COLOR WENT BAD
Ihave a 52" sony projection tv, and the color is all messed up and the screen sags to the left.
  • 2 more comments
  • smurray1804 Jan 14, 2009
    model number # KP53XBR200
    can you clarify what the 2nd line "IC 5005 STK392-020"
    And is the "A-1131-319A" and the other part above actual
    sony parts?
  • smurray1804 Jan 15, 2009
    I was able to find a place that had the IC STK392-020 8-749-014-67
    but the BR board A-1131-319A Says is no longer available.
    Do you know of a place that would be able to get the BR Board?
  • Daniel Conklin
    Daniel Conklin May 11, 2010
    need model number
    thanks
    Champion:
  • 240 Answers
FIX
replace Br board up converter part number is #A-1131-319A
REPLACE IC 5005 STK392-020 SONY PART NUMBER
IS 8-749-01467.
Posted on Jan 14, 2009
  • Daniel Conklin
    Daniel Conklin Jan 14, 2009
    yes the sony part is the same part its just more cost thats all.
  • Daniel Conklin
    Daniel Conklin Jan 15, 2009
    try andrews electronics.
Have sharp quos 52" screen went pink. Can still
Hi, My guess is your daughter messed it up. Go to menu and color and reset to default should fix it.
You may have to adjust color for your best viewing. Good luck.
Sep 27, 2011 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
My screen to my RCA 56" HD TV is messed up. The picture seems to be bowed inward and the colors are all mixed up. I tried to do the convergence but it is not on the menu and I remember it being there...
t is the problem of convergence setting or convergence IC.
Comment by ready2helpu, posted on Oct 21, 2008 IF THE PROBLEM OF CONVERGENCE SETTINGS then check out this link
http://www.somelifeblog.com/2007/06/sony-projection-tv-red-line-repair.html
if the problem of convergence IC THEN check out this link
http://home.earthlink.net/~oleg.filippov/ConvergenceFix.htm
you can do it manually.
thanks.
Oct 21, 2008 | RCA R52WM24 52" HDTV Projection Television
The tv picture looks like should be wachting it whith 3d glasse
This is a very common failure on Projection TV sets. Its called a convergence failure. Here are some common symptoms.
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
The other common problem is cloudy lens fluid. After many years the coolant in the blue and green lens will become cloudy and cause the screen to look dull, red/orange, bright white, etc. You may even see halos around objects on the screen.
You can see some example photos and find a solution here on Fixya.
http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Nov 15, 2009 | Sony KP-46WT510 46" Rear Projection HDTV
Is the tubes going out on my rear projection tv?
If the red, green, and blue colors are separated like a rainbow, then the convergence amps are going out. This set has a common problem of two electrolytic caps going bad. The caps are in the upper left-hand corner of the main board and will have a bulged top if bad.
I would not think the picture tubes are bad, especially all at once.
- Dan
Apr 28, 2009 | RCA D52W19 52" Rear Projection Television
Sony KP-51ws500 Sagging Picture and blurred colors
Bad convergence Amp ics mounted to large metal heat sinks on deflection bd.Sony parts around $40.00 each-generic approx 12.00 ea.The board must be pulled out of chassis frame to unsolder the ICs.and some alignment will be needed after replacement.NOT a do it yourself job unless experienced at soldering and desoldering.
Jan 04, 2009 | Sony KP-51WS500 51" Rear Projection...
Hitachi Projection Color Lines
Convergence amp ic bad
http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
Sony Convergence
http://www.techlore.com/blog/entry/19694/Sony-Convergence-Repair-My-Sony-TV-has-a-distorted-picture-/
http://www.techlore.com/article/19631/Sony-Convergence-Procedure/
Jan 29, 2008 | RCA P52937 52" Rear Projection Television
Samsung 52" rear projection tv convergence problem?
THE PROBLEM IN YOUR TV. IT'S THE CONVERGENCE. YOU NEED REPLACE THE CONVERGENCE STK'S AND AFTER THAT YOU NEED DO ADJUSTMENTS.
Jan 14, 2008 | Panasonic PT-47WX49 47" Rear Projection...
Color is messed up
sounds like bad convergance ic
http://www.techlore.com/forum/thread/18970/Sony-KP-46WT500-Convergence-Repair/
Dec 14, 2007 | Sony KP-46WT500 46" Rear Projection...
RCA P52830BL picture is bowed and colors separated.
There is a convergence printed circuit board that likely has a few bad components. If you decide to get it repaired, the technican will probably check for fluid leaks from the picture tubes coolant area which has given problems on this model also. If the picture quality leaves a bit to be desired, it may be a wise move to upgrade to HDTV. A Sony KDS-55A20 model has a great picture and should be less than $2300. I just saw one at a local Sams Club store.
Mar 12, 2007 | RCA P52830BL 52" Rear Projection...
Color sag on mitsubishi ws-55909 projection tv
Adjust convergents for blue.This is done with your remote control. go into menu, setup, instructions will come up on screen, also in manual.
Feb 04, 2007 | Mitsubishi WS-55909 55" Rear Projection...
Televison & Video Logo
82 people viewed this question
Top Televison & Video Experts
Electro Med Services...
