Question about RCA RTD207 System
Rca rtd2006 usb slot
Hey i just set up my the surround sound verything works properly except my usb slot. i tried hooking my phone which has a mp3 player on it as well as my ipod and a hook either of them up it just says loading FOREVER...it never does anything else. any suggestions would be gratefully appreciated! thanks! :)
  • m0n0 Feb 23, 2008
    my usb input doesnt work i want to hook up my ipod wat can i do
  • teamrojasx2 Jan 16, 2009
    I tried to hook my Sansa MP3 player and got a "Menu" screen. It shows that something is being downloaded, but when I hit play I get Nada!!!!
The usb slot does not except anything too complicated.. So pretty much it accepts simple mp3 players, and flashdrives.. anything else will just result in the message you got.
Posted on Oct 08, 2007
I cannot get the surround sound to work on my tv
no it does not, however you will only get surround on channels broadcasting in Dolby surround. try another input like a DVD / Blu ray
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/tony_a41fa0b801734e2f
Oct 15, 2014 | RCA Televison & Video
I'm trying to hook up a sharp aquos tv to an rca surround sound receiver and it won't work? any suggestions? I have tried turning off the speakers on the tv....
First thing to do is get the owner manual for each and start checking both settings and actual hookup---usually a surround system will work on all types of sets---when in doubt read the owner manuals.
If need either manual Google that model number with "manual" to try to locate it.
As far as the set goes it may require either a variable audio output source or in some cases the out to be a fixed level.
May 23, 2012 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
I just bought an rca surround sound rtd315w - mp3 won't work
You must select that input with the RCA surround sound
Apr 20, 2010 | Televison & Video
When watching a DVD in surround sound movie mode
FIRST- double check that the center channel is hooked up in the center channel connection. we have all made this mistake. second if you are watching a movie through a dvd or bluray player be sure that both your audio L/R rca's or hdmi cable's are plugged in. I do not know if your are on cable or satellite? Double check the connections. Be sure that the that if your can select your sound preference turn it to 5.1 surround or matrix. hope this helps
Jan 11, 2010 | LG LH-T754 Theater System
RCA 5.1 Surround Sound Receiver Sounds fade in and out
chk how you are hooking up the speaker polarity minus to minus and plus to plus.
Oct 17, 2009 | RCA RT2250 System
No surround sound on normal tv just dvds
Do you have a cable box or satellite box? If you do, try hooking up your TV sound through the box. Look for audio out in the back of box (white/red RCA Jacks). Hook RCA cable from cable box to surround amp. Even if the audio out jacks are being used already, you can use Y connectors to hook up the surround amp to the box.
Hope this works for you!
Jul 23, 2009 | RCA Audio Players & Recorders
Suround sound does not work on my 26" proscan
Hello Brian,
I understand your problem and I have a surround sound system hooked up to my TV and I think I might be able to help you because I have done this in the past.
RCA Setup Only
  1. On your TV you should see an Audio Out slot. Plug your RCA Cord into that slot.
  2. Then plug the RCA Cord to the Audio In slot on the Surround Sound System.
  3. Then, if your Surround System is the type with a DVD in it continue step 4.
  4. You should see a Yellow Video slot on the TV. Plug the Yellow RCA into that slot.
  5. If you do not have one of those, you would need to pick one up at a Electronics Store.
HDMI Setup Only
  1. Take the HDMI cord and plug on end into the slot on the TV.
  2. Take the other end of the HDMI cord and plug that into the slot on the Sound System.
I hope this helps you out.
If you have any questions, let me know
Thank you for using Fix Ya!
Don't forget to rate the overall satisfaction of this solution.
Mar 01, 2009 | Proscan 26LB30QD 26 in. LCD HDTV
Correct hook up
connect the right and left audio out to any of the audio in of the unit. dvd,game,mp3 etc via a pair of RCA connectors
Aug 30, 2008 | Durabrand 5.1 Surround Sound Computer...
No USB reaction
Hey I have an !RCA! Pearl MP3 player and it doesn't even work with the unit. Though I saw a suggestion of buying a usb flash drive and filling it with music.
Mar 30, 2008 | RCA RT2760 System
Hooking up video
I am assuming that you are using a surround sound system?If so on the back of the satellite receiver you will have RCA cables labled yellow ,red,white uuse an rca cable to run from the output on the back of the sat box to an rca input on the surround sound unit.the inputs should be labled on the back of the surround sound unit.once you have the sat box plugged in look for the output on the surround sound (rca cables) run one set of rca cables to the rca cable input of the Tv.on the original tv remote select the tv input that is the cable from the surround sound is plugged in to . make sure the surround sound unit input is selected to the input that the sat box is plugged into.this will give you surround sound from your satellite receiver,repeat with your DVD player plugging the DVD rca cable output to another empty input on the surround sound.to switch between the sat box (satellite TV) to DvD select another input on the surround sound unit.Try to correspond the units you are plugging into the surround sound to the correct name of the component on the back of the surround sound unit to avoid confussion.any questions,Im here to help.If this works rate me FIXYA! if it helps.GOOD LUCK!
Nov 18, 2007 | Panasonic SC-HT40 System
RCA RTD207 System Logo
145 people viewed this question
Top RCA Audio Players & Recorders Experts
Gyula Lacz
Are you a RCA Audio Player and Recorder Expert? Answer questions, earn points and help others
