Question about Dryers
Dryer only works with manual timer
Unable to use the automatic preset controls. It will only work with setting the timer manually.
  • 2 more comments
  • chas3411 Jan 14, 2009
    This is a Maytag electric dryer Model MDE4000AYW Neptune. Web site would not let me insert this info. The intellidry system will not work. It will only start by using TIME DRY. Will not start using press Care or Regular. Looks like a manual timer dial. No LED panel. Built in 2000.
  • chas3411 Jan 15, 2009
    Two part numbers found at Maytag. I guess it will be necessary to remove the old part to get the number.
  • chas3411 Jan 16, 2009
    What is the exact name of the part. The previous answer is no help.
    THIS is a good answer, ordered the part as stated. Thanks,
    cec
  • Dryers Master
  • 19,396 Answers
You can also find replacement below:
find parts and diagrams by entering model number here.
Posted on Jan 23, 2009
    Sergeant:
    Scholar:
  • 199 Answers
 timers and how they work: Timed dry cycles on a timer are the simplest timer cycle. The timer motor receives 120 volts and just advances all the way from where you set it to the off position. Example- You set it for 50 minutes, it will run for 50 minutes and shut off. The AUTO cycle is a little different. Theoperating thermostat cycles off and the power is redirected to the timer motor to advance the timer to the off position. There is no power to the timer motor until the thermostat cycles the heat off and then that power is directed to the timer motor. If your timer will not advance in timed and auto dry...probably a bad timer or wire. If your timer will not advance in AUTO dryer but will advance in timed dryer...problem is normally not your timer.
Dead dryer: Common problems...blown house fuse, broken belt ( on some models )...door switch...*thermal fuse open ( venting needs attention )...broken or burnt wire....timer....motor, in order from most common to least common. * If you find a blown thermal fuse, always clean, change, adjust the venting system and vent hood first, then it is often a good idea to replace the operating thermostat at the same time. This is a picture of some modern thermal fuses.
Changing from 3 to 4 wire hookup on a electric dryer:
Power cord help for 3 & 4 prong dryer cords
This is an example of a three wire connection dryer cord hookup. Notice that there is a ground strap connected from the common center terminal to the frame of the terminal block. Place the center wire of the cord on the center terminal [ one with the ground ******** it ] and the other two wires will be placed on the outer terminals and it doesn't matter which wire goes right or left. Get the center wire of the cord right and you are in business.
This is an example of the 4 wire dryer cord hookup. Notice that the ground strap has been removed from the terminal block frame and folded back onto the center terminal for storage. You can see the colors of the other hookups. TIP: White always to the middle.
Posted on Jan 16, 2009
    Genius:
  • 1,199 Answers
    Sergeant:
  • 221 Answers
Q - Dryer takes too long to dry or multiple times to dry a load
A1- Pull the dryer out away from the wall. Unhook the vent from the dryer completely. Do not put anything over the dryer exhaust on the back of the dryer. Do a normal load with the vent unhooked. If it dries better or ok like this then the problem is in the dryer venting. Like a blocked vent pipe or a smashed or restricted vent hose.
A2 - If the vent doesn't make a difference, then check the blower wheel for excessive lint build up, check that there isn't anything stuck to the air intake baffle inside the drum, (i.e. the screen on the back wall of the dryer when looking into the drum). Check the lint filter chute for blockage. Check that the heating element isn't shorted to ground. Check the exhaust temperature of the dryer. A meat orpocket thermometer can be used for this. It should cycle between 120 degrees and 160 degrees. Check that the drum seals are worn out.
Check blower fan for proper air flow Check the blower wheel for being stripped out in the middle
Notice: this is a common problem The hole in the center of the blower wheel should be "D" shaped. These strip out after awhile and then spin freely on the shaft, not spinning at the same speed as the motor. This makes a rumbling noise and poor/slow air flow through the dryer.
  • Dryers Master
  • 8,220 Answers
Near the timer is a small micro processing board. Yank it out of its slot and clean the copper contacts. Re install it. Reach inside the dryer and clean the two metal sensing strips with alcohol. These, measure capacitance in clothes, in association with that small electronic board, to determine dryness. Retry the machine in the Auto dry cycle. With any luck you will not have to buy any parts.
Posted on Jan 15, 2009
    Genius:
  • 1,665 Answers
Hi ! At Link below you can find your timer assy in stock. Good Luck
http://www.repairclinic.com/Parts?s=t-MDE4000AYW+Neptune-%3d%3dd92706c212
    Sergeant:
  • 378 Answers
Its the problem with the control panel board functioning unit.replace the board to solve.
