Question about Optoma RD50 Television
TV will not turn on, already replaced lamp
I turn on tv but the screen is dark and no tv volume. A loud noise surges up and down for approximately 1 minute and shuts down and the LED indicator for lamp is solid red. The lamp has been replaced.
  • tinaleblanc4 Jan 17, 2009
    Could this problem be the color wheel or power supply. Does anyone have an idea. Again, the tv warms up the screen is black with no sound. I hear the fan and another noise humming that goes lound and then goes low up and down for approximately 1 minute. The tv then shuts off with the lamp indicator goes to a solid red.
  • tinaleblanc4 Feb 16, 2009
    I will try to find a tech. to test the board. There is only one near my home that is a service tech. Would Best Buy that could service Optoma RD50.
    Thanks
    Tina
    Brigadier General:
  • 6,966 Answers
Hi and welcome to FixYa,
Always, any sound out of the ordinary indicates a fault; intermittent clicking - relay, chirping - power supply, screeching - high speed motor.
Two ways to address the problem:
  • DIY (do-it-yourself) repair. This would require familiarity with electronic components & circuitry, use of a DVM/VOM and a soldering iron. It would be to your advantage to have access to a Service Manual or at the very least a schematic diagram with voltage measurements;
  • seek the services of a qualified professional for a repair quotation.
While it would be possible to effect your own repairs, there would be the above mentioned pre-requisites; otherwise, it would be guess work and unfortunately may lead to false diagnosis/parts replacement. A quote on the other hand would cost depending on the going rate within your location. The advantage is that you would have an idea of the possible cost of parts and service fee. This would be significant since this information factored in with downtime, efforts to have the TV repair would present you an evaluation of your options to consider including, DIY, repair person or worst, replacing the unit entirely.
If you are comfortable with the DIY, pls post back. Good luck and thank you for using FixYa.
Posted on Feb 16, 2009
  • 150 Answers
Sounds like you have lost your power modules.Possibly your picture tube.Is this a projection screen? Is it worth fixing?If it is I would call a repair man.
Hope this helped.Let me know by rating me or
for more help go to live chat.Thanks
Len West
    Scholar:
  • 160 Answers
There is a safety latch where the lamp door closes you have to make sure that the latch is getting depressed when you put the lamp in if not the set will not turn on, some people have stated the when they change the lamp that the latch is not being depressed and the set will not fire up.
thanks.
Posted on Jan 14, 2009
  • Optoma Master
  • 19,396 Answers
The noils lets think to a fault concerning the power supply.
If no blinking code is given the tv must be taken apart and tested by a technician.
On PSU board, capacitors and components must be tested.
If problem is not there , get the service manual and follow troubleshooting diagrams.
    Sergeant:
  • 221 Answers
The upper cover of the is not seated properly.just remove it and make it proper and then check out.
Loud noise then lose picture
The green power LED probably is merely indicating that power is getting to your TV but the internal power supply is failing as evidenced by the loud "pop".
Dec 31, 2013 | Vizio P50HDTV20A 50 in. Plasma HDTV
Volume up then pic gone
You've got a bad solder connection,or broken foil line,s on the pcb (printed circuit board1.gif).Narrow it down by pressing in different places,or use plastic or rubber tip.If not,then you got a shorted load on this fuse and diode.do you have a schematic,whats at the end's of this circuit.D represents a <Diode> not a transistor.
Jan 28, 2008 | Mitsubishi WT-46807 46" Rear Projection...
Rca HD61LPW42 -- we just replaced the color wheel. now we get a picture but only for a few seconds. then it turns off and after a few seconds restarts. this goes on indefinitely. a couple of times...
Hello
If the power light blinks slowly,
you've tried to turn on the TV during
the lamp cooldown cycle. Wait
approximately 30 seconds, and the TV
will turn on automatically.
If light blinks, pauses for about a
minute, and blinks again: the lamp is
trying to turn on (TV will turn on
when successful). If TV doesn't turn
on and sequence continues, the lamp also
needs to be replaced.
