Transformer has failed in my Trutech M#KLV3112
I have a under cabinet mounted TV/DVD/RADIO unit from Trutech. We had a power spike that caused the transformer to fail. I need to know what the rated secondary voltage is.
  • dk194 Jan 14, 2009
    I wish it did, It just has the following number, L5735-E02U. I know the primary is 120 volt but have no idea what the secondary mite be. Thanks for posting.
    Wowzers! I think I may just do this. Thanks for the idea!
    Sergeant:
  • 227 Answers
The transformer should have the input and output rating labeled on the unit itself. Such as input 110vac, output ...... dc.
Posted on Jan 14, 2009
  • Mike Schmidt
    Mike Schmidt Jan 14, 2009
    Assuming this was bought at Target, Go and buy another one remove the adaptor and take voltage readings to see what the secondary is on the output. And take it back. Or put in the old one and keep the new one and return it as not working. These manufacturers want to keep us in the dark.
Trutech TV/DVD klv3110 spacesaving kitchen manual download
Hiya Rosa,
you can try the manuallslib site they have most of all manuals from old mixing gear through to modern tv/DVD players,
Hope this helps
Kevin.
May 23, 2015 | TruTech KLV3112 10 in. LCD TV/DVD Combo
I have a TruTech KLV3112 10in LCD TV/DVD combo and the DVD door will not open. What do I do?
I would try unplugging it for 5 minutes and then power it back up.
There may be a reset/eject button that you can depress with a pin or paperclip near the door much like an old Macintosh had.
I have long since abandoned this unit and have a Skyview 13" in my Westfalia. You might have to do the same if you need to run DVD's.
Mar 02, 2015 | TruTech KLV3112 10 in. LCD TV/DVD Combo
The dvd tray will not open, why?
Possible that the mechanism is faulty or the drive has failed in the control board.
Also if there is a DVD that has jammed it can prvent the tray from opening. So it is best to open the set to check on the mechanism and also on the voltage to the drive to confirm.
Jun 17, 2011 | TruTech KLV3112 10 in. LCD TV/DVD Combo
It's not a problem ... I just want to know what the power requirement is for the Trutech 10" Undercabinet LCD TV/DVD Combo - KLV3112
Hi, it will be in the 9 to 12 volt range probably with about a 2 amp rating. Buying the kind of " universal " power supply with interchangable plugs should do the trick. The actual " adapter " you buy will more than likely be marked as follows 100-240v~ 0-12v dc ( or a solid vertical line over dashes) 2.5a followed by a polarity indicator. Always be careful too when inserting new plug-it should fit snugly but not so that you need to push with much force. thanks for letting me try to help, I hope this was of some assistance. Good luck, Prodzilla
Apr 13, 2011 | TruTech KLV3112 10 in. LCD TV/DVD Combo
I need to purchase anothe remote for my Trutech under cabinet DVD/tv combo. could i get the number to call Trutech or anybody that can sell me another remote please..
If you were to log on to the manufacturer's web site, I think you will be pleasantly surprised as usually one is able to download, by model number, Customer Instruction Manuals, list of Dealers for spare part supplies and Driver downloads (if applicable) as required.
The information is normally free of charge.
I hope this helps.
Jan 05, 2011 | TruTech KLV3112 10 in. LCD TV/DVD Combo
Do i need a converter box or attena for this tv??
U require a good antenna no need for a converter box,because this tv is digital tv.
Nov 08, 2010 | TruTech KLV3112 10 in. LCD TV/DVD Combo
I have a spacesaving kitchen 10
I have the same problem as the above question. The picture goes off and there is only sound
Feb 17, 2010 | TruTech KLV3112 10 in. LCD TV/DVD Combo
Comcast dta remote codes for trutech klv3112
I have a Trutech 10 inch under cabinet DVD/TV and needed the codes for the new Digital Adapter that Comcast is forcing everyone to move to. The short answer is that there isn't a single code that will work for what we all need. After much research I have an answer. It's largely unsatisfactory, but its somewhat of a work around. If you use code 10451 you can get the channel up, channel down, the number pad and the "last" button to work. To get volume functional, change the volume lock on the comcast box. To do this:
1. With the TV on, manually set the volume to a medium high setting
2. With the comcast remote, press and hold SET until the red light blinks twice.
3. Enter 9-9-3 (red light blinks twice)
4. Press and release the digit 1 (red light will blink 4 times)
Now, in addition to channel control, you have volume control. I can't do anything about the power button or other functions. However, this at least makes the remote functional.
Good luck to all!
Jan 10, 2010 | TruTech KLV3112 10 in. LCD TV/DVD Combo
Need manual for trutech product
go to the trutech website and you should be able to download a manual there.
Nov 29, 2008 | TruTech TT320
Televison & Video Logo
155 people viewed this question
Top Televison & Video Experts
Electro Med Services...
