Question about HP - HP Photosmart 8250 printer
Error Code on Printer Screen C2FE0100
C2FE0100 is on a blue screen on the printer. The computer says it doesn't recognize the usb device.
The Machine
  • 788 Answers
SOURCE: ricoh error code sc291
There's a list of Ricoh error codes right here: http://www.tecnodigitale.com/riparazioni/pdf/Codici_errore_Ricoh.pdf but it doesn't indicate an sc291 for the 3800 or for any other model for that matter.
There are usually contacts on the cartridge that interface with a reader in the printer to detect the chip in the cartridge. Examine a cartridge and look for any electrical contacts, make sure they don't look damaged or dirty clean them with 98% isopropyl alcohol. With the printer powered off and upplugged, try to find the corresponding contacts inside the printer for each of the contacts on the cartridge, clean those too.
If that doesn't change, try a different cyan cartridge, if that still doesn't work you will probably have to get the machine serviced.
Posted on Jan 14, 2008
Ajkill
  • 2035 Answers
SOURCE: hp laserjet 1020 ( usb device not recognized )!?
I wish that there was a simple, single answer for this. There's only one thing more distressing - no device recognition at all. Here are the most likely culprits:
* The USB device or the USB adapter requires it's own power source. If your USB device or adapter came with an AC power "brick", try connecting it.
* Here's a likely one - the front USB ports on your PC case may be misconnected. I've seen them that way from the factory. It's a good idea to check the connections against specifications. The standard order of connection is Red, White, Green, Black. No more than 4 wires per USB bank are needed.
* Defective device. Do not assume that all PC components work correctly out of the box. I've seen many new USB devices that do not work. If you can, try the device on another PC.
* All drivers are not installed. Some devices will require installing the driver package before plugging in the device. Some devices will also require basic USB files from the Windows CD before the unit will function. The general rule is to always follow installation directions precisely and to have the Windows CD ready.
I will now discuss how to address an unknown device problem which is caused by a driver deficiency.
1. Try to update the unknown device driver from within Device Manager. First try letting Windows search for one. If that fails, go back and choose "Select from a list" and then "Have disk". Browse to the device CD and look for the appropriate Windows folder there. Try browsing to the Windows CD (Win9x folder or i386 folder). Lastly, try updated drivers from the manufacturer's web site.
2. Try uninstalling the unknown device, unplugging the device and rebooting. Replug when back in Windows.
3. Be certain that you have the correct drivers! You may have gotten the wrong CD or a CD with drivers for more than one device on it.
4. Cleaning up in Safe Mode may be necessary. Unplug all USB devices. Reboot the PC. To enter Safe Mode, press the F8 key repeatedly while restarting the PC. Timing is important. Try to press quickly before the Windows logo screen appears. Pressing and holding the CTRL key may work too. Choose Safe Mode and open Device Manager. In Windows 2000 and XP, click View > Show hidden devices. Now locate all USB devices, HID (Human Interface Devices), USB drives and controllers/hubs. Remove all and save the USB Host Controllers for last. When done, restart and replug USB devices one at a time.
Just remember that you are entitled to support from the device maker. If you can't get help, do not hesitate to return the device. Some manufacturers only seem to respond to lost business. It's a shame, but it's true. Send them a message - that you won't accept shoddy goods or lackluster support.
Posted on Mar 26, 2008
iqbal_del
  • 655 Answers
SOURCE: USB port problems with hp printer
There are few things to remember using USB.
  • If your System is in hybernation mode, don't remove any attached USB device, because it will damage your USB driver. This is one of the known problem from microsoft.
  • If you have to remove any USB device use 'Safely Remove Hardware'.
To remove currepted USB drivers its not enough to remove your printer drivers.
  1. You should un-install the 'Universal Serial Bus Controllers' from Device Manager.
  2. Then re-boot to clean registry.
  3. Install the 'Universal Serial Bus Controllers' using XP Setup CD.
  4. Then check the Mass storage, PDA etc, it should recognized by XP.
  5. Then install printer driver (don't attach printer to system untill setup finish or setup says to connect).
I think it will fix.
Please let me know your feed-back.
Thanks
Iqbal
Posted on Apr 15, 2008
Tualiapz
  • 80 Answers
SOURCE: C2FE0100 Error
Please check the link to HP support for you issue on your printer. The error fix is for "Turn power off, then on again" displaying on the control panel.
Please take the time to go through the troubleshooting steps.
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01369982&cc=uk&lc=en&dlc=en&product=1153494
Please rate if this help to fix your issue
Posted on May 30, 2009
SOURCE: USB recognition problem
i also encountered that problem , all you have to do is to replace your usb wire...the defect is in the usb.
Posted on Jun 20, 2009
My computer won't recognise my USB cable (code 43 error)
Its maybe the printer is not compatible with your computer, will to try several steps to determine a solution,
1 try another USB to see if it recognizes it,
2 download and install the driver from the printer manufacturer
3 try another USB device into the same USB port to see if it recognizes it if it does then the USB on your computer works as it should,
if it does then the fault is either software or the printer compatibility.
