Question about Braun Tassimo Espresso Machine/Coffee Maker
Tassimo won't work automatically.
I have cleaned the scanner and changed the disk. Will only work manually. Is there some way to reset? What should I do?
  • Anonymous Jan 23, 2009
    The automatic light does not come on and to make coffee we need to hold down the manual button - effective but a pain in the ****.
  • 3 Answers
Just hold the button pressed down(i suppose you didnt know that) and wait until your cup is filled as you like to have it(in manual mode, you have to hold the button down, not just press it once).
[OT:] I would like to have it that way, because the espresso is not strong enough in my opinion, i would use less water...
Posted on Jan 23, 2009
Panasonic Hi-speed scanner
I am not sure if you have the manual for it so here it is just in case.
http://service.us.panasonic.com/OPERMANPDF/KVS2026C.PDF
Since there are many steps to opening it to clean, the problem may be reassembling it. You can also unplug it and leave it off for 30 minutes to reset its internal memory. You can also press Start and hold it for 5 sec and do the same with the menu button. If after trying this, your machine does not reset, let me know.
Nov 18, 2007 | Panasonic KV-S2026C Pass-Through Scanner
Can't get my VuPont model PDS-ST410A-VP to scan properly. I get black pictures. Tried the white balance calibration and the red light doesn't go off. Tried changing the batteries and taking out...
Welcome to Fixya
Check all the settings. Press the DP button and select high resolution. Press the C/BW button and select Color is you are scanning pictures. Clean the lens using a soft cloth and start scanning again. Re-install the software disk that came with it.
Thank you for using Fixya!
Apr 14, 2011 | VuPoint PDSST410VP
I HAVE A PRO-2096 DIGITAL TRUNKING BASE SCANNER. IT HAS WORKED FINE BUT NOW IT READS " ALL CHANNELS LOCKED OUT " NEED HELP
need to do a RESET. Then try your local WX frequency to verify it works. The RESET will wipe out all existing programming, just to warn you. Check your manual, or RadioShack.com for details.
Jan 12, 2010 | Radio Shack Pro-2096 Base Scanner
Do i need more than just the drivers installed in order for the scanner to work? ie. Do I need the kodak software?
You will need the install disk to have your copier, scanner, etc to work properly\
You can contact the manufacturer for the installation disk or re install using the disk provided with the unit.
this should restore the scanner operation if you have lost that function.
2. check the user's manual for specific instruction on the scanner usage.
Jan 06, 2010 | Kodak ESP 3 Multifunction Printer/ Copier/...
While on it gives an error massage no scanner option hp officejet 4355 all in one
May be your printer's scanner part does not work properly.
Check Scanner Motor
Clean the disk of the scanner motor.
and try again
If not solved your problem you need to change scanner unit.
Thanks
Sk. Abdus Sabur
Nov 30, 2009 | HP Officejet 4355 All-In-One InkJet...
Reinstall the scanner
The printer my have corrupt the setup of your scanner. So try and uninstall the setup properly and install it again.
How to unistall go to your control panel-Double click on Add or remove programs-then click on the scanner's setup then click on remove or change.
LATEEF FOR FIXYA
May 14, 2009 | Fujitsu fi-5110C ScanMaker Scanner
Proble with HP laserjet 3330
You will have to have the scanner assembly replaced. There were some problems with the earlier versions and they have seen been rectified. I have not had a single one come back in after replacing it.
Jun 01, 2008 | HP LaserJet 3330 All-In-One Printer
Braun Tassimo Espresso Machine/Coffee Maker Logo
1,428 people viewed this question
Top Braun Coffee Makers & Espresso Machines Experts
Oloyede Monsuru
ellipse0904
Level 1 Expert
Are you a Braun Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
