Question about Kirby Generation 3 Bagged Upright Vacuum
Kirby G3 - jump - skip problem
I can't figure out why my vacuumm does and jumpy - skip several times when I push it forward. It is very irritating. I've tried different level settings, etc. but nothing seems to work. Has anyone else had this problem? What can I do differently?
  • 3 more comments
  • Anonymous Jan 04, 2008
    my GEN 3 does the same thing. It skips when you push it foward
  • Anonymous Apr 01, 2008
    Yes i do, I have a gen 3 also and it skips while pushing foward.
  • CANRN May 06, 2008
    I have the same problem, no help from a dealer at all. We tried changing the brush, raising the level of the sweeper, no help. It's frustrating. One repair person called it "chatter". I'm about to by a Dyson.
  • knlutz Jun 28, 2008
    i have had the same problem 2x. the first time i had it fixed at a mom and pop vac store and he rigged it with a replacement piece from a gen4. it worked for quite a few years, then back to the same old thing. my local kirby man fixed it 15 minutes with the right piece. he diagnosed the problem as a transmission problem, a problem with the drive/neutral mechanism. $23 i was out the door. he even let me watch him, so if it happens again, i can adjust it myself with just a screwdriver. just tell you kirby guy it is a transmission issue, and in my case, fixed with a thin metal screw in piece.
  • Vermontique Nov 26, 2008
    My Kirby no longer moves forward or backward. It seems that it is stuck in neutral. Any ideas how I can disassemble and check the 'transmission'? I am suspecting a failed switch.
Skipping or no drive to Kirby G3. My G3 stopped driving forword/backwords the other day. So I decided to strip the drive unit down in the gearbox there is a drive belt which has snapped so requires replacing which I will do, As for jumping it could possibly be there are some teeth missing on the same drive belt. It's worth having a look.
This is not for the faint hearted as there are a lot of bits to remove.
TOOLS REQUIRED.
CROSSHEAD SCREWDRIVER
FLAT BLADE SCREWDRIVER
TORX SCREWDIVER T20
1 Remove all attachements (Bag,Brush assm & Handle).
2 Remove crosshead screw above nuteral/drive switch at rear gently insert a flat blade screwdriver in the slot above the on/off switch and push in while lifting the plastic cover at the rear where you have just removed the screw.
TOP COVER
3 Remove top cover, 4 Screws hold this on,2 under the front light cover at the top and 2 at the rear where you have just taken the plastic cover off.
Check dive belt from center of the main drive motor to the g/box ( If any damage or wear replace.If teeth missing this could be the reason for jumping and you may not need to go any further).
4 With a flatblade screwdriver gently prise off the on/off switch and leave it to dangle.
Now we need to get the Gearbox out.
Turn the machine over.
1 Remove the three T20 screws NOT THE Crosshead.
2 Remove G/Box ( It's a bit tight but it will come out ).
Looking from the rear.
3 In the center of the g/box there is the clutch assembly,remove the 'c' clip at the side of the clutch and reomve the crosshead screw ( Take care not to lose the washer).
4 Remove the crosshead screw from the base of the unit (see item 1) pull the drive/nuteral switch out.
5 Remove the 2 Torx screws holding the wheel assembly and remove assembly.
6 Turn unit over and remove the torx screw from the unit.
7 Turn the g/box over and Gently open the g/box taking care not to lose anything.
You should see 3 wheels 1 at the top and 2 at the bottom, the 2 at the bottom should have a belt joining them together ( on mine it was wrapped around just one of the gears).
8 Replace the belt and reassemble in reverse order.
Hope this helps I will try and get a video done and put it on u tube.
Posted on Jan 17, 2009
Also have you got the switch on n under the power switch
Posted on Apr 12, 2008
Hi, Try logging your post on the Kirby Trading Forum at Kirbydirect.co.uk - you'll be sure to get a reply. John
Posted on Aug 06, 2007
Can't figure out how to attach hose from plastic shampoo container to vacuum
The below link is to a Kirby site that provides a video for attaching the shampooer. Very informative.
http://www.kirby.com/Portals/0/videos.html
Jan 22, 2011 | Kirby Shampooer Shampoo Hose G3 Ultimate...
My Vacuumm kirby hertiage made a funny noise and started to smoke and doesn't work.
Remove the cover and change the belt it may have got a rock stuck in the beater bar(brush)
Sep 12, 2009 | Kirby Heritage II Vacuum
Kirby g3 tech drive
so when u pull it back it's like it's not engaged at all? then it maybe the reverse is out....with the fwd soon to follow. remember the vac is 20yrs old; & working that long? it definately served it's purpose.
depending how much money you wanna spend on it buying a new or used trans. plus labor...or just an ebay used unit.
Mar 31, 2009 | Kirby Generation 3 Bagged Upright Vacuum
Kirby G3, no manual & would like to shampoo
I have the same issue...just got a used G3...but no manual. If you go to the Kirby website, there are videos on several issues...may help.
Mar 15, 2009 | Vacuums
Kirby 3g
Here's a link on how to adjust the transmission on the kirby...the kirby pictured is a G4 or 5 but it is the same transmission as the G3
http://www.greatvacs.com/Kirby%20Transmission%20Adj.shtml
Hope this helps!!!
Mar 09, 2008 | Kirby Generation 3 Bagged Upright Vacuum
Hopping - jumping - skipping - bouncing
It could be that you have the brush settings wrong for your carpet type. Check if the brushes are on number 3, if so, try dropping them down a notch or two and see if that does it. I think that the brushes when spinning spin towards you, so when pulling the vacuum back, the brushes are helping to drive, when pushing forward, you are pushing against the brushes. If the brushes are sticking out too far, it could cause bouncing/jumping. HTH :)
May 23, 2007 | Kirby G6 Bagged Upright Vacuum
Kirby Generation 3 Bagged Upright Vacuum Logo
651 people viewed this question
Top Kirby Vacuums Experts
Jim Parker
Jim Parker
Richard Agent
Are you a Kirby Vacuum Expert? Answer questions, earn points and help others
