two up by HDMI and an optical cable. I Only get sound from the right front and the subwoofer The Rest of the 4 speakers have no...
If you're getting audio out of one speaker, it's likely not an issue with how the TV's connected to the receiver, but an issue with how your speaker's are connected.
If you run a "speaker test", do you get audio out of all your speakers? If not, it's likely you mixed up your positive and negative connections when connecting your speakers.
Mar 19, 2009 | Yamaha RX-V463 Receiver
Audio output
I have the same issue if I connect my digial audio cable from the Yamaha receiver directly to the HDTV. But, I get all 6 speakers working when I connect the Yamaha receiver directly to the Comcast HD box (instead of TV).
Dec 11, 2008 | Yamaha HTR-5650 Receiver
Setting up a Yamaha RX-V690 home theater system
you almost have the exact same situation i am in. i have the same receiver, and going to purchase a panasonic 50" (th50px75u). i think what i will be doing is running a hdmi from my hd cable box to my tv, and installing an audio cable (red/white) from my tv to the receiver. i believe there is an audio input below the hdmi insert. i have polk audio, but theyare about 10 years old, they sound great, but just too large....and may be purchasing a harman kardon system. which models do you have from polk? i have the rt16's, cs350ls center, and fx/500 rears. let me know what you have come up with as well...as it has been a while since you posted this.
cheers,
sean
Nov 05, 2007 | Yamaha RX-V690 Receiver
No sound from Yamaha HTR-5990
You must be sure that you also have "audio" cables connected to the receiver to make this all work. As far as the TV is concerned, the same applies....accordianman
Oct 31, 2007 | Yamaha HTR-5990 Receiver
Yamaha HTR-6130 Receiver Logo
1,014 people viewed this question
Top Yamaha Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Yamaha Audio Player and Recorder Expert? Answer questions, earn points and help others