To order lamp call 1-800-338-0376.
Have your TV serial number
and lamp type available (you'll
find this information on the
sticker that's on the right side of
the TV).
OK.
Jul 24, 2011 | Televison & Video
The picture has suddenly gone dark. We can still see the picture, however it is really dark. We tried shutting it completely down and unplugging and restarting it. We tried to adjust the color via the...
The tv LED light on the tv front bazel frame face have the word "LAMP" light up or blinking?Yes.The tv projection lamp been inside this tv like 1 1/2 or 2 years already,tv used it everydays like 4 or 5 hrs daily?Yes.Than the tv projection lamp life are over,that why it dim picture tv now must have it tv projection lamp to be replaced.
Jun 12, 2011 | Samsung SP50L6HX 50" DLP HDTV
Heard a loud pop noise and the tv cut out. Left it off to cool down and turned it back on but no sound or picture. The green light was on and the fans attempted to start but then shut down
Easy one. Your lamp needs replaced. part number is labeled on the lamp itself and is easily accessed from the rear of the TV. Approximately 6" lamp cover removes with a few screws then a couple more for the lamp. Simply pull out and replace. Cost for the lamp is around $219. Make sure to replace with OEM parts.
Bill W
integrityhomeworx.com
Mar 12, 2011 | Mitsubishi WD-65733 65" HDTV
Have a model WD 55734 and the screen is completely black when turned on, and the tv makes a loud chirping or clicking sound that continues even when you turn the tv off. Lamp replacement??
Tv LED"LAMP"light flashes,projection lamp been inside the tv like 1 1/2 or 2 years?Used like 4 or 5 hrs daily?Yes,the tv projection is dead,should be replaced.The clicking noises,that mean the board call the Ballast board also dead,must be replacing too.The Ballast board only job it to ignite the tv projection lamp.
Feb 13, 2011 | Mitsubishi WD-57734 57" HDTV
I have a Sony Bravia KDL-22BX300. When I turn it on, within the first few minutes I get this loud blast of static-y noise & the picture goes all snowy. It'll last approximately 10 seconds, then the...
This problems it is the tv Tuner signal board itself it is dying,just not dead yet.This problems the tv Tuner signal board is slowly dying,when it is completely dead.Ur tv will have only LED power light indication.No broadcasting tv signal at all.The tv Tuner signal board,that the board,where the incomming broadcasting signal cable plug into it.U can wait until it completely dead or like to change it now.Tries websites like Shopjimmy.com,Ebay.com to buy a tv Tuner signal board for the replacement.
Jan 18, 2011 | Sony BRAVIA KDL-40S2010 40 in. LCD...
Sony kp-65wv600 projection tv error code. My tv blinks 7 times.
The Standby LED blinks when the TV is turned on, then shuts off when the picture is displayed. If the LED blinks continuously, this may indicate that the TV requires service. Before getting the TV serviced, try power resetting the TV and factory resetting. Try the below steps also: Connect the TV to a different wall outlet and check if it helps. This is to check if the issue is with the Power. Disconnect the TV from the Power Strip or the Surge Protector and connect it directly to the Wall outlet and check if it helps. To Power Reset the TV, disconnect the Power cord for a short period of time (approximately 1 minute). Then, reconnect the Power cord and power ON the TV. To factory reset the TV, turn it ON. Then while holding down the RESET button on the Remote Control, press the Power button on the TV front panel. The TV will turn OFF and then turn ON again. Then release the RESET button to complete the reset procedure. If the issue persists, service may be required.
Good Luck!!
Nov 09, 2010 | Sony KP-65WV600 65" Rear Projection...
Optoma RD50 Television Logo
52 people viewed this question
Top Optoma Televison & Video Experts
jasbo
jasbo
rostit
Are you an Optoma Televison and Video Expert? Answer questions, earn points and help others
