Question about Apple iPod classic MP3 Player
Ipod a1099 i have tried everything to reset my ipod. all i get is the the apple logo and then a www.ipod/support and thats all.
  • occhi_scuri0 Jan 14, 2009
    thank you so much. the solution worked!
  • Anonymous Feb 26, 2009
    uSB is not recgnized
  • 81 Answers
That's the equivalent of the blue screen of death for Windows. That means there is trouble with the hardware. More than likely your hard drive. Usually the heads get stuck. If you can take it apart, remove the battery for a few minutes to reset it. Some people are known to have whacked their ipod on a hard surface and its fixed the problem. Only temporarily though. I don't recommend it.
Posted on Jan 14, 2009
  • 3 Answers
For what it's worth, I just fixed my a1099 by rapping it briskly against the palm of my hand, along the thin sides.
Posted on Feb 21, 2010
  • rusha Oct 18, 2011
    myy ipod is also having the same problem..cant be charged and displays the logo and the site..what do i do?my model is A1099
On the ipod 20gb after apple logo comes then bettry logo comes
Reset Click Wheel Ipod (newer ipods including resetting an ipod video)
1. Flip the Hold switch on and off and make sure it ends up no longer on hold.
2. Press and hold the Menu and Select buttons (center Button) until the Apple logo appears (may take 5-11 seconds, and you may need to repeat this step)
If this not work for you try plugging your ipod into computer or wall power
Resetting iPod (with dock connector)
Most problems with iPod can be solved by resetting it.
To reset iPod:
1 Connect iPod to a power outlet using the iPod Power Adapter.
2 Toggle the Hold switch on and off (set it to Hold, then turn it off again).
3 Press and hold the Play/Pause and Menu buttons for at least 5 seconds, until the
Apple logo appears.
If Your iPod Won't Turn On or Respond
* Make sure the Hold switch is off.
* If you're using the iPod Remote, make sure the remotes Hold switch is off.
* If that doesn't work, connect iPod to the iPod Power Adapter and connect the
adapter to a working electrical outlet. Your iPod battery may need to be recharged.
Resetting iPod (with out dock connector)
If that doesn't work, your iPod may need to be reset.While the iPod
is connected to power, press and hold the Play and Menu buttons
for at least 5 seconds, until the Apple logo appears.
Mar 03, 2011 | Apple iPod classic MP3 Player
I have two ipod video's a1099 and a1059, They were dead wont turn on wont charg,, I got two new battery's The a1099 came on with new battery and had about 1/2 a charge, charged it last night just...
Hi, answer a little bitlong, you can use this links to reset the ipod.
reset-ipod.com/reset-ipod-video.htm
or
support.apple.com/kb/ht1339
or
wikihow.com/Reset-an-iPod
or
support.apple.com/kb/ht1320.
Hope it helped. await your comment.
Take care.
Jun 06, 2010 | Audio Players & Recorders
I have the white screen on my ipod nano 2nd gen i tried the reboot, restore, debug everything i cant see any logos text or anything i cracked my old screen ao i bought this put it in and bam white screen...
Hi.
This is probably caused by not allowing the firmware update to finish the installation before disconnecting the iPod. Try these steps:
Reset the iPod:
  1. Turn the Hold switch on, then back to off.
  2. Press and hold the Menu and Select buttons for 10 seconds (until the Apple logo appears).
  3. You may need to repeat the reset several times.
If the reset doesn't help, then put the iPod into forced disk mode.
Put iPod into Disk Mode:
Apple suggests that you ensure your iPod is charged before following the next step. How exactly you check a charge on an iPod screen that is completely white has yet to be revealed. But hey, give it a shot anyway. Plug the iPod into a high-powered USB port, let it sit for 2 hours, then disconnect it. If you have a wall charger, plug in the iPod, then follow these steps while it is still plugged in.
  2. Press and hold the Menu and Select buttons until the Apple logo appears
  3. Immediately switch your figures to press and hold the Select and the Play/Pause buttons until "Disk Mode" appears at the top.
For a lot of people, this solves the problem. Connect the iPod to the computer and (assuming it shows up) reset the iPod again to get it out of Disk Mode. If at this point you still have the white screen, restore the iPod using the restore function in iTunes under the Summary tab (this will erase everything on the iPod and put it at factory settings).
Don't disconnect or eject the iPod until the store is totally done. After you think it's done, wait another five minutes
Nov 05, 2009 | Apple iPod nano 2nd Generation MP3 Player
Mi ipod have a text sayin please contact suport
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} The message "go to www.apple.com/support/ipod" usually is preceded by, or followed by, the Apple logo or the sad face icon. It directs you to the Apple support site because either the iPod software is corrupted or there is a hardware problem. You should try to reset the iPod (try several times). Toggle the Hold switch to on, then back to off (none of the red is showing). Reset your iPod Press and hold down the Menu and Select buttons for 10 seconds (until you see the Apple logo) If you can update/reload the iPod software, this may fix the problem with your iPod. If that doesn't right the iPod, then try to restore it (which will erase the entire iPod and reload the software) in itunes. It will not erase your itunes library, only the files on the ipod itself. I hope this helps and good luck. Please vote appropriately and leave a message.
Oct 30, 2009 | Apple iPod MA446LL/A MP3 Player
Ipod touch freezes at the apple logo
mine did the same thing. plug it into the computer. when it's open in iTunes, set the iPod to manual. sometimes when it's automatic, it'll clear itself out/freeze up until you plug it in again. this worked for me. it could be a glich, or their way of getting us to go onto iTunes more often.
Sep 10, 2009 | Apple iPod touch
Where do i find my songs in ipod A1099?
after connecting to itunes ,try to reset your ipod to factory settings,then re-sync the music .
this sud solve ur probs
harri
Feb 19, 2009 | Apple iPod MA446LL/A MP3 Player
Ipod not working, displays only shows the apple logo
Start with these five simple solutions: Reset, retry, restart, reinstall, or restore
http://www.apple.com/support/ipod/five_rs/
If you need more assistance let me know. I'm here to help.
Apr 11, 2008 | Apple iPod classic MP3 Player
White screen, have to do a soft restart and then words show up
if you are having the problem of a blank white screen, dont freak out! hold down the menu and select button for about 15 seconds or until the appel logo appears.if this doesnt work try plugging in your ipod. if that doesnt work wiggle the lock and unlock button a couple of times. if all these soulutions dont work go to www.apple.com and call customer support
Nov 13, 2007 | Apple iPod nano
Apple iPod classic MP3 Player Logo
839 people viewed this question
Top Apple Audio Players & Recorders Experts
TO Lady
Are you an Apple Audio Player and Recorder Expert? Answer questions, earn points and help others
