Question about Westinghouse LCM-19v1 Monitor
Westinghouse lcm 19w4 has to be used in brightest mode or
My monitor that is a couple of years old has bright bars that run up and down the screen kind of like the old tvs use to do when the vsync was out of focus, if I put it on the brightest setting the bars are unseeable, is there a fix for this?
I had this same problem and going through the on-screen menus I found a reset option. I reset the monitor settings and the scrolling bars went away. I plan to leave it powered up for a while to see if they come back.
Posted on May 31, 2009
Lcd-17v8 monitor power won't stay on. westinghouse monitor
If the monitor turns on and goes directly to sleep, or it powers on briefly and shows an image then goes black then the monitor is defective. The first is often an I/O panel issue inside of the monitor. The second is typically a lamp failure within the monitor.
A simple test would be to plug a different monitor into your computer or this monitor into another computer. If the monitor doesn't work on another computer or a different monitor works on the same computer then the monitor is the issue.
If the different monitor does not work on the same computer or this monitor does work on a different computer then something on the computer is to be suspected such as a driver issue or a faulty video card.
If you find the monitor is defective then you should dispose of it (assuming it is not under warranty) at a nearby recycling center and purchase a new monitor. I would suggest something by Acer, Samsung, Dell, HP, NEC, or Viewsonic. These brands cost a bit more, but have much better track records.
Sep 06, 2011 | Gateway FPD2275W LCD Monitor
I have model LCM-19v1 SL monitor and I need to know what type of power cord I need for it. and possible a picture
hi,
these are the specs for you monitor
Upgrade your desktop display in size and style with this Westinghouse LCM-19v1 19-inch LCD monitor! Its advanced HD-Grade flat panel technology lets you enjoy crisp, vibrant images while working on spreadsheets, writing email, watching movies, playing games and surfing the web.
Some key features include 1280 x 1024 native resolution, 600:1 contrast ratio, and a fast 21 ms response time. Its thin, sleek and sophisticated design will complement any office. Get yours today!
By law, California shipments of this product are subject to an $8.00
Electronic Waste Recycling Fee
Features/Specifications:
  • Westinghouse LCM-19v1 19-Inch TFT LCD Flat Panel Monitor
  • General Features:
  • Silver Cabinet color
  • 19" diagonal screen size
  • Native/Optimum Resolution: 1280 x 1024 16.7 million colors
  • Compatible Modes: VGA, SVGA, XGA, SXGA
  • Contrast Ratio: 600:1
  • Brightness (Nits): 300 cd/m2
  • Response Time: 21 ms
  • Viewing Angle: 170 degree Horizontal, 170 degree Vertical
  • Built-in stereo speakers
  • Connectors: 3.5 mm stereo mini-jack. VGA-in, DC-in
  • DC Input: 19V - 3.1A
  • EnergyStar compliant
  • Regulatory Approvals:
  • FCC
  • UL
Package Includes:
  • Westinghouse LCM-19v1 19-inch TFT LCD Flat Panel Monitor
  • Power Supply (100-24V 50~60Hz)
  • Power Cord
  • Stand
  • VGA cable
  • Audio cable
  • User's Manual
Additional Information:
  • Requirements:
  • Available power outlet
  • VGA adapter
  • Notes:
  • LCD displays may have cosmetic imperfections that appear as small bright or dark spots. This is common to all LCD displays used in products by all vendor and is not specific to any vendor or brand. Below are the acceptable amounts of "dot defects" for LCD displays that we sell:
  • 17-Inch to 18-Inch:
  • Total Defects: 8
  • Bright or Dark Dots (random): 4
  • Bright or Dark Dots (2 adjacent): 2
  • Bright or Dark Dots (3 adjacent): 0
  • Minimum distance between defects: 15 mm (bright to bright dots); 5 mm (dark to dark dots
for the adapter, already inserted the picture of it
Hope this will help... Your response is very much appreciated....
Jan 20, 2011 | Computers & Internet
When i turn on my westinghouse 17" LCD monitor it will have a sharp white bar appear through the screen in various sections then blotch out to completely white, after i let it warm up for about 20 minutes...
