Question about Minolta CF1501 Copier
Background Color Everytime I print in color the background color comes out in yellow everything else is in perfect color. When I print in black and white everything comes out correct.
  • 3 Answers
Clean the LED's.
Posted on Dec 22, 2009
  • 4 Answers
1) In the Applications Menu on your copy screen there should be a option to turn on or off a background color fill. Turn it off and try. If it still comes out try hitting panel reset. If this doesnt work. 2) You have a bad Image Unit. Change the yellow image unit. 3) You may also have a bad write unit. Pull out the four write units and check the yellow write unit. It may have gone bad in which case it needs to be replaced.
Posted on Aug 26, 2007
Color printing is printed with a yellow background in bizhub c450
have you replace the Transfer belt.??? It also has a transfer roller for yellow. (Called First Transfer) since it is transferring yellow off the drum. You have replaced the yellow image unit???? 2nd transfer is to the paper!!!
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
May 18, 2016 | Konica Minolta bizhub C450P Laser Printer
I have one problem with hp laserjet P4014n printing all paper black. the background is black all but word are showing can someone help me in this
If your background is "Black" it's going to print it all black, change your background color to "Gray" and your machine will then print a gray background instead of black. Also note that when you print a black background your toner life expectancy will be no where your expected yield ratio is. Average yield is 5% for X (X meaning size of cartridge) amount of printed pages. If your printing a black background your utilizing 100% yield coverage. Not sure if this is the answer your looking for. However basic black and white printing with a black background will print the page completely black.
Mar 01, 2011 | Office Equipment & Supplies
Phaser 7300 dn prints full yellow color background on every page even if the background copy shows no color.
Most likely the yellow drum unit is causing that problem. The charge roller gets worn and makes whatever color it is in print out all the time. That would require replacing the yellow imaging unit.
Feb 20, 2010 | Xerox Phaser 7300DN Laser Printer
Printouts have a solid yellow background
If you look at the transfer belt, it will probly have yellow all over it. More than likely, by have a bad yellow toner.
Mar 06, 2009 | HP Color LaserJet 2550n printer + HP Color...
Hp c 1515n printer
Replace the Magenta Toner Cartridge
If you have a problem with a color replace that color toner.
Sep 22, 2008 | HP Color LaserJet 2600n Printer
How do I reset the ink levels?
Well, theres the problem. Most printers can remember up to three cartridges. That includes color & black. The best way to put it is that each cartridge has a"funger print" that the printer can read, and estimated ink levels can be gaged. There is a way to "reset" the cartridges, but i do not have the document on me. Please email steve@nicesites.org and I'll send it today. I'm not saying it will work 100%, as the reset method is geared for the 56/57/58, but who knows right?
Jun 19, 2007 | HP Photosmart C5180 All-In-One InkJet...
Yellow on all color printings
What photo program do you use? Is the yellow background on all Word doc's? You should check WORD go to the Format|Background make sure "no fill" is selected. You should also check your print properties in control panel and any special program DELL uses. Make sure there isn't some custom setting that is printing the yellow background. Let me know what happens. Good Luck, Tim
Feb 18, 2007 | Dell 962 Photo All-In-One InkJet Printer
341 people viewed this question
Top Minolta Office Equipment & Supplies Experts
Adorjani Laszlo
Norman  J Weimar Jr
Norman J Weimar Jr
Marvin
Marvin
Are you a Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
