Question about Panasonic PT-47WX49 47" Rear Projection Television
Our tv suddenly began showing what looks like a rainbow on the bottom third of the screen (last evening). Tonight, it is even more pronounced. What's going on?
  • dwbuechler Jan 28, 2009
    The advice was right on the mark, My husband replaced the ICs with the help of Sonny from the servicemanuals.vstore site. Our tv actually seems to have an even better picture than before. Thank you so very much for the help!
  • jfever Feb 01, 2009
    I have a PANASONIC PT-51G45CU rear projection tv...made in 1997. I would like to fix it, but don't want to put alot of money into it. If I could fix it myself, it would be great. The tv has a blue wave across bottom third of it, kinda looks like you have 3d glasses on. You can still see the whole picture on the screen all the way around, just bottom part has that blueish wave through it. Don't know what is wrong with it, could someone please help...thanks..John.
  • Panasonic Master
  • 8,617 Answers
You need to replace the convergence ICs they are both STK392-110 you can get replacement ICs at the following link and they provide free installation instructions.
http://servicemanuals.vstore.ca/
Posted on Jan 19, 2009
  • Sonny Berry
    Sonny Berry Jan 28, 2009
    Glad that I could help, I try to recommend servicemanuals.vstore all I can as they really go out of there way to help their customers which is very rare theses days. Congratulations on a job well done.
65" Mitsubishi TV
cannot get any sound at all from tv
Jan 28, 2010 | Mitsubishi WT-46805 46" Rear Projection...
Rainbow showing up at bottom and top of screen creating double and triple vision
IM GUESSING ITS A LAPTOP SCREEN OR COMPUTER IT COULD BE SOME WATER TRAPPED INSIDE OF THE SCREEN LIKE CONDENSATION WHICH COULD MAKE A PRISM OF LIGHT LIKE WHEN YOU SEE A RAINBOW BECAUSE ITS SUNNY AND RAINING
Oct 08, 2009 | Philips TV Tuner Video Capture PCI Card -...
The screen has a rainbow of red blue and green on bottom
The specs say this is a CRT type projection system, so it could be related to the display or to the TV. Since this has an SD card, it might be good to plug in the memory card with some pictures on it, and see if the problem persists with a source other than the tuner. That might at least narrow down whether you have a display failure/adjustment issue or something else.
Jul 04, 2009 | Panasonic PT-56TWD63 56 in. Rear...
Tv won't power up
Check the inverter if you do not know what a inverter is chances are you need to bring this into a shop and have this repaired as first the inverter goes then the lcd makes colorful rainbows this would be the first thing I would check.
Jun 26, 2009 | LG 42LC2D 42 in. LCD HDTV
Horizontal color line across the screen
Most likely a bad Vertical IC or bad connections on the vertical IC. don't continue trying it on. If you have a bad connection it could do more damage. You also could damage the CRT ( picture tube ). If you remove the cover and look at the bottom side of the PC bord with a good magnifiing glass you may see what looks like rings around the leads comming from the Vertical IC. The Vertical IC is mounted on a heat sink usually towards the front of the set looking from back. If you do see the rings around the leads try reheating with a solder iron. If this dosen't fix you most likely need a new IC.
Apr 15, 2009 | Televison & Video
Rainbow effect at top of screen
This is a convergence problem that can be as simple as poor solder connections on the pins of the convergence ICs or defective ICs. If you wish to attemp the repair yourself, please let me know and I'll look up the parts and provide additional details and instructions. Also, please confirm your model number.
Thanks,
Dan
Feb 18, 2009 | Samsung HLN617W 61" Rear Projection HDTV
Rainbow on the screen
Do you have any larger speakers close to you tv. Or any magnets been neer it. If you unplug it for a while the tv should have remove the rainbow
Aug 28, 2008 | Panasonic PT-53TW53 53" Rear Projection...
Cracking noise and flickering screen
Sounds like you have a bad flyback Transformer...Crackling is high voltage leaking. I would quit turning it on and replace the main board in the set if you are good at soldering you can replace the flyback transformer but cost wise it is easier to replace main board. 20" might not even be worth the repair.
Nov 02, 2007 | Insignia IS 20" TV040919 TV
Panasonic PT-47WX49 47" Rear Projection Television Logo
74 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
