Question about Electrolux 24 in. EDW5505EPS Stainless Steel Built-in Dishwasher
Electrolux DX302 Dishwasher power button wont stay on
I have an Electrolux DX302 and it has been playing up with the button not staying on. The dishwasher does work if I hold the button down for the entire wash.
I rang Electrolux and have ordered a new switch....
Posted on Jan 14, 2009
Hello - I have an Electrolux Dishlex DX302 dishwasher. The washer works okay - but it doesn't always empty the contents of the dishwashing powder in to the dishwasher. It is often wet and stuck in the
If you have hard water, you should reduce the amount of detergent you use. Here's a map showing water hardness in the USA. http://www.citriclean.net/why-citriclean/
Nov 23, 2013 | Dishwashers
What does the error code 50 relate to for our electrolux dishlex DX302 dishwasher?
Thanks for this information. I was able to follow triburi's instruction and just make sure all the electrical connector is connect properly. It works after i put it all back. I guess i am just lucky one of the connection come lose.
Jun 19, 2011 | Electrolux Dishwashers
Electrolux dishwasher DX302 isn't drying the dishes. What might be wrong?
Check your heating element..
A bad heating element causes many problems in dishwashers…
Dishwasher Problems The Heating Element not Working
Dishwasher Maintenance
heatman101
Asker's Testimonial " explanation very clear. will give it a go and see how simple it was. thanks Ronnie " - ronnieshomes
Aug 27, 2010 | Dishwashers
Electrolux ewdw6505gs model dishwasher commd panel does not power
Read publication 5995509477 of Electrolux name factory Parts Catalog. You will see the POS NO 12 Part no 7154671401 name Latch Assembly, door w/shield. This relay stay open. a little bit of WD-40 and he working correctly.
Apr 22, 2010 | Electrolux EWDW6505GS Fully Integrated...
User manual for electrolux dishlex DX302
Go to http://www.dishlex.com.au/SupportCentre and then search by the model description DX302WB. I downloaded a pdf file no problem.
Nov 12, 2009 | Electrolux Dishwashers
My DX302 dishwasher wont heat the water, the heating element is ok.
Yes I had the same problem with the DX302. One of the solder joints on the relay was cracked but hardly visable. Resoldered it and no problems.
How to do it:
Make sure you turn off the power at the wall and pull out the plug. To get to the circuit board remove the screws on the inside top of the door and pull out the front panel (where the buttons are). Press the little clips and the white box containing the circuit board comes free. Remove all the plugs and lever open the small clips holding the box shut. After you open the box pull the circuit board up and have a look at the contacts under the black little box (relay). Use a soldering iron and some flux cored solder and redo the joints. Put it all back together and turn on to see how it goes.
Worked for me.
All the best......
Jun 22, 2009 | Electrolux 24 in. EDW5505EPS Stainless...
I need a user manual for my Electrolux dishwasher Model DX302
Call Electrolux @ 877-435-3287
Make sure you have your model/ serial # handy
Lou
AFFORDABLE APPLIANCE REPAIR
(949) 855-0788
Jun 20, 2009 | Electrolux Dishwashers
Electrolux dishwasher all lights blinking and wont turn on push start button either all lights flash or normal light stays onĀ  either case the dishwasher wont run a cycle
Remove the toe kick by loosening 2 screws. There is a panel there with little lights that correspond to specific problems. The light that is on will correspond to the problem that the dishwasher has detected. Correct the problem and you should be good to go. I have no idea why this is not in the instruction manual. A common one is that there us a leak that the dishwasher has detected, normally in the drain pipe.
Apr 23, 2009 | Electrolux 24 in. EDW5500DSS Stainless...
Electrolux 24 in. EDW5505EPS Stainless Steel Built-in Dishwasher Logo
1,217 people viewed this question
Top Electrolux Dishwashers Experts
Mike
Starnley Johnwells
Starnley Johnwells
Are you an Electrolux Dishwasher Expert? Answer questions, earn points and help others