Hi
Well that's the age old question. Is it worth repair? The problem is probably 6 capacitors in the power supply that have aged significantly. In my shop those caps would run approx $2.00 each with a total labor charge of $50.00. Now whats the charge where you live? Then you can decide if it's worth a $62.00 repair or a new monitor for $150.00. Good luck
Mar 13, 2010 | Westinghouse Electric LCM-17v2 17"...
Monitor Brightness
most user manuals for these moniters you can get on line (free downloads)
it will explain how to use the buttons on your monitor
Feb 02, 2010 | Westinghouse LCM-19v1 Monitor
I have a Westinghouse LCM-19v5 monitor. When I start the computer, after the startup screens, the monitor goes black and I get a red bar with the message "Out of Range." I am in safe mode right now, the...
in the safe mode you have to change the resoulution and the frequency to 60 hz you can get it by fright click on the screen and then choose properties and then choose settings and adjust the resolution to 1280 to 800 and then choose advanced then choose monitor then choose the frecuancy to 60 hz ok and apply ok and insa every thing will be ok conntact me for more if you still haveing the same problem
Nov 14, 2009 | Westinghouse LCM-19v5 Monitor
Westinghouse LCM-19w4 has power, but blank screen
refer to an earlier post about similar problems. Does it power up and then shut itself off. this is possibly due to two defective capacitors. 27 cents on line $1.50 at radio shack. They will be puffy on top. I am a complete novice to soldering a capacitor onto a board. but since I was junking the monitor otherwise I gave it a try. It's still working after sitting idle a year. Handy advice on soldering online. use copper wire to **** up the old solder and try not to fry the capacitors or the board. If I did it anyone can.
Mar 22, 2009 | Westinghouse Computers & Internet
Happy turkey day, I have a westinghouse lcm-19w4,when I turn it on the screen flashes gray horizontal lines in the middle of the screen for a second then goes black. this happens a couple times then the...
You either have a hardware problem with your video card. ( may have pop out of socket when you plug in the monitor) or the cable is not allow communication to the monitor. As long as the amber light comes on you know you have power so focud on data cables and hardware.
Nov 27, 2008 | Computers & Internet
Westinghouse LCM-19W4
I had the same problem with my two LCM-19W4 monitors. Both failed within two months of each other. Radio Shack stocks 220uF 35V capacitors that work fine for this. You have to pay $1.49 ea though.
Nov 02, 2008 | Westinghouse LCM-19v1 Monitor
Westinghouse monitor model lcm 19w4. Screen keeps going black and you have to turn it off then back on to get screen back. Sometimes screen will work properly for hours, but sometimes keeps happening...
This looks like a power supply problem, due to internal
over heating. When it cools down, the power supply turns
back on, or an "over current/ thermal" protection circuit
trips. Shutting of the monitor off resets it, and then it trips
again.
I had an old Samsung 19" with an identical problem.
(see my other post)
Mine was caused by a leaky capacitor, but every
monitor is different. (I have considerable knowledge of
electronics, as well as a degree in engineering, so
I was able to fix it, but I would not recommend this to
a non-tech person.)
The 19w4 seems to be a fairly new wide format monitor,
probably still under warranty. I would take it back to the
store on a busy Saturday afternoon and scream blue
murder.
There is absolutely nothing you could have done to cause
this problem, nor is it normal wear and tare.
It is the result of sub-standard manufacture, and you have
every reason to take it back. Your case is stronger if
you don't try to open it.
Good luck, Martin.
please rate my answers.
Jun 14, 2008 | Computers & Internet
My Westinghouse LCM-19w4 Monitor will not turn on,..it just blinks and nothing
I just repaired my LCM 19W4. My symptoms were a little different; the light was not on or blinking like yours. I replaced two bad capacitors today (220 uF 25V High Temp) So far so good. Bad caps can be easy to identify; they are slightly bulging at the top. Soldering can be very tricky though. But just like plodder said, make sure it's the monitor that's bad and not something else by hooking up a known working monitor first.
May 18, 2008 | Computers & Internet
Westinghouse LCM-19v1 Monitor Logo
443 people viewed this question
Top Westinghouse Computers & Internet Experts
Jim Goldsmith
Jim Goldsmith
Alun Cox
Are you a Westinghouse Computer and Internet Expert? Answer questions, earn points and help others
