Question about SanDisk Sansa m250 MP3 Player
I cant put songs on my sansa
Whenever i try to put a song on it it says "do not have rights" or something like that. by the way i tried changing the USB settings but that did not work.
    Champion:
  • 203 Answers
It is look like it is psword protected ,or has some kind the buton wich does not let you put/remove song's fom it.try to find that buton or rest to factory seting, format the player.
Posted on Jan 19, 2009
My sansa e260 will not work with Windows Media Player...
Try using Windows nedia player, put all the songs you want into media player, connect you sansa and hit the sync selection on the windows nedia player screen the screen will change and you can slide whatever you want to put onto the player to the sync column on the right when you have it all over there hit the start sync button and it shouls all go into your player
Mar 22, 2009 | SanDisk Sansa e250 MP3 Player
My songs wont add onto my sandisk sansa mp3 player
What format are the songs you're not able to hear? It's possible that the songs are not in a format the Sansa can play.
Also, you can navigate your Sansa like a removable drive. Try going to "My Computer" and looking to see what's actually on the drive.
Nov 27, 2008 | SanDisk Sansa e250 MP3 Player
Sansa c250 troubleshooting
The Bearshare songs have either a Green or Gold disc next to them. If you don't have a current, paid subscription, one set of them won't work. If your Bearshare subscription is up to date, connect the mp3 player to the computer and have Bearshare update the licenses on the songs. Also, some Bearshare songs have fixed-term licenses - your playing rights from the mp3 player expire after a certain amount of time. If you choose songs that are only in mp3 format (i.e.: not bearshare, napster, etc.)
-Tha Mp3 doctor
Nov 18, 2008 | SanDisk Sansa c250 (2 GB) MP3 Player...
Cant add songs after i made space
Have u checked if the songs u put in have extensions that are supported by the player............in ur case check if some of the songs are .rm or something and not .mp3...........only files with .mp3 extensions will be supported
Aug 28, 2008 | SanDisk Sansa e250 MP3 Player
Can't load songs
ive had this same problemo. you cant use the media converter to drag and drop songs. you have to download your songs or rip them onto windows media player. you plug in the sansa and then when its recognized there will be an area on the right hand side where you drag the songs and they appear on sansa.
Jan 27, 2008 | SanDisk Sansa c250 (2 GB) MP3 Player...
Sansa shaker files write-protected
SHAKER ONLY TAKES MP3 FORMAT!!!!!
Use this site to change your format to the correct one for the sansa shaker. This is the only way to load songs from your cds MWA will not work at all. Must convert all files to MWA use site below
http://www.wma-mp3.org/
Dec 10, 2007 | SanDisk Sansa Shaker SDMX9N-512 MP3 Player
I cant find the songs to delete and it the refresh database fails everytime
If you cant see it in MTP mode, the MTP drivers may not be installed on your computer.
Its easier to do this than explain the other solution.
Follow these instructions and you will be back in business.
Run the recovery tool from the SanDisk website. Make sure you select "format" when prompted.
http://www.sandisk.com/Assets/File/Downloads/firmware/e200fw01.00.12.exe
You need to put the device into "recovery mode" before you run the tool.
- Turn the device off (hold power for 20 seconds)
- Slide the hold switch into "hold" position.
- Press and hold the "record" button while connecting it to your computer. Keep holding the "record" button until you see the "new hardware found" on your computer.
Then run the recovery tool. Select format when prompted.
Best of Luck.
Oct 14, 2007 | SanDisk Sansa e250 MP3 Player
Cant fast-forward through a song
that will happen to my if my battery is low, did you try changing the batteries?
Jul 12, 2007 | SanDisk Sansa m240 MP3 Player
Cant add/delete songs
it is just re-reading the songs
Apr 20, 2007 | SanDisk Sansa e260 MP3 Player
SanDisk Sansa m250 MP3 Player Logo
70 people viewed this question
Top SanDisk Audio Players & Recorders Experts
Gyula Lacz
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
