Question about Dell Axim X51v Pocket PC
Align Screen stuck in loop after hard reset and clean
  • shane rooney Jun 13, 2007
    Hi Bogdan thank you for your reply. Yes i can connect with active sync. I cannot get past the align screen messege. I tried the axim update from dell but it wanted me to be past the welcome stage. The screen does respond to taps and the cursor moves but just goes back to the start of the align screen sequence each time.
    Hi Bogdan
    Thank you for the detailed information. It's not your fault that its terminal news. I really appreciate it as now i know that i need to just move on and get another pda and not waste any more time or money on this one.
    Best regards
    Shane
    Novelist:
  • 198 Answers
Hello, I could be able to diagnosticate your problem but first I need to know some more details. At the current state, can your pda be connected to active sync ? (you may try using it's cradle or usb cable) Can you manage to pass in some way of the align screen message? Does the screen respond to taps? When you tap the screen trying to callibrate does the cursor moves or does something? Please try to explain these questions and I'll be back with an answer as soon as possible. Thanks for understanding.
Posted on Jun 13, 2007
  • Motoi  Bogdan
    Motoi Bogdan Jun 13, 2007
    Hello again,
    I worked some time in a PDA service center, altrough now I work for my own. However during this time I've seen a number of PDA's with this problem. Most people thought that if the touchscreen doesn't respond to taps it may be broken or the display unit is damaged itself and needs to be replaced. I remember beeing surprised when I found out that most of these problems comes from a component on the pda's main circuit board - the display controller. Unfortunatelly I suspect this in your case also. However in this case, there is no known repair that can be done for your pda. Maybe only the change of the whole motherboard but that is very unpractical and expensive. The display controller could have failed from different motives. Sometimes I've seen these problems when a pda is left unused for a long time, sometimes when the pda suffers from passing from cold to warm environments, somethimes mechanic shocks. However there is no service that I know that can repair this. I my self I'm working for 2 years to diagnosticate these kind of problems in order to better understand them. For the time being I will share with you what I know.
    Your problem isn't related to the display itself. I say this because if it were, the cursor wouldn't have moved. Tapping the screen would have resulted in nothing, yes, but the cursor would have stayed still. This is because the cursor moves when the display controller "says" the screen has been touched. An ok and working controller would have known that if the touchpad is dead, there aren't any signals for it to pass on and allow the cursor to move.
    This is not a connector problem. Sometimes people think that this may occur because the connector cable that links the display unit to the motherboard it's damaged or doens't make an perfect electrical contact. Well, the screen of a pda (the actual display) is a matrix of small transistors (TFT display - thin film transistor). If even one single pin is removed or doesn't make a proper contact, the results would be verry visible on the screen. The touchpad of a pda is a matrix of small resistors. A touchpad has only 4-5 pins to connect to the motherboard. If one of these or more don't connect properly, the display controller woun't do anything at all. In any case at least it woun't move the cursor by it's own.
    Reinstalling the operating system/upgrading the firmware/upgrading bootloader woun't help in these situations because the problem has a hardware nature.
    I'm sorry for I was suposed to help you, not to tell you so much reasons for nobody will be able to do that. However there is still a small chance that for Dell axims this problem could be a litle more easier to fix. HP's aren't for shure in that region. I had 11 PDA's, all hp with this problem, all of them becomed exchange parts. However, in your case, you may try to go to a PDA service center, a really good one, I may add, tell them all I have told you and hope that they may have some kind of cheaper solution that doesn't involve changing the whole motherboard. Please do not go to Dell, they will simply say you it's broken and then, they will try to sell you a new motherboard at an even most expensive price then other services. Please note the reasons they can't help you. Few people know that Dell, HP, Fujitsu Siemens, Mitac, XDA, MDA or all other names in the pda business don't produce the pda's by themselves. They don't even know how they work at a hardware level. All these pda's are made at HTC factories in Taiwan and assembled in other countries. They are however all of HTC design. If there is supposed to be someone to know of this problems, HTC would be the ones. However I had a difficult time making them share the hardware specifications of the screen controllers or the bootloader bypass codes in order to run a system diagnostic to figure out more of this problems.
