Question about HP LaserJet 3330 All-In-One Printer
CAn you help me change the cartridge in my HP 3330?
Just slide it in gently
Posted on Jan 14, 2009
  • Kate Powell Jan 14, 2009
    do you need any more help?
How to change the toner cartridge on an HP Laserjet 3330 printer?
The panel just above the paper tray is the toner door. Grasp on left and right side, there should be little indents, then pull towards you. Front will open and toner cartidge will move towards you. Grab cartridge and pull it up and out. Reverse procedure to install new cartridge.
Jun 06, 2011 | HP LaserJet 3330MFP All-In-One Printer
Changing Cartridge
Hi:
Your Laserjet 3330 uses a toner cartridge, HP15, and to swap it out, you open the door just below the control panel, or above the paper tray. Once opened, the toner can be removed and replaced easily! Close the door after the new toner is installed, and you are good to go!
Apr 23, 2010 | HP LaserJet 3330 All-In-One Printer
How do I change a printer cartridge?
Get manual below. http://h10061.www1.hp.com/ccsearch/search?method=viewDocument&redirUrl=http%3A%2F%2Fh20000.www2.hp.com%2Fbc%2Fdocs%2Fsupport%2FSupportManual%2Fbpl11470%2Fbpl11470.pdf&docId=http%3A%2F%2Fh20000.www2.hp.com%2Fbc%2Fdocs%2Fsupport%2FSupportManual%2Fbpl11470%2Fbpl11470.pdf&uqry=&cqry=&ctry=us&dlc=en&lang=en&qry=change+cartridge
Mar 10, 2010 | HP LaserJet 3330 All-In-One Printer
Hp laserjet 3330 gears on right side grinding after print
The most common problem with grinding is from compacted toner. Try changing the toner cartridge.
Aug 26, 2009 | Office Equipment & Supplies
HP Laserjet 3330 printed dark page especially around the middle
Does this happen both when copying and printing?
For printing solution, try another toner cartridge.
If lines continue to appear when copying (primarily through the automatic feeder) then lift the auto feeder, and clean the glass -mainly the narrow piece on the left side.
please rate solution :)
Apr 07, 2009 | HP LaserJet 3330 All-In-One Printer
Internal drum on hp laserjet 3330 damaged. How to replace?
If by drum u mean toner cartridge, you will have to order a new toner cartridge from HP.
WWW.HP.com
Dec 14, 2008 | HP LaserJet 3330 All-In-One Printer
My HP laserjet 3330 all in one is now producing very dirty copies after I put in a new toner cartridge. Is it possible to clean it up without taking it to a repair place? I am only semi-skilled at taking...
You might have gotten a hold of a bad toner cartridge. (Did you use a genuine HP toner cartridge?) I would try a new toner cartridge and see if that helps.
Nov 09, 2008 | HP Office Equipment & Supplies
HP LaserJet 3330 All-In-One Printer Logo
20 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
