Question about DISH Network IR Remote Control
My IR remote no longer works in another room
The remote used to work in several areas of the house. It works in the room with the receiver, but will not work from any other room. I ordered a new UHF/IR antenna and re-programmed the remote. I can't seem to get anything to work.
  • dawnwhite102 Jan 21, 2009
    I will try! Thanks.
    Dawn
  • 374 Answers
Dawn,
If you want a remote that works via IR to control the satellite receiver you will need a IR only. The IR/UHF type only transmits signals to the receiver by UHF and the IR portion only operates the peripherals in the room such as the TV and VCR. There are some remotes that come with a kit that can change the remote to work as an IR only. I believe you have a TV2 remote and want it to work further away from the receiver particularly the room the TV is in. If this is the case you may have have to change the remote address of the new remote to match that of the old. You can do this by taking the number one remote and pressing menu-menu. Now take the new remote and press and hold the SAT button in the upper left of the remote until all lights across the top light up. Now key in the two digit number on the tv screen at remote address for tv2. Then press the pound sign and the SAT button will flash three times then press the record button and the TV2 icon should flash. Now you can cancell out of the screen on tv one and try the remote at the TV2 location. I believe this will fix your issue if not let me know. Thanks for using Fix Ya.
Posted on Jan 16, 2009
  • Jim Franks Jan 28, 2009
    Dawn if your issue was not resolved you can move the UHF antenna to the TV2 location as depicted.
Have DVR 722K and want to change TV2 to remote IR however system will not allow. How do I get system to take this change?
Hello, my name is Tommy Faust with DISH Network. I would be happy to clarify this for you.
At this moment our second remotes only work via UHF. We're unable to change them to IR as that requires a direct line to the receiver which is usually in a different room/part of the house.
Hope this information helped you! Feel free to post here if you have any other questions.
Nov 28, 2010 | DISH Network IR Remote Control
Infared won't work unless room is brightly lit
Just to provide clarification regarding the IR remote control- unfortunately its the opposite. A brightly lit room can negatively affect the infrared signal the remote uses to transmit the signal from the remote to the receiver- additionally interference may also be caused by fluorescent lighting. Another recommendation regarding IR signal interference is to; power everything off but leave the receiver & your TV on. Then proceed by powering one component on at a time, then testing the remote after each component has successfully been turned on. This process will also help you determine if a component may be causing the interference. Hope this helps! -Kirstie DISH Network
Nov 01, 2010 | DISH Network IR Remote Control
I got Two TV's My TV Connected to remote 1 in IR mode. After trying to record some thing using dvr the remote dies on satellite cannot change channel... Tech team tries every thing send new remote and...
topscrew2002
From what you have written, when you try to record on your DVR the remote stops working, is that correct? How long has this been happening? Have you received a new remote? If yes and it is still happening, you are probably getting IR interference from some source in that room. It could be from a florescent lamp, another player, or even the TV. Is the receiver in a open space or in an enclosed area? The IR sensor has to have a direct line of sight to work properly. You may also check on the receiver if anything is obstructing the sensors, maybe dust. I hope this helps.
Ray Calo
DISH Network
Dec 02, 2009 | DISH Network IR Remote Control
Dish IR Remote 20.0 has problems after sunset.
The problem for me was the TV giving off IR signals that interfered with DISH's poorly designed remote. When the TV's room ambient light sensor was turned on and it became dusk outside the DISH remote would stop working. Moving the receiver away from the TV helps but the problem is not eliminated until the light sensor is turned off.
Until DISH corrects this poor design there may be no other viable solution.
Jul 09, 2009 | DISH Network IR Remote Control
DishNetwork IR Remote Control Problem
First the only way the 6.3 will work is if it has the green number 1 on the tab facing you. Assuming this is the case you will need a new remote. This primarily is the remote for the second room away from the receiver. Thanks for using Fix Ya.
Apr 15, 2009 | DISH Network IR Remote Control
The remote control will no longer work even when I put new batter
Sometimes the IR receiver bug in the tv goes out.
To clarify. The remote RM1 for TV 1 will not work on TV1, but the remote RM1 works on TV2.
If this is the case, answer is above.
Best Regards,
Charles
Jan 09, 2009 | TruTech PLV16190 Television
Yamaha RX-V663 delays 10-30 seconds between commands using the remote control. New batteries, new receive. For example, try to raise volume. It goes up 1 dB then cannot give any other commands using the...
I have seen this type of thing with several remotes.  You have some light source in the room that is interfering with the reception of the ir.  Turn off all light sources in the room and then try.  You might be surprised!
Dec 20, 2008 | Yamaha RX-V663 Receiver
Panasonic PV-8400 Remote sensor not working?
This is indeed a faulty IR sensor. If it's just the sensor, swap with your good one to check. From memory they are plug in - a little device behing d the smoked translucent facia (display panel). I have come across this several times with Panasonic VCRs. Check whether the remote works at night time with all fluorescent lights in the room switched off. If so, the IR filter circuitry is faulty. Same solution - replace IR sensor on VCR.
Jul 21, 2008 | Panasonic PV-8400 VHS VCR
IR frequency determination
The remote could be using RF, which is why your Niles equipment cannot handle it. There is no way to duplicate the RF or convert it to an IR signal.
If the remote is using IR, make sure the batteries are full and the light is low when you are learning the codes with tne Niles equpment. There is no way if it's IR that the freq is > 100.
Apr 22, 2008 | Televison & Video
IR Reliability--Intermittent
The Kenwood VR-510 does indeed respond to IR remotes. I now use a Logitech Harmony H659 which is IR only.
Your issue is a problem with the VR-510, actualy the whole series had a problem with cold solder joints on an assembly behind the front panel. Fix that and fix the problem. It frustrated me for 5 yrs.
Go here for the fix:
This site has the fix well documented: http://resnet.uoregon.edu/~gurney_j/kenwoodrepair/.
All is working great now!
Jun 08, 2007 | Kenwood VR-510 Receiver
DISH Network IR Remote Control Logo
446 people viewed this question
Top DISH Network Televison & Video Experts
S. Gontko
john milligan
Jaime Hernandez
Are you a DISH Network Televison and Video Expert? Answer questions, earn points and help others
