Question about Dell Inkjet 720 Printer
My dell 720 printer
Everytime i turn it on it slams back and forth and the green light flashed twice off and on. what is wrong with it? i have only had it for two years and hardly never used it.
  • Anonymous Nov 04, 2007
    I have the same problem after attempting to replace the cartridges. When I opened the lid a plastic cable (for the lack of a better description) ~14" long, ~3/16" wide, with slots on either end, an arrow and "K-06" on it was loose inside. Further investigation, a spring on the right-hand side of the printer where the cartridge shuttle travels was not connected to anything.
    I'm thinking the plastic cable is should be attached to the spring through the shuttle and attached on the other side, and help slow the shuttle travel. But none of the Dell documenation is detailed enough to describe this peice. Where can I find a detail schematic of the printer?
    Thanks.
    President:
  • 2,961 Answers
Normally thats a sign of a printer driver error, remove the printer and go to add/remove programmes and remove the dell/lexmark printer driver. You will need your installation cd you got with the printer, so re install the software/driver and then re connect the printer when promped and try printing again. The drivers can be downloaded from here if you have no cdrom, but if the solution doesnt work, then the printer may need replacing, as it's not economical to repair. http://support.euro.dell.com/support/downloads/driverslist.aspx?c=uk&l=en&s=gen&ServiceTag=&SystemID=PRN_INKJET_720&os=WW1&osl=en&catid=&impid=
Posted on Jun 12, 2007
Dell1110 Laser Printer. Changed Cartridge - New Fuse - Checked twice Simpson 260 No blown fuses on circuit board. (1) Fuse, (2) wire. No burn spots Red & Green lights blink after 10 sec of OR/GR...
If you have flashing RED and GREEN LEDs on your Dell 1110 your printer will need servicing by the Dell service department. It is hard to say what is wrong without looking at the printer in person but those two lights together spell trouble not easily fixed. It could be a damaged circuit board or component. This typically has nothing to do with ink, paper jams, etc.
Regards, Chris
Aug 17, 2011 | Dell 1110 Laser Printer
My lexmark blinks green but wont turn on everytime i try to turn it on it just spins for a second and goes right back to blink mode
The flashing green light probably means communication error, it is not normal.
These Dell/Lexmark comm. errors can be difficult.
Try this:
Start > Control Panel > Printers2_bing.gif and Faxes > RtClick Your Printer (default) > Properties > Advanced (on mine) > Check "Print Directly to Printer"
Feb 12, 2010 | Lexmark Z2420 Printer
Dell 720 printer. Printer has been getting
There is a small rubber belt that moves the print head back and forth. If it is out of alignment it may seem to fly too quickly across the silver track to the opposite side of the printer making a big "thunk" when it hits! This usually happens right after changing a cartridge and USUALLY fixes itself. Don't worry, the printer won't break from it.
Next, the print becoming lighter may just be the print head wearing out. If you've tried the print head cleaning procedure that is included with the software and it's still too light, it's likely that you use the printer heavily and it's just worn out. If that is the case, I would highly recommend a printer that is designed for heavier usage. It will cost a little more, but the print cartridges are about the same price, they usually print a little faster, and they last about 5 times longer than a standard consumer version.
Lastly, if you installed Explorer 7 and are having problems, you need to make sure you have the appropriately up-to-date operating system software. You don't necessarily need the newest version of Windows for example, but you need to make sure that the service pack for your current software is up to date. Explorer 7 doesn't seem to work and play well with old Windows versions and older Mac OS.
Hope this helps!
Jan 12, 2010 | Office Equipment & Supplies
Printer won't print, on-off light flashes on-off
I have the same issue....two flashes of the light on the power button the repeat. The carrier is clear, so I don't know what else to do. Also, when I turn the power on, the carrier goes back and forth, hitting the sides very LOUDLY! Anyone else having this issue? This printer is a few years old, so no warranty, and of course, I just bought replacment ink for it, so now it won't work..worked fine till the ink ran out this time! PLEASE HELP!
Dec 05, 2008 | Dell Inkjet 720 Printer
Cartridge slams
That piece of plastic that is out of the machine helps the print head to know where its at on the paper think of it as a guide of a sort you may be able to place it back in.I wouldn't turn the printer back on until the part is put back in you may damage it beyond repair.
Aug 11, 2008 | Dell Inkjet 720 Printer
A Ghost Shadow appears when using the flash
you can turn down the intensity of the flash using the flash+/- in the menu
Jul 07, 2008 | Olympus Stylus 720 SW Digital Camera
Dell 720 Printer
your printer has a hardware part broken to fix it plz take it to your vendor.
Jun 24, 2008 | Dell Inkjet 720 Printer
Cartridge Stalled Error
Sounds like some muck on the guide bar or perhaps a bit of paper getting in the way ..
Nov 06, 2007 | Dell Inkjet 720 Printer
Dell 720 printer
Replace the printer- there are no professional repair options here You could take a look at www.fixyourownprinter.com
Jun 12, 2007 | Dell Inkjet 720 Printer
Dell 922 printer giving error code 1200
I get error 1200 and print carrier stall.  The carrier moves fine when I turn it on, in fact it slams to the right!  Will not print at all!
Mar 23, 2007 | Dell 922 All-In-One InkJet Printer
Dell Inkjet 720 Printer Logo
62 people viewed this question
Top Dell Office Equipment & Supplies Experts
David Patricia James
Marvin
Marvin
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
