Question about HP OfficeJet J4580 All-In-One Laser Printer
Printer says it's jammed with each and every copy.
The copy is complete and very readable but the paper does not exit the machine and stops about halfway out. The machine is three days old.
  • 1 more comment
  • Anonymous Jan 28, 2009
    • I have checked front and back of printer and finde no jam. When I press OK button paper is drowen in and jams half way through. Have also tried turnning off then back on with no seccuss.
  • Anonymous Feb 01, 2009
    my printer said paper jam and no paper is in it
  • jibreelr Apr 25, 2009
    every time i start the printer it displays the message "clear paper jam and press ok" though there isnt any paper in the printer. tried unplugging and pressing # and 6 for one minute while replugging. this did not solve the problem. please help.
  • 55 Answers
It sounds like you printer does not know what size paper it has in the paper tray. Go into the menu and reset the paper size, If your printer is only 3 days old, Ihope the manuel is still around.
Good luck
Posted on Jan 28, 2009
    Scholar:
  • 97 Answers
Please follow the follwoing steps,
1) unplug the power cord at the both ends from the printer and wall outlet. connect to wall out let directly dont connect to
printer.
2)Press and hold # and 6 while reconnecting the power cord to the product hold for 1 min after plugging the power cord, and
then release both buttons, this should resolve the issue.
Regards,  raj_p5983
Posted on Jan 29, 2009
Exit jam
have the machine perform a paper path test with just 1 copy to see if this jams then have it path test 5 prints to see when it jams- if its only jamming when more than one sheet is being printed then the fault lies with the paper pick up ( you may notice a longer delay for first print)
the machine will attemp to feed three times before failing as a jam
if the machine is printing more than one sheet then the jam appears just before the tail end of the first print exits the fuser (fixing Unit).
clean or replace the feed rollers.
if the jam happens on every print and the code is 13:02/3
then paper pass sensor arm 2 has stuck (look on you tube to resolve this search for lj4200 13:02 jam)
hope this helps- if you are still unable to get the machine working and your willing to pay then I would suggest Belmonte Buisiness machines
are a good company to deal with they are on 0161 480 5556 and can call out anywhere in the UK
Jan 26, 2014 | HP LaserJet 4250n Printer
I keep getting the Unable to clean message, even after cleaning manually. Is my printer about to go to printer heaven?
Resetting purge counter:
1) Enter machine maintenance mode (on MFC210C all four photo/copy/fax/scan lights flash in maintenance mode). Care is needed in maintenance mode, otherwise critical settings may be inadvertently corrupted.
FAX models with numerical keypads: Press the Menu/Set, *, 2, 8, 6 and 4 keys within two seconds. (if you fail to complete the correct key sequence within two seconds, press the Stop key to try again).
Other (non-FAX) models: Press the Menu/Set and Black Start keys. Next press the "up arrow" key four times to enter the maintenance mode).
2) Press the 8 then 0 keys in the initial stage of the maintenance mode to call up the machine's log information list (function code 80).
3) Press the Black Start key several times to scroll through the log information list to reach the purge counter. The purge counter is the 25th item in the list.
4) Press the 2, 7, 8, and 3 keys in this order to reset the purge count to zero.
5) Press the Stop/Exit key to return to the initial stage of the maintenance mode.
6) Press the 9 key twice to return to the standby state.
Mar 31, 2011 | Brother MFC 420CN All-In-One InkJet...
I REMOVE THE JAMMED COPY. PRINTER STARTS AGAIN AND JAMS UP AGAIN ON THE VERY NEXT COPY. COPY SEEMS TO BE MADE BUT CAN'T GET OUT OF THE EXIT
Jam may not be completely cleared or paper is not suitable for your printer.
You can find your User Guide, an Educational Guide on the paper which is compatible with your printer and updated Drivers here:
http://my.okidata.com/PP-B4350.nsf?opendatabase
In the Troubleshooting section of the User Guide (page 74 of the English version) there is a section on dealing with Paper Jams. Make sure you have cleared all areas and that your paper is compatible.
Trust this is helpful. Please vote.
Dec 25, 2010 | OKI B4350 Laser Printer
My 2600n laser printer had a paper jam in the outbox bin. I took the stuck paper out and had a look inside. I see no other paper jam but the printer keeps telling me I have a paper jam in the outbox. ...
There is a sensor flag (little black peice) that hangs down in the paper path as the paper exits. The flag tells the printer if the paper has made it out or not. That sounds like your problem. Just in case it is something else, her's a copy of the complete service manual for your printer. Start on page 90 (pdf page 113) and it goes thru the jam areas.
http://www.feedroller.com/Store/Service%20Manual/HP%20Color%20LaserJet%202600N%20(Q6455A)%20Parts,%20Service%20Manual.pdf
Nov 16, 2009 | HP Office Equipment & Supplies
How do I fix a paper jam? I've got paper jam around the exit roller and I can't get it out?
There should be a way to unlock one of the sides. Try taking out the toner cartridge and going in that way. If you can see the paper, get a pair of needle nose pliers and SLOWLY see if you can pull the paper out.
Sep 21, 2009 | Samsung CLP-510 Laser Printer
When we put paper in the printer it goes cricked
Lexmark printer have paper roller problem take printer for once service
Jul 25, 2009 | Lexmark X1270 All-In-One InkJet Printer
Paper Jam light on, but no paper jam
A piece of paper torn from copy paper is caught around registration switch, exit switch or feedshift switch.
so check theme.
Jan 18, 2009 | Sharp AL 1631 Copier
Sharp-275 Not a simple paper jam
This sounds like you may have a bad jam detect sensor, there is a sensor on the exit end of the fuser on the right and the flag for this is located in the middle of the exit guide on the fuser this gives us most of those types of jams.
Hope that helps...
Jun 16, 2008 | Sharp AR-275 Copier
HP OfficeJet J4580 All-In-One Laser Printer Logo
138 people viewed this question
Seeker5211
Seeker5211
