Question about Sharp Aquos LC-46D62U 46 in. LCD HDTV
Picture not HD quality while watching HD channels
Just purchased my Sharp Aquos 46" LCD and had my DirecTV satellite upgraded to HD and the HD channels are as crisp as I expected.
    Problem Solver:
  • 6 Answers
Make sure you are using an HDMI video cable for optimal picture quality. Also, you must be using an HD reciever.
Posted on Jun 13, 2007
Sharp aquos dolby digital tv has sound but no picture
go to source on your remote then click down to the second one like HD ONE.
Feb 21, 2015 | Sharp AQUOS LC-32D44U 32 in. LCD TV
How can i adjustment my picture quality sharp aqu40d78un to get rip of the fuzzy look?
Your Sharp Aquos 40D78UN is a 1080P HD display, and will provide razor sharp, vibrant images if provided with an HD signal.
HD signals (those that are 720P, 1080i and 1080P) are only available from the following sources:
1) Local "off air" (antenna) HD broadcasters (providing HD content) delivered via the coaxial antenna terminals.
2) An HD source such as a stand alone Blu Ray (BD) Disk player, PlayStation 3 optical (BD) disk, HD service provided by DirecTV, Disk Network, Local CATV provider or other satellite service delievered to the TV via any of the (3) HDMI jacks or (2) Component RCA jacks (RGB). Satellite and CATV providers offer both SD and HD service. You must have HD service to watch programs in the higher quality HD format.
3) Computer signals delivered via the PC (VGA 15 pin) jack - such as movies or video in HD or Netflix HD.
It is important to note that any signal source (regardless if 720 or even 1080) that is delivered to the TV via either of the (2) "A/V" RCA jacks, will be limited to SD or 480i resolutions.
An HD picture is only possible when the source is HD, it is brought to the display over HD cables to HD capable jacks on the TV and, the display is capable of at least 720P. If any one of these variables is missing or substituted, the picture quality will be reduced significantly.
CNet has a helpful review and discussed HD signals. it is only a couple pages in length and may help you understand even better. I hope this helps and good luck! Please rate my reply - thank you.
Feb 25, 2011 | Sharp Televison & Video
I have a 1080 with 120 and my picture is not clear. If it's not a hd channel it really is terrible and if it is hd channel it still is not in full focus. The picture is not sharp. I am really disappointed...
I am assuming your set is new. Ask for it to be serviced under warranty. This sounds like your set is defective for some reason.
LCD TV sets are known for their exceptional sharpness and performance when having a good quality signal source, and especially with an HD programs.
Jerry G.
Nov 14, 2009 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
32 inch Sharp Aquos is less than a year old... I changed that channel and the picture was green or gray... i changed it again and got a normal picture once but now all channels are looking blank with a...
Contact Sharp to locate the nearest authorized Sharp servicer. Sharp Aquos servicers have to give Aquos TV top priority. Sharp provides very good and fast serice on these sets.
Apr 26, 2009 | Sharp Aquos LC-46D62U 46 in. LCD HDTV
View mode incorrect after connecting to pc
hi my name is mark, i own an aquos, the side bar are normal. not all programming is broadcast in wide screen. if you watch during primetime you will see the bars come and go depending on if the program was taped in 16:9 or 4:3 format. you will see it on commericals also. thanks for your question.
Mar 17, 2009 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
New Sharp Aquos LCD 46 TV
If you hooked up the satelite box to your tv Automaticly the Satelite box is the one who pick up the channels (from the satelite)
In this case your tv is acting as a monitor only. Try to connect your tv with HDMI cable or COMPONENT cable for best picture. Don't use RF antenna input to hook up your Satelite Box. Hope this Helps
J
Dec 28, 2008 | Sharp AQUOS 52" Flat-Panel LCD HDTV
Have tv plugged in on hdmi cable but picture only showing in 480i how do i change to 1080p
You need to verify that you have hd service with your tv provider first. Then, you need to find out which of your channels are being broadcasted in HD because not all of them will be in HD. HD cable and satellite is not capable of broadcasting in true 1080p. Some of them have on demand services that stream 1080p movies, but thats about it. Channels can only go up to 1080i(which is still beautiful hd). Make sure your HDMI cable is version 1.3 and you should be good...good luck 2u
Dec 12, 2008 | Sharp Aquos LC-46D62U 46 in. LCD HDTV
Sharp Aquos Audio Intermittent
This is a problem with the ATSC channel's reception. Usually switching to another channel and back solves the problem.
Jul 28, 2008 | Sharp Aquos LC-46D62U 46 in. LCD HDTV
LCDTV - Picture problem
Do the lines only appear on the Cable box input? It maybe be a problem with your cable. Try to isolate the problem.
Do you see the lines on all sources such as your DVD player as well? If you press the MENU button on the Sharp remote, do the lines go through the menu as well? If yes, it is most likely a TV problem.
A bunch of lines sounds like it is most likely a problem with the connection with the LVDS cable, if not that, then a defective main board.
There isn't really much you can do about it now.
Since the TV is less than a year old, I suggest calling Sharp to locate a local authorized service center.
Mar 18, 2008 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
Picture quality
I think you are right about the backlight. You need to replace the backlight tube or, if you can, replace the TV. Good Luck.
Sep 13, 2007 | Sharp Aquos LC-32G4U 32 in. HD-Ready LCD...
Sharp Aquos LC-46D62U 46 in. LCD HDTV Logo
213 people viewed this question
Top Sharp Televison & Video Experts
Jaime Hernandez
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
