Fan works at all speeds
SOURCE: 1999 honda accord ac / heater fan control
Hi! The speed control is defective.The terminal 1&2 could either b worn or burnt out.
SOURCE: 98 honda accord A/c panel lights went off. Now only blower works.
you are going to need to replace the climate control panel...
SOURCE: 2000 honda accord v6. Indicator lights remain on
Alternator not charging by if all lamps are lit
SOURCE: 2002 Honda Odyssey fan only works at high speed. The A/C compress
Usually when the blower fan only operates on hi speed, its because of a failed blower motor resistor. You still have hi speed because on hi, the power going to the blower motor goes directly to it, as opposed to the lower speeds, when the power is routed through the resistor, thus lowering the voltage, which in turn lowers the speed of the fan. The resistor is usually located near the blower motor itself, under the hood back near the firewall.
SOURCE: how do i replace instrument panel lights (heat and
The center dashboard panel, which holds the climate control system, etc., must be gently pried up. Start at the bottom and work your way around. Once this is loose, disconnect the electrical connectors and the panel can be removed completely. The light bulbs are marked Gray and Black and are freed by a turning slightly. I think the only place you can get the bulbs is a Honda dealer.
