Question about Whirlpool GEW9250 Electric Dryer
Whirlpool duet dryer lock is loose
Whirlpool dryer lock loose, it works, but when clothes hi the door it goes off, you ahve to go back and start it2 or 3 times per load.
    New Friend:
  • 88 Answers
You have to change the plastic catches there are 2 one on the top and one on the bottow of the door
Posted on Jan 14, 2009
Clothes dryer overheating?
use your dryer on air dry only (not heat dry) run about 2 min. check if your dryer is hot, that is heating element is short to ground and if your dryer is cold, check your dryer air venting system. (open the door if you see lint on door panel, it is a sing of bad air flow, it is dangerous to fire) hope its help.
Jul 10, 2014 | Whirlpool Dryers
I ahve a duet gas dryer and it will not get hot
Now did this happen all at once or did it slowly dry clothes slower and slower and then just quit? If it happened slowlt it is because you have some sort of ventalation blockage withing the dryer itself or in the wall of your home. When this happens it will the blow the thermal cut off and this will need to be replaced. If it happened over night then it could be the heating element or the thermal cut off & thermostat. All these can be checked with a volt meter using the setting for continuity.
Mar 26, 2010 | Whirlpool Duet 7.0 Cu. Ft. 7-Cycle Super...
Brand new Duet Dryer - WED9400SZ model - just installed and connected - everything looks good. BUT, it won't start. All I hear is a beep sound? any setting to be turned on?
Make sure that the door is firmly closed and the light inside the drum goes out. I have model YWED9400SW (brand new) that had the same problem. The spring lock on the top was not fully engaging. Press firmly on the top and bottom of the door until the light goes out then press start. Good luck.
Jan 03, 2010 | Whirlpool Duet 7.0 Cu. Ft. Capacity Plus...
Whirlpool washer doesn't unlock the door at the
Hi There
I have found this for you to read. it's door unlock error. Hope this helpful and let me know how it goes.
F/dU Door Unlock Error
A Door Unlock Error occurs if the door cannot be unlocked. It will try to unlock the door 6 times before displaying the error.
  • Door Lock Mechanism broken.
  • Check Door Lock/Switch Assembly for foreign objects
  • Check Wire Harness connections to the Door Lock/Switch Assembly and Central Control Unit (CCU)
  • Door Lock/Switch Assembly Failure
Thank you for writing to fix ya.
Best Regards Richard
Dec 29, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool duet dryer won't start
whirlpool duet dryer has power but will not start--when I press start, it beeps once and the sensing light comes but the dryer doesn't start
Nov 02, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Activate the diagnostic test mode.
1. Within 5 seconds, press more time-less time-more time-less time.
2. All indicators should now be on and "88" displayed.
3. Press dryness level button. All LEDs in group should turn off.
4. Press control on button. Control locked should turn off.
5. Open door. Press cancel.
Oct 01, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Door locked & nothing happens Whirlpool duet wfw8300sw01
hi there,
sounds like the machine has no power at all.
there was no need to break the lock.
unplug the machine
take off the console
check connections from the touchpad to the CCU board
make sure nothing is corroded, burned, bent or pinched
unplug and replug the wiring harness
plug the machine back in and try it again.
let me know if this works.
Sep 26, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Duet dryer won't start F30
well the sensing light will stay on till it feels wet clothes against it if you in auto dry mode it says it wont start without feeling wet clothes against the silver bars in the vent housing it says it will run in manuel mode even if it doesn't feel them pull the top off the dryer and on the right hand side is a tech service sheet in a plastic bag see what it says
Mar 30, 2008 | Dryers
Whirlpool Duet won't run
The trouble could be with the door interlock. When the clothes were jammed in the door it could have caused the door latch to put strain on the interlock.
Oct 28, 2007 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool GEW9250 Electric Dryer Logo
82 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal De
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
