Question about Ovens
Kenmore ultra self cleaning oven or top heat
Neither oven nor top will heat. Electrical display works says "pre-heat" but never get hot.
Before the problem, I saw gray smoke and smell a different odor. We checked the back of stove, saw no apparent problem.
Can you help me?
I found that the 220 plug had burned out, that was where the smoke came from. The display worked because the ground "prong" was the only one burned. Had to replace the electrical 220 socked and the electrical plug on the oven.
Posted on Jan 14, 2009
Why don't top oven broiler and bake elements heat?
we had that problem once. it turned out to be the control switch was broken
Apr 10, 2016 | Kenmore 27 in. Electric Self-Clean Double...
Not sure which model my oven its but it takes a long time to preheat then does get warm enough. I put an oven thermometer in it and if you set it for 400 it beeps that it is up to temperature at 300 then...
I have a kenmore electric range/ultra bake, after using the self-cleaning mode on the oven, I cannot get the oven to heat up when I put it in the preheat mode. What should I do?
Apr 06, 2011 | Kenmore 40494 / 40495 / 40499 Electric...
Display went blank during the self cleaning cycle
Hi, Before you go working too hard to get you oven to go intothe self clean mode(self destruct)....check out this tip...
Self Cleaning Oven Problem
" Wish I had read this first. I never would have used the self cleaningoption. Thanks for the info!!
Apr 29, 2009 | GE JTP28 Electric Double Oven
Kenmore Ultra bake self cleaning oven is showing code E0 - F2
My oven will not stay on, when started to preheat it will come on for a few seconds and they it will make a beeping noise and the codes E0 F2 will appear. The codes stay on even if the oven is off.
Jan 04, 2009 | Kenmore 40494 / 40495 / 40499 Electric...
My oven is a kenmore gas single, self cleaning oven about 8 years old. the oven will not light. the top of the stove is fine.
Open the oven door and take the bottom panel off. you will be able to see it the hot surface ignitor starts to glow or not. Now turn the oven on and see if the hot surface gets red hot it not that is the problem. Should be able to get the part at a heating and air parts house or a appliance parts house. let me know what you find out. ken
Dec 13, 2008 | Kenmore 30172 / 30174 / 30179 Gas Single...
how do I get my self cleaning to come on in my hotpoint stove
May 22, 2008 | Ovens
Kenmore 47779 double oven; lower oven doesn't work after self clean
Sounds like a thermal overload has opened up during clean. It may be mounted on the back.
Nov 02, 2007 | Kenmore 47772/47774/47779 Electric Double...
Our oven's heating elements will not come on althought the display seems to work correctly.
Wekiwa, your TCO, (thermal cutout) probably opened during the high temps in self clean. You will have to remove the back panel and replace it. It should be just under the vent back there. Part number 4450934. You can ohm it out first to make sure, it will show open (no continuity) if bad. This is an easy job, won't take you that long. Kill power to the range before going back there. In doing a little more research on your model, I see there was a service flash where they recomend moving the TCO over to one side so the cleaning cycle doesn't affect the TCO. This may be covered by Whirlpool. You might want to call them and inquire. back.
Dec 18, 2006 | Whirlpool RBS275PD Electric Single Oven
Ovens Logo
115 people viewed this question
Top Ovens Experts
Dan Webster
Dan Webster
Are you an Oven Expert? Answer questions, earn points and help others
