Question about BenQ PE5120 Multimedia Projector
Can't Reset the Lamp Timer on my BenQ PE5120
So, I replaced the lamp on my BenQ PE5120 about 6 months ago, but forgot to reset the timer. Recently, the projector has been powering down becuase it thinks the lamp hours are 3001... when I tried to reset it per the manual (press exit then auto) it doesn't respond and shuts down. I tried calling BenQ in CA but they are useless... Please help
  • 14 more comments
  • aceconte Jan 14, 2009
    Thanks for the link, but it did not solve my problem. The problem is that the projector is not letting me reset the lamp timer. It assumes I have gone past the alotted amount of lamp ours and is shutting down right after start-up
  • aceconte Jan 18, 2009
    i was hopeful this would work, but onfortunately, still having the same issue and cannot reset the timer .. projector keeps powering off. anyone else have an idea? I tried calling BenQ, but the 1 french tech support guy was useless..
  • aceconte Jan 19, 2009
    You just gave me the directions from the manual. I tried this and it did not work. Thanks.
    I don't think it's the main board as the projector has been working fine... the only reason it is shutting down is because it is reading 3001 hours of lamp usange and doesn't know the lamp is new. There has to be a way to reset the timer before the projector powers down...
  • aceconte Jan 21, 2009
    There is no "UP" arrow...
    Same result, there must be a way to bypass the security on the projector so that I can reset the lamp before the projector shuts off on me... the problem is that the projector thinks the new lamp has 3001 hours on it so it is shutting down before I can do a timer reset...
    Are you guys even reading my comments?
    This is rediculous..
    wow
    ummm
    "mouse button"? this is a projector not a computer
    I tried this way early on as someone had mentioned it before.
    Guru, I tried this and it didn't work. I have also called BenQ and their tech support is useless... same French guys answeres the phone and gives me the same advice Fixya is giving me, but it never fixes the problem
    not working ;-(
None of these answers are of any use,, The machine benq5120 once it has exceeded the 3000 lamp hours it will automatically shut down, once it has done this it damages the main board, It needs to be sent to a benq agent to replace the main board, Cost is $500. this is a serious ripoff by benq. ,I would never buy another one because this should not be allowed to happen
Posted on Dec 16, 2014
  • BenQ Master
  • 19,396 Answers
Hold down the up arrow key on the Projector for a couple of seconds.
You'll see a on-screen message that appears in one of the top corners that will read - press left or right and Auto or Enter.
from
Lamp Timer Reset...
Posted on Jan 23, 2009
    Sergeant:
    Champion:
  • 435 Answers
Do you have the old bulb ? If so, insert it, switch it on. Switch off after 5 mins. Insert new bulb, switch it on and try resetting as per the manual.
Posted on Jan 21, 2009
  • 10,515 Answers
Try to remove and reseat the bulb is about all you can do at this point. Make sure all vent filters are clean also.
1500 on a 2000 bulb is not uncommon. Reaching a bulbs stated life is a **** shoot at best.......
  • 8,197 Answers
Ok this is what you need to do. You need to be at the projector though. Turn it on and press and hold the exit button for 5 to 10 sec. You will get a menu come up on the tv. now use the arrows to scroll down to reset the lamp hours. If you need you can call benQ at 1-866-600-2367 or 1-949-255-9500 They will be there till 5:30 PT.
Good Luck
  • 1 more comment
  • Jyackle5
    Jyackle5 Jan 21, 2009
    I just got off the phone with BenQ and that is what they told me to do.
  • Jyackle5
    I just got off the phone and talked to an american guy. He was real nise and was going to stay on the line with me till it was fixed. Can the 949 number
  • Jyackle5
    Call the # above and go to this ex.5964. The guy I just got off the phone with will help you till the problem is fixed. He is waiting for your call today or tomorrow I would call the 949 #
  • 11,896 Answers
Turn machine and and reset it WITHOUT the bulbs in it.
