Question about LG WM-2277HW Front Load Washer
LG wm1814cw washer is leaking from the front
There is a good amount of water coming from underneath the front panel (not the door). I ran a test cycle on rinse and spin and it didn't do it. Then when I put laundry in and ran a full normal cycle I had almost a full drip pan. Any ideas?
  • lilkimmiesco Jan 14, 2009
    what am I looking for when I pull at the bellow? if I do need to replace it is there a manual available to help walk me through it?
  • mthomtech Jan 24, 2009
    I have a very similar problem, just not quite as bad. I have the LG WM2688HNM model and I just noticed that I'm getting a slight drip from the underside of the bottom front edge of the machine ... typically near the corners. There's a white plastic piece along under he edge where it looks like the drip is coming from.
    I watched a cycle and it seems to happen during the rinse cycle. I didn't notice it during the first 5 or so loads, but once I started usigng the pedestal drawer, I noticed it. The water dips into the pedestal. I only get about a tablespoon of water leak out during the cycle, but I'm wondering if it is accumulating inside the machine in places where it shouldn't
    New Friend:
  • 88 Answers
Did you check the door bellow. I know you said it's not the door but if you really open that rubber pull it back and check it from top to bottom. let me know I'll keep thinking.
Posted on Jan 14, 2009
  • Dean Rhymer
    Dean Rhymer Jan 14, 2009
    you are just looking for a little rip or tear in it. sorry there is no manual that I know of.
Spin cycle appears to be broken. washer just hums
Humming can indicate a stalled motor...If a coin is jammed in the pump impeller it will often do what you describe...Check via pump filter access door...Good luck....Nomess
May 08, 2010 | LG WM1814CW Front Load Washer
The washer seems to leak a small amount of water, less than a cup after each wash. It looks like it is coming from the back underneath. Checked the filter and such.
You may have an oversudsing condition which will cause it to leak like this. It can cause permanent damage over time.
Try to use one eyedropper full of HE detergent, either the liquid stuff or powdered dissolved in hot water. Use vinegar for fabric softener it will rinse the load clean. Run it on a hot cycle first with a cup of vinegar to flush the detergent residue from the drum, no laundry, and see if the water runs clear and/or if it leaks, if the problem occurs you may be facing a gasket breach. More often than not it's due to oversudsing. They tell you NOT to use regular detergent and that is why.
Apr 21, 2010 | LG WM1814CW Front Load Washer
LG WM1814CW Front Load Washer rubber seal on front door collects water underneath and now has black mold, and a strong odor, like cigarette smoke.
Use some detergent plus baking soda and mix it in with the water--rub it around (with an old toothbrush) to loosen the mold. Let sit for a while, then wipe water, mold, and cleaner away. Finally, rinse with clean water and wipe dry. Leave the door ajar to air out after each wash. It will help to remove the standing water each time. Don't poke a hole in the seal to drain the water out, because water will then run out of the bottom of the washer.
Sep 28, 2009 | LG WM1814CW Front Load Washer
Door locked and will not open. i ran an empty cycle to see if that would work and it doesn't.....thanks! Margit
IF water is left in machine then door wont unlock, check pump, run drain cycle. If pump runs but doesnt remove water, then check filter at bottom (small door on bottom front) water will come out when this is done. If washer is completely empty of water and door locked then you may access lock release tab from bottom or reaching down from top to lock asm. Then check lock
Jul 19, 2009 | LG WM1814CW Front Load Washer
Have a LG Tromm wm2688hnm and is leaking water? Does anyone know what causes this and how do you fix it?
If leaking from the bottom it could be a number of things and you would have to remove the back panel to start. Then do the rinse and spin and using a flashlight try to locate the leak. Have towels handy. For us, in our 5 yr old LG - the bellow (the black large tube connected to underneath the tub) had holes in it. A $10.00 part online.
Jul 04, 2009 | LG WM1814CW Front Load Washer
Water leaking from my front load LG washer
My LG WM2277HB also leaks after 4yrs of use. I found a hole in the front door gasket at the 3 o'clock position. I also have LE errors constantly.
Mar 09, 2009 | LG WM-2277HW Front Load Washer
My LG front loading wm1814cw washer is leaking from the front panel (not from the door but underneath the front panel). I have to say about half of the water from the load is in the drip pan at the end of...
On the bottom left side there is a cover cap open it up an there is a drain pump filter and a drain plug. plug may be lose. But clean the drain pump filter.an tighen the plug. if that dont work call 1-800-243-0000
Jan 13, 2009 | LG WM-2277HW Front Load Washer
LG WM1814CW Front load washer PF continues to come on and stops cycle
Seen This before Main control board fixed it It would go through most of the wash cycle and just quit no errors but PF
Jan 29, 2008 | LG WM1814CW Front Load Washer
LG WM-2277HW Front Load Washer Logo
191 people viewed this question
Top LG Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