The timer works but after starting within a few min the motor speed goes to low speed and stays there
well I cant be absolute sure because you didn't include the make and model of the timer/control , but I can say on most automatic controllers for pool and spa pumps , if you set them to come on automatically at a preset time of day most will run in there slow to mid speed , this is because the filter doesn't need to have highest flow to work , and then this reserves the highest speed for when it's needed like when pool/spa is in use by people and the control should allow an operator to manually override it to full speed as well , hence the automatic cycle time of day should not be set to operate at peak use times but instead late at night or off use hours (saves energy too)
Aug 15, 2015 | Pool & Spa
Duet dryer problem - GEW925PWO control panels do not automatically set. When they do give lights and time like they are accepting, they are not matching up with what the control is set on. The whole left...
hi The dryer timer, located in back of the control panel, controls several things: the drying time of the clothes in the drum, the flow of electricity to the heating element, and the flow of power to the timer motor and the drum motor in the dryer cabinet. Timers are driven by synchronous motors. Although the contact part of the timer can be cleaned and adjusted on some dryers, this is a job for a professional repair person. Timer motor repairs should also be handled by a professional, but you can replace a faulty timer yourself. Here's how to test and replace a dryer timer:
Step 1: To access the timer, remove the front of the control panel. On some dryers, the timer can be removed without removing the panel. In either case, pull the timer knob off the shaft and slip off the pointer. The pointer is usually keyed to the shaft by two flat surfaces to keep the pointer from slipping when it's turned.
Step 2: Test the timer with a VOM set to the RX1 scale. Turn the timer to the NORMAL DRY setting and disconnect one of the timer power leads. Some timers may have several wires connected to them: The power leads are usually larger than the other wires, and this size difference can be spotted under close examination. Clip one probe of the meter to each timer terminal. If the meter reads zero, the timer is working. If the needle jumps to a high reading, the timer is faulty and should be replaced. Replace the timer with a new one of the same size and type.
Step 3: To replace the timer, have a helper hold the new timer close to the old one, especially if there are several wires to be changed. Disconnect the old wires one at a time, connecting each corresponding new wire as you work, to make sure the connections are properly made. Or, draw a diagram detailing the proper connections. After all the wires are connected, check the connections again for accuracy.
Sep 13, 2008 | Whirlpool Dryers
KitchenAid electric dryer, Model # 750LQ, has a broken (I believe)cycle selector (timer) control. The dryer turns on when the control is activcated by turning to the right, but is not in automated mode...
If you are setting the unit on automatic and the timer itself is not moving forward to the shut off position and you have to manually turn the timer off then you would need to order and replace the timer itself. If you have any further questions message me back Thanks Rick
p.s If you need me to look up the part number for your unit please provide the full model number of your dryer and I will try to locate the part number Thanks Rick
Jul 01, 2011 | Dryers
My Woods 59202 Lamp Timer doesn't have a switch labelled "ON/AUTO" as per the instructions, but obviously the only switch on it, labelled "ON/OFF" is the manual override. The problem is...
There are two timers that look very similar.
Woods 59201 programmable timer with settable on-off functions and switch with ON-AUTO
Woods 59202 random vacation timer that has preset on-off functions and switch with ON-OFF
http://waterheatertimer.org/Woods-timers-and-manuals.html#59201
Random vacation timers are not programmable.
They have internal pins that are preset for random on-off functions so house appears occupied while you vacation.
Random timers do not have AUTO setting, instead they are either ON or OFF.
Technically, programmable timers are also either ON or OFF, but usually these timers use the word AUTO, so you know lamp will turn on AUTOmatically based on settings.
Add a comment for more free help.
Also take advantage of fixya expert assistance live.
For a price, expert works with you while you work on timer or any do-it-yourself project.
Fixya is always less expensive than a service call.
Mar 05, 2011 | Woods 59202 7Day Vacation Security Lamp...
Hotpointdryer timer problem
There are two coils in the heating element, and if one burns out, the timer will not advance in automatic dry. The timer should still advance when using manual (or timed) dry.
Jan 20, 2010 | GE DBSR453EBWW Electric Dryer
Kenmore 11070702990 Gas Dryer - Timer does not work
If your dryer seems to run forever, it could be because of a clogged vent or internal ductwork. Your dryer may have an automatic cycle that turns off the dryer when the clothes are dry. It does this with a special thermostat or moisture-sensing system.
Normally, this is what happens during an automatic cycle:
  • The thermostat tells the dryer to heat until the interior of the dryer reaches a pre-set temperature--say 135 degrees.
  • When the dryer reaches the pre-set temperature, the thermostat tells the timer to begin advancing. (If there's a moisture sensor, the timer advances only if the moisture content of the clothing is low enough.)
  • The timer advances until the interior cools, then the thermostat tells the timer to stop advancing, and tells the dryer to start heating again.
This cycle continues until the clothes are dry. But…if the vent is clogged, the dryer may never reach the proper operating temperature, so it doesn't send the signal to the timer and the dryer continues to run indefinitely, even if the clothes are completely dry. To fix the problem, clean the vent and/or internal ductwork.
May 09, 2009 | Kenmore 60172 Electric Commercial Dryer
Dryer heats timer advances however won't shut off
Timer replacement needed unless you can deal with it.
Jan 20, 2009 | Dryers
Unable to control the maching
Are you sure that this is a timer issue because my research does not list this unit with a timer. It does have a humidistat which could give the operation that you describe depending on where the humidity level is set. You should be able to go to the menu and select the mode that the unit is in. If it is set to run until a certain moisture level is reached it sounds as though your unit is probably working the way it is supposed to. Generally that is the mode that most people would want. If you want it to remove more moisture readjust this setting to a lower percentage. Your operation manual should explain the procedure. Good luck.
Jun 21, 2006 | Danby DDR600R Silhouette Dehumidifier
Dryers Logo
Top Dryers Experts
