I HAVE A JACCUZZI TUB THAT WON'T SHUT OFF ALSO THE AIR JETS AND THE THERMOMETER WON'T WORK EITHER.
  • 15,935 Answers
The timer is likely bad.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Posted on Sep 10, 2010
Why do jets turn on, then shut off?
the motor protection device is sensing to many amps. could be a flow restriction or the pump motor bearings are going bad.
Mar 06, 2016 | Jacuzzi Home
Mirolin jaccuzzi tubs
Air Switch Repair
It sounds like you have a bad air switch located in your motor.
The air switch is what the air hose connects to on the back of the motor or on the box on top of the motor. The other end of the air hose is connected to the air button on the lip of the tub.
This is a latching air switch and when you push the air button it latches to send power to the motor. When the air button is pushed again it opens the latch in the air switch and stops power going to the motor shutting it off.
US Parts Center
Jan 28, 2014 | Home
Mirolin jaccuzzi air tub
If your pump will not shut off then the Air Switch in the motor is most likely the problem with the pump not turning on.
Rod
US Parts Center
Dec 02, 2013 | Home
Air jets
is there voltage going to the motor?
Rod
US Parts Center
Jun 24, 2013 | Maax Calla 6042 Bathtub - 101058-000
Maax tub
Some air jet bubbler blowers are designed to run for 5 to 10 minutes after you drain the tub to push all of the water out of the air channels. It should shut off on its own once it senses all of the water has been blown out. If it continues to run much longer than that, then contact the mfg for a service call. You have a warranty if it is a recent purchase that should cover it. Hope this helps!
Sep 10, 2017 | Home
I have a Jacuzzi Z110 hot tub. the top control is broke (pn 51422). Can i use a digital top control PN 33334.
When dealing with a big manufacturer like Jaccuzzi, it is unwise to swap top side controls. They make theirs proprietary on purpose so that swapping is more difficult (especially jacuzzi).
If you use the wrong one, the buttons on the controls will be misleading (such as temp up button cycling jets, or the ozone button cycling the lights, etc)
I would use manufacturer part.
Oct 01, 2010 | Qca Spas Jewel Series Topaz Plus Hot Tub
Whirlpool tub, jets come on and won't shut off. No water in tub.
Is it a jetted tub, or a air bath tub with holes or jets in the floor? If it has holes or jets in the floor, the control box is bad and needs replaced. If it is a jetted tub, there may be a water level sensor, if so the sensor may be bad causing the tub to turn on.
Jun 13, 2009 | Whirlpool 5"x36" White Bathroom Drop-in ...
Jets are draining my jaccuzzi tub
Check to see if there is an open valve where the water exits the tub. If there is a valve, shut it and your problem should be solved. good luck
Jan 15, 2009 | Jacuzzi 8730-829 Bath Rotary Drain Kit,...
I have an american standard air tub and cannot get the air jets to shut off.  They turn off, but come back on automatically a short time later.  How do I shut the power off?
Check the air vacuum switch and line as you may have a air vacuum leak. The button that controls the on and off to the jets is an air vacuum switch....It may have a slow air leak in the line or connections that is activating the on and off control
Dec 16, 2008 | American Standard 2748.328 Town Square 5'...
Washing Machines Logo
52 people viewed this question
Top Washing Machines Experts
