Question about Extensis Suitcase X1
Presto combination lock on a suitcase will not open
The lock was reset to a new combination then closed without closing the suitcase--I cannot get the lock to open to reset the combination.
  • mgepainting Mar 24, 2009
    My Samsonite lock which is travel sentry certified has depressed and is lower than the locking hole. I need to know how to make it pop up so that i can continue using it. thanks.
  • Anonymous Mar 31, 2014
    How do I set the combination lock
My mother in law has a norton suit case and needs keys the number on the lock is 332 norton do not excist anymore where can i get replacment keys from?
Posted on Mar 01, 2010
Hartmann suitcase. How do I open Presto lock with 3-digit combination?
Look for my tip on opening luggage with combination locks in this listing.
Nov 27, 2015 | Luggage & Travel
How to unlock suitcase
Pain in the *** but these are simple three tumbler locks. I am assuming it is what you have. If you start at 000 and go up in increments of 1 you can probably get this in about an hour. Other than that a screwdriver will break it open if you pry in at the locking mechanism.
Dec 01, 2014 | Samsonite Silhouette 11 Hardside Spinner
By frequently resetting your lock combination, you decrease the chance that someone will break into your luggage.
If someone watches you open your luggage at baggage claim while going through security or at a hotel, they may break into your luggage when they encounter you on another leg of your journey.
Change your lock after every major flight or trip to help keep your items safe.
Avoid easy to guess passwords, as well, such as sequential numbers, all the same number or birthdays.
Open your lock by inputting the current combination.
New Prestolocks have a factory set combination of "0-0-0."
Turn the shackle 180 degrees.
Press the shackle down and turn it 90 degrees to the left or right.
Input the new combination.
Move the shackle 90 degrees so that it is 180 degrees from its locked position.
Take your hand off the shackle and pull it out.
Turn it back to the locked position.
Push the shackle into the lock and turn at least one of the lock's dials.
Write down your new combination.
Keep this paper in a safe place for future reference.
Jun 20, 2013 | Extensis Suitcase X1
Forgot my Presto Lock combination!
You cannot reset the lock unless you know the combination. You would need someone to pick the lock, like a locksmith and then once it's open you can reset the lock with a new combination.
Jan 25, 2013 | Locks & Locksmithing
How to change lock code in TSA007 lock?
Nov 30, 2012 | Samsonite Tripod
My combination on my california pak luggage does not work. How can I open/reset the combination?
If the lock is unlocked - try this: Unzip the inside liner, find the lock backing plate. Undo the 2 screws and remove the lock from the suitcase. Find a good strong light, and maybe a magnifying glass. Look at the 3 holes in the back and rotate the dials until the 3 slots are lined up. Open and close the lock, noting the combination. Re-assemble the lock on the suitcase. Hold the lock open, dial in your own combination. Make sure it works before locking it up. Cheers
Aug 27, 2011 | Locks & Locksmithing
I don't remember the combination but it is open. please tell me how to set it
same problem with the spinner model.
My suitcase is open but since I dont have the lock combination (3 digits) I can't close it (not lock it, just close the case) . The combination changed when the case was open - is there a way to reset it ?
Mar 05, 2010 | Samsonite Tripod
Problems to open a Samsonite TSA 007 lock on suitcase
Hi I have a problem to aopen my luggage I think my niece has change my security code accidentally , but now I cannot open my luggage can you please chelp me out?
Nov 08, 2009 | Samsonite Tripod
I HAVE THE TSA COMBINATION LOCK ON A SAMSONITE GRAVITON G LUX
I can't answer the problem - but am interested as we had an identical failure on holiday in South Africa. We had to force the case open as the lock and the mechanism seemed to have come adrift in that when moving the lever with the correct combination - the case neither opened or closed. I'm sending it back to Samsonite under warranty to hopefully get it repaired/replaced. I rang the UK number listed on the Samsonite website. Bit disappointed as Samsonite should be more reliable - particularly given the price of the case, at £295, isn't exactly cheap.
Apr 11, 2009 | Samsonite Tripod
I WHANT TO RESET MY MASTER LOCK , WHAT STEPS I HAVE TO FOLLOW?
Instructions:
Opening the key storage
compartment door
1. Open shutter door to reveal the dials
and the release button
2. Rotate dials to the current combination
(if the lock is new, the combination is set
at the factory to 0-0-0-0)
3. Press down on the release button
to open the door
4. Pull the door fully open
5. Add or remove keys
6. Close compartment door
7. Scramble the combination dials to lock
the door and conceal your combination (A)
8. Close the shutter door (B)
To set a new combination:
The initial combination is set at the
factory to 0-0-0-0
1. Open the compartment door
(see instructions above)
2. Push the reset lever left and down.
The lever remains in this position
3. Rotate dials to your desired combination
4. Push the reset lever, up and right, back
to the original position
5. Close the key storage compartment door
6. Scramble the combination dials to lock
7. Close the shutter door (B)
To hang shackle model
2. Push the shackle release lever to the left
to open shackle
3. Pull the shackle up and out of the lock
4. Place shackle around door knob or other object
5. Close shackle to lock
6. Close the compartment door
Reminder:
(A) The release button will open the lock
until you scramble the dials
(B) Keep the shutter door closed to increase
weather resistance and to conceal the
dials from view
Mar 05, 2008 | Master Lock 5400d: Portable Select Access...
Extensis Suitcase X1 Logo
4,438 people viewed this question
Top Extensis Computers & Internet Experts
David Payne
David Payne
Are you an Extensis Computer and Internet Expert? Answer questions, earn points and help others