4 follow step 2 if the problem persist then the answer is your printer is not compatible and will need to order one that works for your system.
Kronoguy
Aug 18, 2012 | Computers & Internet
Canon MP 600 printer is dead
Unplug the printer.
Restore power.
Hold down the power button for an unreasonably long time until it boots into maintenance mode.
Follow the prompts.
If nothing comes up call Canon.
Aug 16, 2017 | Canon PIXMA MP600 all-In-One InkJet...
Hi, my lex1270 scanner is not working. printer and copy is fine. when i want to scan i get an error code!!! please help.
What is the error code displayed on the screen?
A quick fix for most communication errors can be achieved by resetting the printer and/or rebooting the PC.
If that doesn't help, try the steps below:
1. Disconnect the printer from your computer.
2. Unplug and re-plug the printer into the power source to reset it.
2. On your computer, go to Control Panel > Printers and Faxes.
3. Delete the Lexmark print object.
4. Reboot your pc.
5. When your pc turns on, reconnect the printer.
6. Wait until your pc fully recognizes the USB connection. To check, go to Control Panel > Printers and Faxes. If you see a new Lexmark print object in the list again, then try to print again.
You may also try to update your printer driver by visiting the Lexmark website at http://bit.ly/aKlcOJ. Select your operating system, download and execute the file.
If the problem continues, please contact Lexmark Technical Support Center for additional assistance.
Aug 16, 2011 | Lexmark X1270 All-In-One InkJet Printer
Tried to fix a paper jam and now I get this code C2FE0100 and the printer won't print. Unplugged it and still nothing
Found this link to reset an HP Printer:
http://www.out-of-warranty.com/how-to-reset-hewlett-packard-hp-all-in-one-printers/
Good Luck!
Mar 01, 2011 | Office Equipment & Supplies
HP Premium C309 All-in-One Printer error message "C2FE0065"
I had a similar error (not the same! C2FE0100), and cleared it up with the following procedure:
1) While the HP logo was displayed on the screen, I unplugged the printer. 2) Plug the printer back in. 3) Immediately open the printer so you can see the ink cartridges. 4) Press the power button at least once. If yours is like mine, you see the error just by plugging in the printer, but it takes a minute or so. Pressing the power button for me just caused it to restart the boot sequence where I could get the error again. 5) Wait a couple of minutes. You should see the ink cartridge carrier move back and forth several times, and the screen will display a message telling you the ink access door is open (or similar). 6) I let it move the ink cartridges around for several minutes, but this probably isn't necessary. 7) Close the printer back up. 8) About a minute after closing the printer, it told me that I shouldn't turn it off by unplugging it, and that I should use the power button. 9) I pressed the power button once, and it shutdown. 10) I pressed the power button once, and this time it turned on without any error messages.
I was able to print a photo via bluetooth from my phone, and a short document from my computer, so it seems to be working OK.
Jan 08, 2010 | HP Photosmart Premium C309A All-In-One...
USB device not recognized
SOLUTIONS:
  1. Unplug the USB device. It is possible that the connection is not secure and has become loose. This is one of the most common reasons for an error in detecting a USB device.
  2. Use the Device Manager to scan for new and recently installed hardware. From the start menu, select the 'Run' option. In the pop up box, type in Devmgmt.msc and then click 'Ok'. From the 'Action' Mmnu, click 'scan for hardware changes'. This will make Windows recognize any new devices that are installed. Now, close all device managers and control panels. Now see if your computer will read the USB device.
If the above two doesnt work, then try the following,
Disable power management of the USB hub. To disable the power management,
1.Click Start, and then click Run
2.Type devmgmt.msc in the Open box, and then click OK.
3.Expand the Universal Serial Bus controllers' node, and then follow these steps for each USB Root Hub that is listed:
4.Right-click the USB Root Hub and then click Properties.
5. Click the Power Management tab.
6. Click to clear the Allow the computer to turn off this device to save power check box, and then click OK.
PS: If you perform the following procedure on a laptop computer, you may reduce the battery life.
Jun 03, 2009 | Samsung CLP-315W Laser Color Printer
My printer won't print any document
Try installing the software from the cd which came with the printer.
Apr 26, 2009 | HP PSC 2175 All-In-One InkJet Printer
Having trouble installing HP Photosmart All in One Printer. Model C5280. Near the end of installation it ask's for printer to be connected via USB cable. Msg comes up on screen 'USB Device not recognized'...
Dear Sir:
It seems that the printer has gone bad because when you get this message 'USB Device not recognized' it means that the usb device connected to the computer is defective however I would suggest you to connect this device to another computer and if you are getting the same error with the other computer.
Please contact hp support they should be able to help you with this.
Please feel free to get back to me If you need any further assistance.
Regards
Mohammed.
Mohammed.feroz.ali@gmail.com
Jul 19, 2008 | HP Computers & Internet
Windows XP: Blue Screen of Death
Hi are you connecting the usb devices b4 or after windows has started? what version of windows r u running?
Do the usb devices come with their own driversand software?
Dec 18, 2007 | Dell INSPIRON 6000 CENTRINO...
486 people viewed this question
Ben Johnson
