Question about Whirlpool Duet GHW9150P Front Load Washer
Can i adjust the water level on my Duet?
Is there a way to increase the water level on my machine.
  • Anonymous Mar 30, 2014
    how to adjust
Ours isn't a Kenmore HE FL, but a Whirlpool Duet 9150. I add soap to my soap dispenser (a small amount), set the cycle and turn machine on. I set a timer for about 6 minutes, then I add 4 gallons of water by pulling the soap dispenser drawer out about 2.5 inches and pouring water in. I do not open the door itself, but the soap drawer. At this point, the water will now touch the bottom rim of the glass door and gets ALL the clothes wet...even those wrapped in the middle. It has helped TREMENDOUSLY in actually cleaning our clothes now, but it is a PAIN to have to add water to each load! BUT my clothes are getting clean and before they weren't...before, the soap would build up in my clothes. (Did I mention that I only use about 3/4 of the tiny little circular measuring cup of Tide HE? I doubt it is a tablespoon.)
Posted on Jun 26, 2012
    New Friend:
  • 88 Answers
Sorry there is no way to adjust the water level. the washer decides how much water by how much clothes are in the washer .
Posted on Jan 14, 2009
  • 3 Answers
Check out this guys blog and see how he increased water level in his Duet.
http://whirlpool-dueling-with-duet.blogspot.com/
Posted on Mar 05, 2009
2 Suggested Answers
  • 415 Answers
SOURCE: canyou adjust the water level on a whirlpool duet
no and if you fill by hand and attempt to start an wash cyc it should pump out the water first
Posted on Aug 24, 2009
Too much water going to the tub
Many top load machines have a big metal water level sensor up in the electronics bank with a plastic tube that senses pressure as it fills. There is a small half inch screw in the center of it that is adjustable to set the water level on that thing. The sensor sort of looks like a car EGR vacuum recycler valve. Check Google images of washing machine water level sensors to see if your has it, as it is fairly universal. Make sure your pressure tube is not loose or kinked.
Mar 10, 2014 | Whirlpool GHW9150 Duet Washer
Overflow during cycles
There is an adjustable water level sensor up in the electronics bank on many Whirlpool toploaders. It is usually metal, about 2 inches around and has a 3/8" diameter hose going down to the tub that senses air pressure as it fills. Try to back off the half inch screw in the center a little. Check on Google images to see if your machine has something that looks like this somewhat universal adjustable "water level sensor"
(use quotes around your search phrase).
Mar 06, 2014 | Whirlpool Duet Sport HT WFW8400TE Washer
Can you ajust water level to be more in washer
No.
As with all modern machines your senses the size of the load and adjusts water levels accordingly. Unlike older machines, this means that less water is used and less energy is used to heat excess water. It also means that you get a better wash as the cleaning quality is lower if the load is sloshing about in too much water.
May 16, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool fron loader washer leaks at the door
The water should be able to come up to the door level without leaking. Chances are you have build up on the bottom side of the glass on your door. If so take a razor blade and scrape the build up off. Your door will quit leaking.
Aug 12, 2017 | Whirlpool Duet GHW9150P Front Load Washer
Is there a switch or screw to increase water in washer
In short No. The water level is determined by the pressure switch and its feedback to the controller.
Nov 10, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Canyou adjust the water level on a whirlpool duet front loading washing machine model ghw9150pw3?
Aug 24, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Is there a way to increase the water level on a whirlpool front load Duet washer model GHW-9150
If the machine is underfilling, check the water level switch. This diaphragm like device has a small clear plastic tube attached between the switch and the bottom of the washer's outer tub. As the water level increases, so does the pressure on the air in the tube and when it reaches a certain level, it activates the switch to shut off the water and signals the timer to advance to the appropriate cycle. Make sure the plastic tube has no damage or obstruction. An obstruction can cause the switch to be activated too early.The switch can be tested for continuity using a multimeter or ohmmeter. A lack of continuity would indicate a faulty switch. Hope this helped and best wishes.
Aug 09, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Water level problem with duet GHW9300WHP
The best way to check this problem is to run with no clothes in it the water fill and stop three time after the third time the water level should be high in the back tapering off to not much in the front this unit wash as a chemical wash not with a lot of water
Mar 28, 2009 | Whirlpool GHW9300 Duet Washer
Not enough water
http://mikes-duet.blogspot.com/ shows how to adjust water level. I would give it a shot...Mike also has the link to the online manual.
Oct 27, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool duet washer
Increasing the water is not possible and would not help anyway. The odor is from bacteria. To kill the bacteria run a load without clothes on the HOT wash setting and add a cup of bleach to the soap dispenser. In the future to prevent it from returning use the hottest water allowed by the clothing care tag and use bleach whenever possible. If you don't like to use bleach or hot water you may need to repeat the cleaning once a month. Also make sure you are using a HE detergent. Non HE detergent can suds up and the suds may not rinse out with the water and can create an odor.
Jul 21, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Duet GHW9150P Front Load Washer Logo
1,149 people viewed this question
Dan Webster
Dan Webster
Sal De