  • Nate Stansfield
    Nate Stansfield Jan 21, 2009
    I found out from a guy who works specially with BenQ and other projector companies that you cannot reset any of the BenQ PE models. They are designed this way so that you have to spend money on a new one or send your old one back to the company. Good thing for friends in high places. What a scam!
  • Nate Stansfield
    Nate Stansfield Jan 29, 2009
    Here is a link to your Benq PE5120 Manual:
    http://www.retrevo.com/support/Benq-PE51...
    Master:
  • 623 Answers
Press and hold the Left Mouse Button, then press the Menu button. Hold both buttons down for 10 seconds.
Posted on Jan 19, 2009
  • 119 Answers
I think it might have a BIOS chip..see if you can lookup instructions for flashing the BIOS. BASIC INPUT OUTPUT
    Genius:
  • 1,665 Answers
Hi aceconte!
Resetting the lamp counter i. When the projector is next started, press and hold the Exit 5 button on the projector for 5 seconds to display the total used lamp time. ii. Press Auto on the projector or on the remote control to reset the lamp hour to “0”. iii. Wait about 5 seconds to let the OSD close. ONLINE manual page 23 Thanks for using fixya.
Posted on Jan 18, 2009
    President:
  • 2,110 Answers
Within 10 minutes of powering on,
1) Press the Exit button on the projector for 3 seconds to display the total used lamp time.
2) Press the MENU button on the projector during the lamp hour message. An adjustment message will appear.
3) Press the left or right arrow keys to reset lamp hours (or press EXIT to leave).
    Master:
  • 416 Answers
This might help to reset lamp counter:
1. Press the Reset button on the projector for three seconds or press the Timer button on the
remote control for three seconds to display the
total lamp time.
2. Press the Reset button while displaying the
lamp time to display the reset window.
3. Use the Menu button on the projector or the
Stick Switch on the remote control to select the
0 in the reset window.
Good Luck
Posted on Jan 14, 2009
  • 1,031 Answers
To reset the lamp timer While the Projector is switched on - Hold down the up arrow key on the Projector for a couple of seconds.
an on-screen message will appear in one of the top corners that will read - press left or right and Auto or Enter.
    Sergeant:
    Scholar:
  • 199 Answers
Ok do the following to reset the lamp timer :
    President:
  • 1,990 Answers
Welcome to Fixya! This is a Problem with the Main Board inside the Unit. You could try to repair this yourself But, There are no Schematics available for this Unit. Probably should Locate a Qualified Service Center for Repair.
    Brigadier General:
  • 8,619 Answers
Hi
When the projector is next started you need to press and hold the Exit ^ button on the projector to display the total used lamp time.
Then, Press Auto on the Projector or on the remote control to reset the lamp hour to "0".
Then ,wait about 5seconds to let the OSD close.
Thanks
Rylee
  • 81 Answers
I suggest you start over. Unplug the projector. Take the new lamp out. Plug it in and turn on so it knows there is nothing in the socket. Don't unplug, just turn off. Install the new bulb again then turn on. Now do a reset. The problem you are having is with its internal security type system. It thinks you are just trying to reset bulb time with original bulb in it. Hope that helps.
    Sergeant:
  • 221 Answers
Sharp projector timer unable to reset after replaced lamp.
Reset the lamp timer.
1,Connect the power cord.
2,While simultaneously holding down "menu","enter" and "down" on the projector, press "standby/On" on the projector and keep all four buttons pressed down until the lamp indicator starts blinking green.
"LAMP 0000H" is displayed, indicating that the lamp timer is reset.
Have a nice day!
We supply original projector parts: lamp, bulb, Lcd panel, Lens, DMD chip, color wheel,
motherboard, powersupply ... with high quality and competitive price.
Jerry
Lampdeng Limited
Mar 07, 2015 | Sharp XV-Z9000, XV-Z9000E, XV-Z9000U...
I need help. I have a BENQ MP720p projector. For 6 months I changed the lamp (the old one died). I've been using the projector ever since. 2-3 weeks ago a message "your lamp has ~2900 h of use" came. I...
