Question about Technics SL-1200MK2 Turntable
Want to change 60hz to 50hz help please
Bought spraygun 60hz. but want touse it at 50hz
3 Suggested Answers
SOURCE:
Benimur
  • 6966 Answers
SOURCE: Different HZs problem (from 60Hz to 50Hz)
Yes there are frequency converters available but most are relatively over rated (industrial) for your requirement such as MDS Power or VisiComm Industries. What you need is a Low Power Solid State Frequency Converters lower than a
Electrocon Frequency Converters. However, I expect this devices to be rather expensive.
A few other options you may want to consider:
1. Contact the store where you bought if from; swap with an International version (Model SL-1210 Mark II; same price as SL-1200 Mark II); dual voltage switchable on rear of unit: 120 volts/60 Hz (U.S.) or 220 volts/50 Hz (Europe). You hopefully just spend for the cost of shipping + a restocking fee;
2. Contact 3rd party Technics TT specialist like TopDJGear, Quality Electronics, Planet DJ or DJHardware
and inquire if they would supply you the part(s) that you need to convert the 1200 to a 1210; or
3. Offer a swap on eBay.
Hope this be of some idea/help. Pls post back how things turned out or should you need additional information.
Good luck and kind regards.
Posted on Nov 13, 2007
djproaudio
  • 515 Answers
SOURCE: 60hz to 50 hz
No need to worry about that. The direct drive on these turntables will adjust for hz setting automatically.
Posted on Feb 24, 2008
Can i use a 50hz 220V SPLIT TYPE AIRCON TO 60HZ 220V
you probably can but it will be damaged over time, you would need to replace the motor inside to handle 60hz using the 50hz can do damage to the motor, or even cause a fire. also if it has a power capacitor that asys 50hz on the power line to the unit inside this would been changing as well.
Jun 29, 2017 | Heating & Cooling
Is it possible to use this turntable from UK 220V 50Hz, in the US 110V 60Hz?
Go to Radio shack or other electronic places and buy the correct converter for it.
May 18, 2015 | Audio Players & Recorders
Have paint spraygun 60hz. want to use it in 50hz area. what can i do
Unfortunately, products are designed to work with specific voltages and frequencies. Some devices have broader ranges of voltages and frequencies because they use electronic power suppies (often called "switching power supplies") as opposed to the costlier, heavier transformer types. Nearly all devices that have motors or have a transformer will be designed to operate on either 50 or 60 hertz - not both. Use of these devices with a frequency other than what it is designed for will run too fast / too slow and will overheat to the point that it may become a fire hazard. Unlike voltages that can be easily stepped up or down with a transformer, there is no easy, inexpensive way to change frequency.
You should replace your "60Hz only" equipment with 50Hz or 50/60Hz equipment, or if a short term relocation, rent the correct 50Hz equipment instead.
I hope this helps & good luck!
Dec 13, 2012 | Garden
Can lg 50hz washing machine run on 60hz
yes but I will not good IDEA you will have phenomen transistory is electrical term in engineeering electric, you must get support via ONLINE chat or phone with LG.
you must transform the 60hz to 50hz or 50hz TO 60hz.
God bless you
Sep 30, 2012 | LG WM-1832C Front Load Washer
Bought a singer from the state but cannot be used in australia what should i do?
If it is an electronic or computerized machine, you are out of luck. USA has 110 volt 60Hz current, Australia has 220 volt 50Hz. A transformer can change 220 to 110 volts, but it cannot change 60Hz to 50Hz.
Sep 21, 2011 | Singer 4423 Sewing Machine
Can I use my EuroPro 416 Sewing machine with 220V electricity?
A transformer will not change the frequency of the supply, only the voltage.
It may be possible to obtain a box of electronics to convert 50Hz to 60Hz, which would solve the problem.
A machine designed to run on 60Hz will run slower on 50Hz and may run hotter. If it burns out due to overheating, then a new motor designed to run at 50Hz should be fitted. You could have peace of mind if you fitted a new motor (which might be cheaper than an electronic frequency converter.
Jul 25, 2010 | Euro-Pro Sewing Machines
Just bought a Maytag MDB8959AWB Dishwasher (120v 60Hz) and installed it in Jamaica (115v 50Hz)but it does not work. We changed the control board but nothing, no lights or response. I also have two friends...
Hey i am sorry i got disconnected could you please reconnect to the chat room or just post me and i will give you the solution there \
best regards mike
Jan 23, 2010 | Dishwashers
Covert 230V 50Hz to 230V 60Hz
To convert to 50Hz will be expensive as the Aircon needs alot of startup power. You could ask maker if 50Hz will be ok, usually motor will run slower so unit will be less efficient, alway check with maker. Or try supplier to see if they will exchange for what you ordered first.
Dec 18, 2008 | Liebert UPStation GXT2700RT-208...
I have magnavox TV
you will need an adapter for it....
its the current frequesncy what he told you.. in US they use current of 60hz frequecny....
the place you live in use 50hz.. that is the reason...
see this link...it wil help you surely..
50hz to 60hz - For: 1.Use overseas to test products destined for use in the US or other 60Hz countries;
2. To operate 60hz machinery from a 50hz utility.
Jan 19, 2008 | Philips Magnavox 51MP392H Rear Projection...
Open Questions:
See all Technics SL-1200MK2 Turntable Questions
Technics SL-1200MK2 Turntable Logo
64 people viewed this question
Top Technics Audio Players & Recorders Experts
 Grubhead
Grubhead
Ben Armstrong
Are you a Technics Audio Player and Recorder Expert? Answer questions, earn points and help others
