Question about Hitachi 51F510 51" Rear Projection HDTV-Ready Television
Transporting can i remove the cabinet for transporting
    Champion:
  • 240 Answers
It is best not to.
Posted on Jan 13, 2009
  • 24 Answers
No the cabinet is none removable on this model.
What states honor EZPass?
Oct 22, 2015 | Video Game Consoles & Games
Disassemble for moving
Cabinet is screwed and glued construction---about all that can be removed for safe transport is entire front screen unit and the Mirror inside the set.
If decide to move in open pickup make sure screen faces front of truck and is covered---if towards the rear the air flow can pull outer screen right out.
Jun 12, 2012 | Toshiba 51H84 51" Rear Projection...
Disassemble Toshiba 65H80 tv
No, cabinet is glued and screwed---entire front screen can be removed and the mirror inside also(be very careful with that) as they are the two things that get damaged most when transporting a set.
Moving a long ways or just across town?
Apr 22, 2012 | Toshiba 65H80 65" Rear Projection...
How do i disassemble my ws-65313 for transport
Good Day,
To disassemble this TV follow these directions:
1). Pull front speaker grill off
2). Unplug the 2 cables connectors in front
3). Remove 4 screws on both sides of cabinet (might have plastic covers)
4). Carefully lift cabinet top until the support tabs clear the bottom cabinet
5). Carefully rotate the cabinet top and place back side on floor ( the mirror is on the top side)
6). Pack/wrap properly with blankets and transport in this manner.
Good Luck and Move, Big Irish.
Dec 02, 2009 | Mitsubishi WS-65313 65" Rear Projection...
Walking machine
Check the transport bolts have been removed from the rear, you should see 3 or 4 bolts on the back panel, 13mm heads, going through plastic tubes, remove the bolts and the tubes (if still there) and fit the plastic covers. If the bolts have been removed already, then there could be a problem with the springs or shock absorbers inside the cabinet.
Jul 03, 2009 | Bosch Axxis WFL 2060 Front Load Washer
Compressor makes noise and goes on and off constantly
That foam block is an anti vibration dampening device. My guess is is goes up against the underneith od that compressor. The real problem is with the short cycling compressor. I would return that piece of junk.
Jun 30, 2009 | Heating & Cooling
Anything I need to Know before disconnecting from the water & unpluging the MSD2454GRW for a move to a new location?
CM,
Yeah, there are a couple of things. DON'T lay it on its' side during transport or storage. Tipping it onto a hand truck is OK. You may also want to take this time to clean it real well. Do this by taking it outside and removing the lower rear panel. (WITH THE UNIT UNPLUGGED, OF COURSE) You can safely use a garden hose to spray into the unit compartment and thoroughly clean it all out. You can even spray down the interior compartments of the fridge and freezer areas. Allow it to dry completely before plugging it back in (approx. 24 hours).
Another thing, securely tape down all shelves and drawers inside the cabinet, you don't want them coming loose and breaking. Either that, or transport them separately.
That's all there is to it!
SG
Apr 11, 2009 | Maytag Refrigerators
URGENT~no clue how to reinstall transport bolts for moving washer
The long one go on the bottom and the short one go on top the hole for the shipping bolts are on the back might have a clear plastic cover over the holes on the back panel there is only one way to put them in start by hand tighten the bolts with nothing in the drum the holes should line up one you fill the catch and get hard to turn start using a wrench when it is done try shaking the inner tub it should not move all the shipping bolts do is keep the tub from slapping around inside the cabinet and breaking things Good luck
Apr 03, 2009 | Washing Machines
How do i move my wurlitzer 1015 cd one more time
I take it you wish to transport your jukebox.
If this is the case I would remove all the CD's (keep them in the order that they were on the jukebox for installation again)
The jukebox mechanism will have some form of tie down system that locks down the mechanism tight into cabinet.
Check the power supply, amplifier etc to see if they pull off their mounts. If they do usually on these parts are holes to insert wood screws to lock them down (use the correct length of screw so they do not damage the cabinet) On the title racks or tubes tape them down so they do not come loose in the cabinet.
Try if at possible to transport the jukebox upright in or on the vehical, cover the jukebox with blankets before strapping to the vehical.
Regards
Alan Hood
ami-man
UK
Jan 17, 2009 | Wurlitzer Jukebox 1015 One More Time...
Cd tray stuck closed
open the cabinet and remove the magnetic lock placed on the top of the mechanism then u can remove the cd
Jan 02, 2008 | Yamaha GX-505 CD Shelf System
Hitachi 51F510 51" Rear Projection HDTV-Ready Television Logo
49 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
