Question about RCA TH1602 MP3 Player
MY RCA MP3 IS NOT WORKING
THE BLUE LIGHT COMES BUT I DOES NOT DO ANY THING ELSE. I NEED THE INSTRUTIONS THAT HAD TO BE DONE ON THE COMPUYER SENT TO ME, TO PUT IT IN MY COMPUTER.
  • 7 more comments
  • Anonymous Jan 14, 2009
    when i turn it on, all that comes up is the blue pearl thing.
    its like its frozen.
  • southsidesse Jan 15, 2009
  • Anonymous Jan 19, 2009
    When I plug it in to the computer, its not recognized. It also won't turn on. I have already changed the batteries and reset the player. Please help!
  • Anonymous Mar 02, 2009
    IN MY COMPUTER.
  • Anonymous Mar 13, 2009
    it jus wont turn on. it will show me the pearl logo but thats it
  • Anonymous Mar 30, 2009
    I have the same problem but my computer will not read or recognize the device at all. How can I download the firmware on it if it won't let me?
  • CapnChaos Apr 22, 2009
    Same here. Blue logo, no other lights/response, nothing when plugged into USB, thus firmware cannot be reloaded (v1255). Worked fine when I turned it off Monday afternoon.
  • moore4440 May 01, 2009
    I too have replaced the battery leaving it out for awhile in the hopes that it would reset itself. I know at one time my son locked it, so I'm wondering if these issues are related. I contacted RCA & they were essentially no help. I turn it on only to find the blue Pearl logo with no little rotating blue dot showing that it's 'thinking'. I was getting a USB connected sign before I tried to download pixyspoxey's suggestion online at the audiovox site, now I've got nothing including no download. My computer won't even recognize the player at all. But I just took out the battery & connected it to the USB port & now it's showing a connection. I'll get back to you if I find a solution.
  • ctyner May 02, 2009
    the screen will light up blue with the product symbol, but after that the product does not work
    Problem Solver:
  • 5 Answers
    Problem Solver:
  • 8 Answers
Normal 0 false false false MicrosoftInternetExplorer4 st1\:*{behavior:url(#ieooui) } /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} I managed to get mine working again! Here’s what I did:
1) Remove battery from Pearl Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} (and microSD else it will also be re-formatted).
2) Open "Computer Management", go to "Device Manager", select "View ->Show Hidden Devices" and select “Human Interface Devices” in the tree.
3) Insert Pearl into USB while holding the center (play) button for 5 seconds (my XP 'bonked' indicating hardware detected).
4) Under "Human Interface Devices", there should be a new entry: "USB Human Interface Device", the "Location" contained: "Location 0 (ROM Recovery)".
5) Run the latest firmware update software and it should find the device. Once the update software has initialized but before starting the update, the HID entry disappeared and a new entry: "_Generic MSC Recovery USB Device" appeared under “Disk Drives”.
6) “Start” the firmware upgrade with “Format Data” checked. While re-applying the firmware, the Pearl's display stayed blank.
7) After the upgrade is complete, you should have the familiar two "Audiovox PEARL USB Device" entries under “Disk Drives” (you may need to disconnect / reconnect Pearl, I didn’t but you never know).
I don't remember if I had rebooted or not when I finished the firmware upgrade, though subsequent tests did not require reboot.
Why Audiovox support didn’t mention the significance of holding down the “play” button while inserting the Pearl is puzzling to put it politely. I am curious if this works for others.
Posted on May 04, 2009
  • CapnChaos May 04, 2009
    Reposting since MSWord tags in previous post:
    I managed to get mine working again! Here’s what I think worked:
    1) Remove battery from Pearl (and microSD else it will also be re-formatted).
OK, so I took out the battery and reattached it to the USB port & retried pixyspoxey's audiovox site update for the RCA Pearl 1602. It first showed the 'USB connecting' on my screen, then when I went into the downloading process the screen went black (couldn't even attempt with the battery in...kept getting an error: unable to write the firmware file data), but my computer screen was showing that the download was in fact happening. Up side...it rebooted itself completely & now is working, down side...I've lost all the music that was on the MP3 player itself (which is fine because I have the music saved on my laptop - I know this won't be the same for everyone). Hope this was helpful!
