Question about LG VX8300 Cellular Phone
Putting music on an LG Scoop.
I bought a mini sd card and a usb cable and I put a few songs on through Windows Media Player, but it's not showing all the songs, just like 30 out of at least a hundred. I have the space on the card. When I go on Media Player, it shows that the songs are on the device. Any suggestions?
  • 432 Answers
I believe these phones will only use a 512kb memory card. I could wrong. The phone directory may only hold 30 songs. There may be a limit on how many songs and how much memory the phone will hold.
Posted on Jan 14, 2009
I cannot download pictures from my LG Neon gt365 to my computer. What do I need to do? Do I need a USB? Do I need a micro SD? If so, what kind do I need? any help would be great!
You should be able to connect it using a usb cable that will need to be bought separately and a micro SD card installed in the phone. You should be able to buy any micro SD card up to 4GB. Also, if you buy a card with an SD adapter that will allow you to connect the SD card (with a memory card reader) to your computer without the additional usb cable. The manual link is attached:
Per the manual:
Transferring Music from the Digital Music Service 1. Using your computer, open your preferred PC music management client. 2. Download the selected song to your library. 3. Make sure the microSD™ card is inserted properly into the handset. 4. Use the USB adapter cable to connect the handset to the PC. When you try to connect handset on your PC, the handset displays "Call and Message functions will not be available while connected to USB". 5. Once the USB connection has been established, the handset displays "To avoid data corruption always carry out safe removal hardware on PC after use." and the computer screen then shows the LG NEON device. If the detection does not occur, skip to Changing USB Connection Settings section on page 63. 6. Follow the instruction in the program to transfer music to your handset. n Note If you have a USB hub, connect the handset directly to your computer rather than through the hub. Transferring Music using Windows Media Player 1. Open Windows Media® Player on your computer (version 10.0 or higher). 2. Use the USB adapter cable to connect the handset to the PC. When you try to connect handset on your PC, the handset displays "Call and Message functions will not be available while connected to USB". 3. Once the USB connection has been established, the handset displays "To avoid data corruption always carry out safe removal hardware on PC after use." and the computer screen then shows the LG NEON device.
Jul 23, 2011 | Cell Phones
Mp3 files don't appear in music player, i inserted a memory card with some mp3 files and they won't appear in the music player, i tried putting them in different directories on the card and still no luck....
-try to move all songs outside the directory using your pc then test.
if still not working,
-insert your sd card to your phone and reformat it not on pc,then remove it and start again uploading mp3 songs then test.
Dec 27, 2009 | LG Vu CU920 Cellular Phone
I can only load 75 songs.I have 2.0gb and a2.0gb card.I cannot format.I take the card out and I have one song in the player.With the sd card I get about 75 songs.Windows Media shows many songs synched but...
Delete each song manually and then folders from both the card and player there may be a boot file something Open music folder and click on tools folder options click view click on the circle show hidden and remove checks from hide and hide remember to undo these changes later go check the card and player manually delete anything....Then try and format a coupe of times....Drag and drop all of the music in to the music folder on the sansa and anywhere on the expansion card easier knowing what you are putting on the player.........
Aug 07, 2009 | SanDisk Sansa e260 MP3 Player
Missing songs?
1. Make sure all the songs are in mp3 formate.
2. Make sure the songs are not protected copywright.
3. Most of the songs once plugged into the device is pugged into the usb device you can drag and drop into the music folder
Jan 05, 2009 | RCA M4204 MP3 Player
Idk how to put music on my phone
Make sure your music is mp3,wma,aac,aac+,or eaac+ format.Insert the micro sd card into the slot underneath the sim card in the back of the phone.Turn on the phone and connect it to ur pc using a usb data cable once the portable device pops up on ur screen use the second option.From within windows media player songs will populate the left side of the screen.check drag songs to be transferred then click start sync when finished tap cancel on the phone then yes to exit music and disconnect the usb cable.
Dec 23, 2008 | LG Vu CU920 Cellular Phone
The songs should be stored in the compact able format of the phone ,check the manual of the phone and you will get the formats....and store the in the format you be able to play.........
May 19, 2008 | LG VX9800 Cellular Phone
Lg scoop
have the newest version of bitpim
make sure you have the drivers for the USB cable you are using.
open bitpim
let it find the phone(it will come up as other CDMA phone)
click FILESYSTEM on the left at the bottom
expand the folder
click dload
right click on lg_mysound.dat and save it to your desktop
after you save it right click lg_mysound.dat in bitpim and delete it
now click brew
click media
click lk
click ms
now drop the songs you want to use as ringers in this file. they will automaticlly load into your phone. it isnt the fastest process but it works.
after they are done loading onto the phone, unhook USB cable from computer, power the phone off and then back on.
the items you just transferred with now be in the my audio file where they need to be to assign them for individual ringers.
everytime you wnat to add new ringers to the phone you have to complete all the steps above, even the deleting that one certain file. not a very hard process and has worked well for me.
good luck and happy mp3 loading songs into the phone as ringers.
Mar 28, 2008 | LG VX8300 Cellular Phone
Put mp3 music on an at&t tilt
So on your Mini SD you need to make a folder named MUSIC. Then you just put ur music into it. After that place the card back into the phone. Next on the phone go into the start menu and into the Tools menu. On there press file explorer. From here you can view all files on the phone. From there go onto storage card and in there select music. That will show all the music files. To import the music into the WMP library go into Windows Media Player from your programs list. Once in WMP press men and then press update library. This process could take any where from 30 mins. to an hour. once that is done you got it working
Mar 23, 2008 | AT&T 8925 Tilt Smartphone
Sansa e250 using micro sd card
Go to the knowledge base on the Sansa site and find this (chances are you have an SDHC card in an incompatible unit):
Sansa e200
 - verify the version of the player.  To check, go to SETTINGS > INFO
For 01.xx.xx firmware (e200 version 1) - up to 2GB microSD cards
For 03.xx.xx firmware (e200 version 2) - up to 16GB microSDHC cards
NOTE: Firmware is not interchangeable.
Sansa e200R - up to 2GB microSD cards
Sansa e100 - supports SD cards up to 2GB
Nov 12, 2007 | SanDisk Sansa e250 MP3 Player
Lg k800
U have to follow this process.
Install Any USB drivers which are needed for your cable. Then connect your phone to the PC. Open Windows Media Player and click on the sync tab in Windows Media Player. Now on your phone hit MENU->Get It Now->Option 1 Music and Tones->6 Sync Music and the phone should show up under the devices in Windows Media Player. Now add the songs you want transfered to the sync side of Windows Media Player. Click Sync in Windows Media Player. and finally enjoy your music.
Oct 16, 2007 | LG KG800 Cellular Phone
LG VX8300 Cellular Phone Logo
94 people viewed this question
Top LG Cell Phones Experts
Computer Repairing
Computer Repairing
Raphael Josiah
Are you a LG Cell Phone Expert? Answer questions, earn points and help others
