Question about Compaq Presario Notebook
My compaq laptop will not boot up
The laptop will turn on and show the compaq logo but will not boot up all the way to windows
  • 6 more comments
  • teddy4 Jan 14, 2009
    No beeps!!
  • asad420 Jan 14, 2009
    yes i have the same problem when i tried to install win xp in it . after loading the system files and restarting the logo appears and no work can be performed. so i had to stop installing win xp,also if i insert vista cd and restarts, that logo remain and no work can be performed
    posted by -HAMMAD AFTAB
    No that did not work. It looks like the laptop is trying to boot up from the "PCI Fast Ethernet Controller v2.13 (020326)
    Media Test Failure Check Cable
    Existing PXE Rom. This shows up on the screen and then the screen goes black. The symble (-) shows up in the upper left hand corner and repeats itself with the above message on the screen.
    I am in the Phoenix BIOS Setup Utility advanced mode and there are four options:
    floppy Diskette Drive
    ATAP CD-ROM Drive
    +Hard Drive
    Network Adaptor
    At this point I am not sure what to do.
    I just checked my boot menu and it does show HDD. It only shows
    1. Floopy Diskette Drive
    2. ATAPI CD-ROM Drive
    3. Network Adaptor
  • teddy4 Jan 15, 2009
    How do I look through the sata or ide settings?
  • Jason Edinger May 11, 2010
    Try this. Take the battery out. Unplug the laptop. Hold the power button down for 10 seconds. Put the battery back in, plug it in. Try turning it on.
    Any beeps?
  • 124 Answers
When you boot again, press whatever button it is to get into the bios, Delete, F10, whatever. Look for Boot Options. Make sure HDD is BEFORE Lan adapter/network.
Posted on Jan 14, 2009
  • Jason Edinger Jan 14, 2009
    As long as HDD is there before network adapter, you should be able to boot.
    If it doesn't, look through the sata or ide settings and make sure those are enabled.
How do I change the boot order ? It some how changed after I formatted the hard drive it turns on but it wont read install cd or flash drive so can any one help me ?
Enter BOS setup
F1 or F10 Enter Setup at the red Compaq logo or blue HP logo
Boot menu Below is a summary of what is contained on the Boot tab of the BIOS Setup:
  • The order for the bottom process; for example: Removable devices, CD ROM, and hard drive.
  • Boot-time Diagnostic screen
strongly urge to update bios too when possible.
Apr 01, 2016 | HP Compaq Cq60-211dx Intel Celeron...
My Acer aspire turns on shows windows logo then goes to black screen, what can I do?
Depending on your version of windows, I would trying starting in safe mode to see if the computer does boot. If it does, then you want to restart again, go to advanced boot options and select "start windows with last known good configuration." Access advanced boot options following the steps at this link. Need to Start Windows 7 in Safe Mode Here How
Jul 18, 2015 | Acer Computers & Internet
I tried to clean the dell vostro 1014 fan, after i assembled the fan and turned on the laptop it appear black screen with dim image on my laptop screen, When I plug in external monitor it shows boot s
It sounsd like your GPU may be BGA chip and would require a re-flow/re-ball if your laptop shows graphical distortion on both monitors.
However I would first try taking the laptop apart again and double check you have connected everything properly.
Mar 20, 2014 | Dell Vostro 1014 Laptop Computer
How to let boot screen show on external monitor
Press Fn key and hold, now look for the icon that shows laptop and monitor screen on the top F keys and press this will switch to external monitor.
May 27, 2012 | Compaq Presario Computers & Internet
Hi i have a compaq presario laptop and after it stars up the screen just goes blank
do you still see the compaq logo and does it show you the windows boot up screen before it goes blank?
OR
do you see anything on the screen at all after pressing the power button?
Check if the laptop is receiving power. If it has power and you can't see anything on the screen it could mean that the LCD assembly or the Video card of your laptop is bad.
If it goes to the compaq screen and then to windows logo before going out, try booting into safe mode and once there uninstall the video driver from the device manager because that means the resolution was set to something higher than the display could handle.
If it restarts after showing the compaq screen try reseating the memory, hard drive and wireless card of your computer put them one by one and try turning the compter on after each part you put back to check which component is point of failure.
Otherwise you have a bad motherboard and it may have to be replaced.
Hope this helps!
Jul 27, 2011 | Compaq Presario 700 470024-192 Notebook
Just got cq56-115dx laptop this morning. turned it off after setting it up. Turned it back on and only have blank screen. Power shows lit up.
Hi.
Remove the AC power (charger) and then take the battery out. Plug in just the AC power supply and turn the laptop on, see if it boots up and shows a display on-screen. If it boots let it boot up and then shut it down as normal. Reinsert the battery and try as normal.
If you still get a blank screen can you then tell me if you get any post (splash) information like the Compaq Presario logo before it goes blank.
Good luck.
Jun 28, 2011 | Compaq Presario CQ56-115DX Laptop
Windows dosent start
go n format it by using a recovery drive...there may be a start up errors occured in windows
Apr 26, 2009 | HP Compaq nx6310 Notebook
Error Code
All you can do is Reinstall windows. You should get the Windows Vista Installation CD with your laptop and all you have to do is put it in and restart your computer and when the message that says "Press any key to boot from CD" press a key.
If it doesn't show up, you may have to press a key like DEL or F12 to get the boot sequencer. When you first turn on the computer you should see the Compaq logo. At the bottom of the screen you should see some buttons to press to do things like BIOS and Boot Sequence. You want Boot Sequence. Once in boot sequence, select the CD-DVD and press any key when it says to.
Once in follow instructions or oyu can reply and i will tell you how to install.
Oct 06, 2008 | Compaq Computers & Internet
My compaq armada 3500 wont boot up or only shows the welcome compaq logo
I think that has to do with the BIOS if it cant boot compeletly. Try pressing the key indicated to enter into SETUP if you cant just try and look for a jumper on the motherboard that is written CMOS it may be a button or something.
Jul 18, 2007 | Compaq Armada 3500 Notebook
Compaq Presario Notebook Logo
315 people viewed this question
Top Compaq Computers & Internet Experts
Alun Cox
Abhinandan  Patil
Abhinandan Patil
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
