who cares if it is the proper voltage,amps and plug. . you need a wall wart , the plastic box with two flat blades sticking out that 12volts DC center positive ,700 milliampsfor the non negatine scanner and 1 amp(1000 milliamps) for thr negative scanneer model an AC/DC adapter look around at 2nd hand stores they usually have a selestion or order online from electronics supplier
the alarm instructions i have say it is a astra sa 100 alarm. the wiring diagram looks like the...
(More)
the alarm instructions i have say it is a astra sa 100 alarm. the wiring diagram looks like the harness. the back on the control unit has different locations listed for the wiring? it say sa200 on the unit? which should i go by?
My Astra 3400 was working fine for all these years ... suddenly recently I keep getting...
(More)
My Astra 3400 was working fine for all these years ... suddenly recently I keep getting "Scanner Link Fail" ... Scanner was powered on before system start ... what could be the problem? Bala
The rear seat safety belts are trapped in the back seat where I folded it forward and back on top of...
(More)
The rear seat safety belts are trapped in the back seat where I folded it forward and back on top of them. I cannot now fold the back seat forward as it is jammed (the wider one). How to I undo the back panel to get at where the belts are trapped?
