Question about KitchenAid 24 in. KUDS01FLBL Built-in Dishwasher
KitchenAid dishwasher overflowing; water will not stop coming in
My dishwasher overflows because the water coming into the dishwasher will not turn off (even with dishwasher turned off). I have checked the float switch and it isn't stuck.
  • fenn1978 Jan 14, 2009
    Where is the valve and is it easy to replace?
    Thanks...found it!
    New Friend:
  • 88 Answers
If it is filling when the dishwasher is off then you need a new water valve.
Posted on Jan 14, 2009
  • Dean Rhymer
    Dean Rhymer Jan 14, 2009
    when you open the bottom panel it should be right in the front on the left side. I can be a pain because of the little amount of space the is usually 2 screws thats about it . good luck. oh yeah turn the water off lol.
I have a lg dishwasher and it ran for an hour and a half and then displayed E1 on it. Then, it would not stop running and wouldnt even turn off so i had to turn it off by the breaker. any solutions?
(1) The water inlet valve is an electrically-controlled valve that opens to allow water to enter the dishwasher. Depending on the model, the valve stays open either for a set length of time or until the dishwasher has enough water. However, if the water inlet valve doesn't shut off after the dishwasher has enough water, the dishwasher will overflow. If water drips into the dishwasher when the door is open, or if water collects at the bottom of the dishwasher while it is not use, you may need to replace the water inlet valve.
(2) The float switch actuates in order to prevent the dishwasher from overflowing. If the float switch is defective or stuck, it might not stop the dishwasher from overflowing. If the float switch is defective, replace it.
One would need the model number of your machine.
Dec 31, 2015 | LG Dishwashers
Intake/Drain lit flashing
I have exact same symptons, please someone help. I have had issue before where the plumbing backed up so it overflowed into the catch tray. Then that has to be vacummed out and then just start a new cycle. This time there is no water in the overflow tray....
May 28, 2010 | Miele 18 in. G601SC Plus Slim-Line...
Water overflows from dishwasher.
The most common cause of a Sears Kenmore dishwasher over flowing is a fail "float" switch that detects when the water has reached the proper level.
If you want more directions, please post back here and we will take the next steps. OK?
Apr 09, 2009 | KitchenAid 24 in. KUDI02IRBS Stainless...
Water keeps running into dishwasher causing overflow
I had a diswasher with thils problem several years ago. The problem was wiith the plastic float at the bottom. It had hardend greese buildup that kept the float from moving freely. Removing the float and cleanning fixed the problem.
Jan 29, 2009 | KitchenAid Dishwashers
Water into dishwasher tub wont shut off resulting in overflows
Hi susan. the problem is with the water valve, which is located behind the bottom plate, of the dishwasher. remove . water valve, is on the left. thanks the appliance doc
Oct 06, 2008 | KitchenAid Dishwashers
Leak from dishwasher fill funnel
Hi . the air gap is required by law, to have it there.to stop water in the tub, to end up in your water system, which would never happen. try setting the pressure down, and use the dishwasher. it should work fine . turn down taps ,till it stops leaking . should be ok
Oct 06, 2008 | Kenmore 15129 Built-in Dishwasher
My dishlex dishwasher overflows
The only part that physically allows water to enter a dishwasher (upon receiving power from the control) is the inlet water-valve. I would test the inlet water-valve located directly where you in-coming water line is connected to.
Shut-off power to the dishwasher and remove the 2 prong connection to the water-valve solenoid (small, black, batter size). Test the solenoid for continuity; if bad, replace the entire inlet water-valve (cost about $20)
Jun 15, 2008 | Candy 24 in. CD623 Free-standing...
Over flowing
My dishwasher will not drain sometimes and overflow other times. What can I do to solve this problem?
May 27, 2008 | KitchenAid 24 in. KUDG25SH Built-in...
KitchenAid 24 in. KUDS01FLBL Built-in Dishwasher Logo
817 people viewed this question
Top KitchenAid Dishwashers Experts
Mike
Are you a KitchenAid Dishwasher Expert? Answer questions, earn points and help others
