HI We have a Mag LCd Monitor and the color is turning green is that a sign we need to buy a new one
  • 38 Answers
You can try replacing the VGA cable first or wiggleing it to see if it goes in and out, if that doesnt resolve your issue then replace the monitor.
Posted on Jan 13, 2009
My monitor fell on the floor and now my color is off. the color is darker on the left of the screen. Do I need a new monitor now?
I suggest you to buy a new monitor because it will be expensive to replace the LCD. You monitor LCD is damage that is reason why there is a dark color on the left screen.
To avoid any harmful accident in the future. Because it will create electrical spark inside the monitor which will be burn out the entire monitor or maybe result to smoke. There is no remedy in that particular trouble but to replace the entire LCD. But this is not advisable because it will cause you expensive cost of repair.
You need to buy new monitor and I suggest if you buy new monitor. Buy LED monitor which is better than LCD. LED monitor is a green campaign of every manufacturer due to energy saving specification and have a better graphics than LCD...
Hope this will help you a lot. If you any other question please don't hesitate to contact me
Sep 16, 2011 | eMachines E211H Monitor
After display goes black monitor green power light remains ON. Power can be turned of and the display again stays on approximately 5 seconds. Replacing capacitors in power supply did not correct the...
The problem can be the lamps are bad, the only way to tell is to remove the lamps, look for poor soldering works where the wires are attached to the lamps, bad lamps will have very dark color at the end of the lamps, just like bad fluorescent lamp you see when it is worn out, anoher sign of bad lamp is pinkish glow when lamp si first turn on. The transistors and caps are good in the inverter section?
Jan 02, 2010 | Mag Innovision LT782S 17" Flat Panel LCD...
When turn on color is great..after a few minutes turn blue and green
Sounds like the lcd is bad but here is a way to verify that. Hook up a known working monitor to the computer, if the colors stay great after a few minutes then you know the original monitor is good.
If the colors turn blue and green after a few minutes with the working monitor then you know for sure that the video card is bad and the video card would need to be replaced.
Aug 23, 2009 | Vision V1721B (Black) 17 inch LCD Monitor
Power is on but no picture!
Hi...there,
It's seems you guys had a bad lucks! Your backlight inverter are busted. Need to replaced a new inverter...Guys! Have a nice day!
Sep 27, 2008 | Mag Innovision 19" LCD Flat-Panel Monitor...
Mag lcd monitor
probably capacytor problem in the mainboard, take it to the lab it will be cheaper then buying new one
May 06, 2008 | Mag Innovision LT782S 17" Flat Panel LCD...
19" Mag Monitor turns 0ff by itself
Hi...there,
All you guys need a new backlight inverter... Your old inverter are busted!
Apr 16, 2008 | Mag Innovision 19" LCD Flat-Panel Monitor...
Color problem MAG Innovision 14" monitor
1. try to connect to another computer . if it is fairly good then it must be your computer is having a problem.may be your video card problem.
Mar 21, 2008 | Mag Innovision lt456s 14" Flat Panel LCD...
Monitor problem
my monitor is 17'' lcd...... mag innovision model: LT716s..before was working well but now the lcd monitor don't to turn or either the led doesn't turn or make any sign.... no matter whta the lcd stay blak,,,,,do not want to turn on....
Dec 31, 2007 | Mag Innovision LT976S 19" Flat Panel LCD...
I think it's busted
you need to open the case and check the capacitors and if they seem doomed or color is leaking then replace the bad ones that should stabilize the power to the vertical ic chip
Nov 20, 2007 | Mag Innovision LT782S 17" Flat Panel LCD...
Mag Monitor LT982s model900p
Hi, Try this link http://www.pchub.com/uph/category/43/LCD-Inverter.html In some instances inverters for other brand/model will also work for your Mag. You just have to match the part number. Good luck and kind regards.
Oct 02, 2007 | Mag Innovision LT982s 19" Flat Panel LCD...
Computers & Internet Logo
61 people viewed this question
David Payne
David Payne
