Question about Maytag PYE2300AY Electric Dryer
LOUD NOISE AND BURNING SMELL
I have a maytag quiet series 100. Whenever i turn it on it makes a VERY loud noise and then smells like something maybe burning? My husband did see smoke once but not since. Should we buy a new dryer or can it be fixed?? HELP!
  • 979 Answers
How old is this dryer? If it is older that 15 years get a new one. You don't want to deal with the headaches. The motor may be going bad on it and the wiring could be melting. I assume it is not working now. Have him check the breakers. Make sure the connections are o.k. in the back. Clean out the lint piping and look for lint underneath it as well.
Posted on Jan 14, 2009
My Indesit IDL40 dishwasher, loud bang with slight burning smell but still working?
Any burning smell is not good. Indicates that something in there is too hot and perhaps melting something. Could even catch fire......
Could very well be that whatever is responsible for the noise can be causing the problemo.
Sep 25, 2015 | Indesit Dishwashers
We were using the microwave the other night and it started making a loud noise like the fan was running (although the fan was not). We let it sit for awhile and try to use it again but the noise came...
The loud noise and no heat means that the magnetron has failed. It the part that generates the microwaves that heat the food. When it fails it shorts out, causing the transformer to heat up. That is what was causing the burning smell. The cost of a replacement magnetron is around $130-150 range so it may not make sense to have it fixed.
Mar 24, 2011 | Maytag MMV4205 Microwave Oven
When I turn on my 2001 elantra air conditioning, it makes loud noises and it smells like somethings burning.
sounds like the a/c compressor maybe no good causing the noise and if the a/c clutch is not working right then this can be the smell.
Mar 18, 2011 | Hyundai Elantra Cars & Trucks
Loud grinding noise and burning rubber smell
Could be damage to drive belt which is made of rubber
Dec 21, 2017 | Kenmore Dryers
Washer is making a loud noise when its trying to rinse
you will have to open up the panel to check where the smell comes from. It could be on the motor which may cause also a loud noise or from the electrical, loose connection or bad relay may cause a noise of a different kind.
Sep 21, 2009 | Maytag Performa PAV3200
Burning smell, Loud noise when start button and doesn't turn on
Belt, and skid plates very easy to change and not much money
Aug 12, 2009 | Maytag Neptune MDG5500AW Gas Dryer
Motor Pulley Squeeling - Maytag MDG5500AWW
try spraying wd 40 on the motor ends to see if it will stop if not try the rollers normally they go bad and make the belt squeel.
Jun 18, 2009 | Maytag Neptune MDG5500AW Gas Dryer
Loud noise, then not so loud, but now electrical burning smell and little draining
the smell is your clutch and the lack of draining is a clogged washer drain protector. see these at www.repairclinic.com drain protector is part 541811 and clutch is 2670. go there enter model number and scroll down to the red 100 click it and look for these part numbers.
Mar 02, 2009 | Whirlpool LSR5132PQ Top Load Washer
Dryer making loud noise
the humming noise is most likely your motor. does it overheat or shut down on you? do you smell anykind of burning? Joe
Nov 14, 2008 | Maytag Neptune MDE5500AY Electric Dryer
Maytag PYE2300AY Electric Dryer Logo
736 people viewed this question
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