Posted on May 01, 2009
    I don't have a micro SD, but if you do, be sure to take it out along with the battery before starting this process so that your music won't get wiped & then after it's been rebooted try & see if you can re-sync your music back onto the player. I recreated a playlist for my son so if this happens again, it'll be easier to re-sync his favorites. I also went to voxrightnow.custhelp.com & downloaded the latest version of the RCAeasyRipInstaller2080.exe because even that was wiped. So far, so good! Good Luck!
If you go to the website and download and install the latest firmware it should fix it. It did fix it for me. Download it even if you have the latest already.
Posted on Jan 19, 2009
  • 3 Answers
You should be able to download a pdf of the manual at rcaaudiovideo.com goodluck
Posted on Jan 14, 2009
RCA MP3 player named PEARL isnt working
This is a common issue with these devices and usually requires reflashing the firmware.
You can download the update from the RCA help site here:
http://voxrightnow.custhelp.com/app/answers/detail/a_id/1451/session/L3NpZC9YaTg4X21Oag==
Be sure to back up any important media on the device in case the fimware install wipes out the media on the device.
Nov 17, 2009 | RCA Pearl TH1102 MP3 Player
TAKES FOREVER TO LOAD THEN SUTS DOWN FOR NO REASON.
Try to reset the device, if that doesn't help, try a firmware update.
Go here for instructions:
http://voxrightnow.custhelp.com/app/answers/detail/a_id/2200
Oct 02, 2009 | RCA M4208 MP3 Player
It started with my mp3 player getting stuck at
did you hit the device by chance, or some hard shock. if that is/was the case, the lcd cable could have been dislodged. Not thing easy to fix on such a small device, however you can have a technician take a look at that aspect of it.
Another thing might be the backlight for the device is done with. not sure they are replaceable on those small device.
Aug 17, 2009 | RCA M4204 MP3 Player
Blue pearl light comes on then play light comes on then nothing
Go here and do the update. It's the same version...but it works. Run the update, put a good battery in and THEN put it in the usb.
http://voxrightnow.custhelp.com/cgi-bin/voxrightnow.cfg/php/enduser/std_adp.php?p_faqid=2243&p_created=1214239700&p_sid=npB9ov8j&p_accessibility=0&p_lva=2253&p_sp=cF9zcmNoPTEmcF9zb3J0X2J5PWRmbHQmcF9ncmlkc29ydD0mcF9yb3dfY250PTEmcF9wcm9kcz0xNTgmcF9jYXRzPTAmcF9wdj0xLjE1OCZwX2N2PSZwX3NlYXJjaF90eXBlPWFuc3dlcnMuYV9pZCZwX3NjZl9icmFuZD0mcF9wYWdlPTEmcF9zZWFyY2hfdGV4dD0yMjQz&p_li=&p_topview=1
Cheers
Apr 07, 2009 | RCA TH1101 MP3 Player
Rca mp3 m4018a
Try going to rca's website and doing a firmware update to the mp3 player.
Jul 30, 2008 | RCA OPAL M4001 MP3 Player
No light comes on, had it on the charger all night, and used the usb cord, now what?
what have happened? did it just stop work or
have u done anything or dropt it? i need more information if i gonna try to help ;p
Jan 18, 2008 | SanDisk Sansa e250 MP3 Player
Need instrutions for my mp3 player M202E
Try music management software that still downloads from libraries like
RealPlayer, Winamp. If you can load your device to it, can manage it through that.
Nov 29, 2007 | RCA Lyra RD2212 MP3 Player
RCA means (Really Crappy Audio)
It seems that it is very difficult to find help from RCA. Most drivers and manuals are not available for MP3 players, and the ones that are, don't help very much and are often very generic. RCA, among other brands make disposable MP3 players that short of changing a battery or resetting it, there is nothing else that can be done. Warranty is the most important thing but when you have to send the defective unit off, they want money for shipping. I have heard of them returning your MP3 player as fixed and the minute you turn it on, it does not work. On here, we try to assist with many problems but MP3 players are often hard to diagnose as most are defective from the factory.
Oct 27, 2007 | RCA M2000 MP3 Player
RCA TH1602  MP3 Player Logo
1,566 people viewed this question
Top RCA Audio Players & Recorders Experts
Gyula Lacz
Are you a RCA Audio Player and Recorder Expert? Answer questions, earn points and help others