1,Press and hold the Exit button on the projector for 5 seconds to display the total used lamp time.
2,Press Auto on the projector or on the remote control to reset the lamp hour to "0".
Have a good day!
Jerry China
Tel: +86 131788 67858
E-mail: lampdeng@hotmail.com
Skype: lampdeng.com
YM: lampdeng@yahoo.com
http://facebook.com/lampdeng
http://www.lampdeng.com
Oct 04, 2013 | BenQ MP720p Multimedia Projector
I have two issues with the pb8220 1. How do you reset the bulb hrs when a new bulb is installed? 2. Projects for about 10 seconds then goes black. The red bulb light comes on when the screen goes...
Reset the lamp hours as follows.
Press the Exit button on the projector for 3 seconds to display the total used lamp time. Press the MENU button on the projector during the lamp hour message. An adjustment message will appear. Press left or right arrow to reset lamp hours or press EXIT to leave.
sonsunny
Jul 09, 2011 | BenQ PE5120 Multimedia Projector
Hi there. I've got a benq mp721 which i've just changed the lamp on. the problem is: how do i reset the lamp timer?
Turn On projector, press EXIT and Up Arrow buttons on projector for 5-6 seconds, lamp hours display will appear, press Auto on projector or its remote to reset lamp hours to zero, wait 5-6 seconds to display will get disappear itself.
Thanks.
Jan 20, 2011 | BenQ MP721 DLP Projector
I put in a projecter lamp about six months ago ,now my tv tells me that it needs to be replaced again
You need to reset the lamp timer in the menu. Check your manual on how to reset lamp timer.
Mar 16, 2010 | Panasonic Televison & Video
Lamp is not coming on. It was replaced recently Benq 8720
Check in your instruction Manual about pressing a button sequence while starting up. Some projectors do not actually know when you have changed the lamp, so you have to reset the lamp timer by pressing a button sequence. Often a genuine replacement lamp will have an instruction set which comes with the new lamp ( If you still have it !! :) You may have replaced the lamp but not reset the counter and it has shutdown because the counter has reached a critical umber of hours.
Jan 02, 2010 | BenQ Office Equipment & Supplies
Just replaced bulb to a phillips, lasted one month
Most systems with lamps will have a timer. If the timer gets to a certain hour the set should warn you to replace the lamp. Once you do, you have to reset the timer. If it gets to the max it will not allow you to turn it on till the timer is reset. Check your manual or call the mfg. to see how to reset. Sometimes it's the volume up and down at the same time or menu and power at the same time. They are all different so if you have no manual it's best to call tech support to get the reset steps.
Jul 17, 2009 | Panasonic PT-50LC13 50" Rear Projection...
Projection lamp timer reset
I need help resetting the lamp timer. Is there a way to reset the timer w/o the remote? We bought this tv as a floor model 4 yrs ago and they didn't have the actual remote that came with it, so they gave us another remote that works. We replaced the lamp but we keep getting the message that the lamp needs to be replaced and the timer reset. Plus the red lamp indicator is still on. We even used a friend's remote (he has the exact same tv) and it still will not reset the timer.
Jul 19, 2008 | Panasonic PT-44LCX65 Television
Lamp Timer Reset...
Hello, does any1 know how to reset the lamp timer on a LG RD-JT31? I want to get rid of the Replace The Lamp sign.
Regards Linus
May 12, 2008 | Office Equipment & Supplies
REPLACING MY LAMP
Hi Big Dogg
Replace the lamp and reset the lamp timer.
Lamp timer can be reset by holding down the up arrow key and then following the easy on-screen instructions.
Sep 14, 2007 | BenQ MP610 Multimedia Projector
BenQ PE5120 Multimedia Projector Logo
989 people viewed this question
Top BenQ Office Equipment & Supplies Experts
jasbo
jasbo
Tom Chichester
Are you a BenQ Office Equipment and Supply Expert? Answer questions, earn points and help others