    As I've said somethimes here on this forums, I'm sorry when I'm the one suposed to deliver the bad news, especially in this situations.
    I wish you good luck in the attempt to contact a pda service, unfortunatelly you will need it. However I may still provide usefull informations if you have further questions. Just feel free to ask.
  • Motoi  Bogdan
    Thank you for the good review, altrough nothing could be done for the pda. There are many people I know with the problem, some are here over fixya, different models but same problem. I will continue to search a way to acces the internal bootloader command mode to diagnosticate this. I have some spare PDA's here to test these methods on them and if I manage to find a fix for this I will ask Fixya to issue a generic message regarding the solution I provide. Untill then, all hopes to the best and .. better luck with the next pda you'll have.
    Thanks again.
I own a Samsung Omnia I (SGH-i900) and I accidently reset its hard disk. I started the device once again and it got stuck at the "align screen" setup. I've been trying to align innumerous times...
Hello.
The screen digitizer could be defective.
But, try to align with a pen (if you haven't already). And, try the hard reset, again.
If still a problem and still under warranty, contact Samsung for a screen replacement. This is a common problem for the Omnias.
Hope this helps.
Mar 12, 2011 | Cell Phones
Screen alignment loop
The only thing I can think of is that the screen might be bad. Has it been hit or dropped? Are you SURE you haven't thrown it against the wall? :P Just kidding, but seriously, my dad's old Palm had a similar problem where if you tried to calibrate the screen, it would loop, and it was because the screen was old and wasn't performing correctly. Although you were pressing it in the right place, the screen wasn't reporting the locations properly, causing the thing to loop to try and get correct readings from the screen.
Dec 04, 2007 | Dell Axim X50v Pocket PC
Tungsten e2 is always looping on the stylus calibration screen
actually ur Digitizer is faulty u can replace it urself cost around 25 $ or so do u want to proceed let me know , unless u change the touch panel digitizer u will be stuck at align screen thing
let me know if i can help more
RATE ME WELL !
Jun 02, 2009 | Palm Tungsten E2 (Multilingual) Handheld
Samsung A707 Stuck at startup screen (loop)
No hard reset wont help!You should try following to get rid of this problem:
  • Change your phone's battery.
  • Change your charger.
  • Hard reset wont be possible in this case.
  • You should also consider charging your phone for long time but still if does the same loopy thing then change your charger.
Thank you and good luck!
Mar 06, 2009 | Samsung SYNC SGH-A707 Cellular Phone
Touch screen doesnt work
you will find a screen on www.ebay.com.au, or prefferrabl you can go into any phone hardware store loated near you to solve your issue.
Jul 15, 2008 | BenQ P50
Stuck On Align Screen
This happened to me also. Drain the battery completeley and then do it again. You may have to do it a couple times but it will finally take.
Mar 20, 2008 | T-Mobile MDA
Cant git pass the align screen on my hp2215 ipack
Have you tried a Hard Reset?
This should get you through it but you will lose all of your info.
Information is here:
http://www.coldreset.com/modules.php?name=News&file=article&sid=713
Hope That Helps!
Dec 01, 2007 | Compaq MS Pocket PC 2002
Axim X5 Align Screen Loop
I am by no means an expert but I have had the same problem that you are having and I found that after I took my X5 apart and cleaned around the underside edge of the plastic housing frame that was at the edge of the screen the problem went away. I also cleaned the front of the screen very well and put a new back-up battery in. I have not had the problem since.
Sep 05, 2007 | Dell Axim X5 Pocket PC
Ipaq RX 3115 Stops at align Screen
solia, I'm sorry, I didn't mean to close the chat session on you.
Is your unit still under warranty? If so, check with the manufacturer.
They can help.
Mike
Sep 27, 2006 | HP iPAQ RX3115 Pocket PC
Dell Axim X51v Pocket PC Logo
505 people viewed this question
Alun Cox
mukhtar21 shaikh
mukhtar21 shaikh
