start new,
use the D110 full setup instructions from scratch.
install the software from HP.
then on some printers, like mine, the USB way works or wifi
if you set it up to wifi , usb is dead.
and the reverse.
so must be reset , per the manual to get it the way you want.
it is a very complex device, this all in one e-printer
https://support.hp.com/us-en/product/HP-Photosmart-e-All-in-One-Printer-series---D110/4023244
wifi, is complex.
first the user must know the routers settings to make it connect.
but some times you have no access to that router, due to owners
are ISP or landlord.
to use wifi , i must force my router to use a fixed IP (reserved)
or will not connect , reliably, the manual covers this too.
use the HP install package,
rule 2:
NOTE: If the printer is connected with a USB or Ethernet cable, the printer cannot connect wirelessly.
click does not maintain wireless....., seen here.
it tells you to run the hp print and scan doctor there.
