Question about Dishwashers
Frigidaire MDB122LBS1 water not circulating
A few months after moving in to our home, the dishwasher began taking all of the food soil from the dishes on the bottom rack and depositing it in/on the dishes on the top rack. I started by checking the rotation of the top arm (mark position, run for a few seconds, check for movement) and confirmed that it was not rotating. I took apart the upper and lower arms and found no major clogs/debris in them. I cleaned out the drain/trap area and found a few coin sized pieces of glas, but again, no major clogs. I can't really get the washer out of the cabinets due to an over-ambitious remodel by a previous owner that laid subfloor over the front feet, and permanently attached the countertop to the cabinets. I'm not ready to replace the surrounding cabinets until after the spring thaw, but I would like to try and further troubleshoot the problem in-place.
If I am able to get the pump out, how would I go about testing it?
Thanks in advance!
4 Suggested Answers
  • 14 Answers
SOURCE: upper arm does not spray
Dig deeper, until you find filters. Those are probably clogged. You may need a screwdriver...
Posted on Dec 29, 2007
SOURCE: my maytag mdb8600aws jet clean 2 only cleans dishes in bottom
The seals that the racks "plug" into need replaced. Ours had the same issue and replaced the seals and it works fine now.
Posted on Dec 21, 2009
heatman101
  • 43501 Answers
SOURCE: Whirlpool Gold Dishwasher - GU2700XTSB The
I have an older dishwasher also and recently my wife also complained about it not cleaning right... so me being the man I am tried in vain to clean the things... Bought new spray arms online and installed them in minutes...now the thing works like new... However I have also found that if the heating element goes bad then that also can mess things up bad... So I would buy new spray arms, and also check out the heating element to make sure it is working... Here is a tip that will help you with the online buying...
Dishwasher
Spray Arms not Spinning
How to Buy
Appliance Parts Online
A bad heating element causes many problems in dishwashers...
Dishwasher Problems The
Heating Element not Working
Dishwasher Maintenance
Dishwasher Residue and Film on Dishes
heatman101
Posted on Feb 20, 2011
Will not rinse well
Is the dishwasher leaving them soapy or dirty with food due to the no rinsing? If the problem is still dirty with food you can try some of the following tips.
Choose a cycle with longer washing time.
Avoid nesting items on top of each other or layering them too close together.
The home water pressure may be too low; it should be between 20-120 psi (pounds per square inch) which should be checked by a plumber.
The incoming water temperature should be at least 120F at the sink closest to the dishwasher before starting a wash cycle.
For heavy food soils always select HI-TEMP WASH option if available.
Check for water hardness. Water hardness can be determined by the local water supply company, water treatment company or via a water hardness test kit, which can be found at local part distributors or hardware stores. In areas where the water hardness is 12 grains or higher, some kind of water softening is recommended. For very hard water a home water softening system would be recommended.
Always use fresh detergent, the older the detergent (About one year) the less effective it is at cleaning dishes
Jan 19, 2014 | Frigidaire FTF2140E King-Size ENERGY STAR
Fridgedaire dishwasher will not start a cycle. The green "clean: light stays lighted up and it will not reset the system. I have to turn off the breaker and then turn it back on. then the...
Hello
Ensure the Frigidaire dishwashing machine is fully connected to a power supply. Shut the dishwasher door firmly and select a wash cycle. Press "Start" to begin. Check that the "delay start" option was not selected.
  • 2 Verify that dishwashing detergent is placed in the dispenser and choose a longer washing cycle for heavily soiled items. Do not overload the dishwasher, as this may prevent proper cleaning.
  • 3 Check the household water pressure, which should be between 20 and 120 PSI (pounds per square inch). A water pressure gauge can be obtained at most home repair stores or hardware stores.
  • 4 Turn on the hot water at the sink closest to the dishwasher prior to starting the dishwasher to raise the water temperature inside the dishwasher. Check the hot water temperature, which should be at least 120 degrees Fahrenheit for proper cleaning.
  • 5 Check the spray arms in the dishwasher and move dishes that may be blocking the water spray or preventing the spray arms from rotating properly.
  • Read more: Frigidaire Dishwasher Wash Cycle is Not Working ' eHow.com http://www.ehow.com/how_7877923_frigidaire-wash-cycle-not-working.html#ixzz1Xow3qbbv
    Sep 13, 2011 | Dishwashers
    Glasses and frying pans not clean at end of cycle. Residue on glasses and cups,food particles on frying pans.
    it's generally not a good idea to put really greasy items in a dishwasher along with relatively clean items such as glassware and plates and cutlery, as most recent good quality dishwashers come with a soil sensor that ends the wash cycle once the dishes appear clean, and all the grease from your frying pan will cause the soil sensor to take longer to detect clean water.
    Jun 29, 2011 | Dishwashers
    Dishes not cleaning
    Are the dishes wet? If they are then maybe the dishwasher was over loaded and the spray jets were not able to wash the dishes. Check the jets to make sure they are not obstructed. If nothing else then the pump is not circulating the water to wash the dishes. Good Luck
    Jan 08, 2011 | Hotpoint Dishwashers
    Crud & crumbs left on dishes
    Most dishwashers have a soil separator which separates the soil from the water while it's washing. When a wash cycle is over a valve opens in the separator to allow the soil to go down the drain. If it's not working properly the washer will leave a film or food particles on the dishes.
    Here are your diagrams and parts. I noticed a filter and trap which could be your problem. Make sure the water is spraying out the spray arms good.
    http://www.appliancepartspros.com/partsearch/model.aspx?model_id=20680&diagram_id=676283#d676283
    Apr 23, 2010 | Amana 24 in. DWA22A Built-in Dishwasher
    Dishes and glasses are not coming out clean even inside of dishwasher has some residue left on it after washing
    Post your model number and I'll try to find a diagram which shows you your parts.
    Apr 19, 2010 | Kenmore 15121 Built-in Dishwasher
    Whirlpool Built-in dishwasher Model DU8700XB -O
    It's under the lower spray arm. Post your model number and I may can find a diagram for you. Dishwasher- Inside the doorjamb on the top, left or right. On the door edge top left or right. Portable models on the back.
    Mar 22, 2010 | Dishwashers
    I have a frigidaire quiet clean I.Water will flow in the washer and it will pump it out at the end of the cycle.It doesn`t circulate the water thru the spinner assemblies to wash the dishes.The soap will...
    the spray arm may be blocked see when door is open that it can spin and is any thing blocking the spray arm ,check if any food particles is in spray arm or tower check these areas out first write back if this dosnt work out.thanks
    Dec 02, 2009 | Frigidaire Dishwashers
    Dishwasher leaving debri and food partical on dishes. the top arm seams to be not moving but water is getting threw.
    top arms are normally free-wheeling, depending on water pressure from beneath to operate and distribute the rinse water. Is it possible you have dishes or utensils being placed in the top rack which would prohibit the arm from turning?
    Nov 27, 2009 | Frigidaire Dishwashers
    Water is not circulating. machine runs full cycle but when opened, soap is in a mushy lump, not dispersed or dissolve, and dishes are still soiled
    When was the last time you cleaned you drain filter? That should be done routinely .. If that's clogged then the the sediment from other cycles just gets redistributed on your dishes.. You might also check the washing arm that spins for debris or clogs.. Try cycling it without any dishes a few times to see if all the water drains out after a cycle.. That will help you identify if its a drain problem or if the system needs other service.. Hope that helps !
    Aug 18, 2008 | Frigidaire Dishwashers
    Dishwashers Logo
    90 people viewed this question
    Top Dishwashers Experts
