Question about Medion MD 7317 17" Flat Panel LCD Monitor
Medion MD7317 17 inch Flat Panel Monitor
Upon start up the monitor will not display anything and the power light blinks on and off.
  • 4 more comments
  • cariad333 Nov 01, 2007
    It appears to be a common problem with the MD731X range of monitors. It's not the inverter unit but appears to be on the power board. Still working o the problem unless someone has a fix for this
  • Anonymous Apr 07, 2008
    on start up blue light flashes on and off. Takes about two hours to come on. When on no problems at all.
  • Anonymous Apr 22, 2008
    exactly the same problem - blue light flashes takes half hour to hour to come on
  • Anonymous Apr 27, 2008
    have same problem medion 17inch seems to be with most of these monitors its not the video card it is the inverter which seems to fail after about 2 yrs of use which is not right medion must have lots returns for this monitor, you can either send back under warranty or if out of warranty get a new inverter which you should be able to find on ebay or a compatable one online.
  • Anonymous Jun 29, 2008
    my medion 32117 pq worked fine then once it the power light started flashing and after a while it came on but the waiting time increased and now it wont come on at all
    2 other monitors exactly the same purchased at the same time work fine still
  • ember_rio38 Jul 04, 2008
    i start up the desktop system unit is ok but the medion monitor is on but no display its all black
    Problem Solver:
My MD7317 did the same thing until I actually installed the driver for it. My windows did not have the correct driver in it's driver base, so I found the driver online ( took a few minutes of searching) and within a few minutes of installation the monitor displayed a great colorful picture. Naturally, I had to use another monitor while I was searching. Driver is about 3.3 megs. It came in a zip format. I did not keep track of the link to driver, but it omly took a few minutes to locate it.
Posted on Sep 03, 2007
Its not the video card i have the same problem so did my aunty get in touch with medion tech support and get a replacement if its still in waranty
Posted on Aug 14, 2007
  • liamo2 Aug 14, 2007
    its not the video card i have the same problem so did my aunty get in touch with medion tech support and get a replacement if its still in waranty
    President:
  • Medion Master
  • 1,314 Answers
This issue could be any number of problems. The most likely one is your video card / onboard video on your computer is not working. Try attaching your monitor to another computer and see if it works. If it does, then it is definitely the video card on your computer. Other causes could be bad VGA cable or bad monitor itself but 95% of the time it is the computer's video.
Posted on Jun 13, 2007
Monitor doesn't turn on
1ST CHECK POWER CORD.
2ND CHECK CONNECTION ON BACK OF PC
3RD HAVE YOU INSTALLED, DELETED OR REMOVED ANYTHING FROM YOUR PC PRIOR TO THE MONITOR SHUT OFF ON YOU
Feb 17, 2013 | Dell ST2420L 24 inch LCD Monitor
Medion monitor won't come on
inverter has gone .cheaper to buy another monitor
Apr 26, 2010 | Medion MD 7317 17" Flat Panel LCD Monitor
Hi, my monitor does not display anything but the lid light just keep blinking.
You should check your display cable from CPU to Monitor. If it just blinking then problem with you connection bitween CPU and Monitor So just check and keep enjoy.
Nov 11, 2009 | Samsung SyncMaster 710N 17 in. Flat Panel...
I CANT GET MY MONITOR TO TURN ON
It could be the Monitor, the VGA adapter, or the PC itself. If you power on the monitor without anything connected to it, do you ever see anything on the display?
If not, it is probably the Monitor. If yes, it is likely the vga adapter and/or PC.
Mar 18, 2009 | SVA-USA VR 17S 17" Flat Panel LCD Monitor
Takes to long for the monitor to start
This is a power supply problem in the monitor. There is an unstable component or components that are failing or you have some cold solder joints in the connections.The reason it turns on is that some components are self healing and will sometimes stabilize after warm-up periods.Cold solder joints sometime close after heating up in the circuit You should return to dealer for repair or replacement. Hope this helps you.
Feb 04, 2009 | Envision EN-7100e 17" Flat Panel LCD...
Medion md 7319
look for capacitors with the tops bulging .. these are high failure rate chinese made capacitors .. they made zillions of them and they fail frequently .. replace any that have buldging tops (should be flat with over pressure vent lines impressed)
Nov 19, 2008 | Medion MD 7317 17" Flat Panel LCD Monitor
MONITOR MEDION MD7317 NOT WORKING
i have some 19 inch medion monitors that have the same problem .. they make a lot of noise and the screen might be jittery/fuzzy ... i found the following:
several capacitors in the power supply (inside the monitor) had their tops buldging .. that shows that internal pressure was high in the caps, usually caused by them being hot and thats caused by high internal leakage .. the caps may eventually blow out the tops (explosion vents) .. the caps are designed to do that instead of becoming a bomb ..
all the bad electrolytic capacitors i have seen so far on these monitors, motherboards and other electronics have been chinese made .. they made millions of bad caps over several years ..
almost all the bad caps had buldged tops but not always .. once in a while i see one thats open but not bulbged .. probably venting elsware ..
i changed the obviously bad caps and the monitors returned to like new performance ..
i dont know about the 17 inch but the 19 inch medion flat pro display is not too hard to take apart .. about 30 screws or so ... speakers have to be unscrewed and you have to be careful not to stress cables that go to the push buttons .. of course you have to know how to solder without bridging paths
Feb 02, 2008 | Medion MD 7317 17" Flat Panel LCD Monitor
Medion MD 7317 17" Flat Panel LCD Monitor Logo
707 people viewed this question
Top Medion Computers & Internet Experts
Hollyecho Montgomery
Robert Karst
Robert Karst
Are you a Medion Computer and Internet Expert? Answer questions, earn points and help others
