Question about LG WM-2277HW Front Load Washer
My LG front loading wm1814cw washer is leaking from the front panel (not from the door but underneath the front panel). I have to say about half of the water from the load is in the drip pan at the end of the cycle. When I tested it on a rinse & spin cycle it didn't do it but when I ran a full cycle it did it again. Any ideas?
  • 66 Answers
On the bottom left side there is a cover cap open it up an there is a drain pump filter and a drain plug. plug may be lose. But clean the drain pump filter.an tighen the plug. if that dont work call 1-800-243-0000
Posted on Jan 15, 2009
I have a tromm wm1814cw washer .i am trying to replace gasket.not having any luck.can you inform me as to the secret. thank you
There are 2 special tools you will need to change the door gasket. Call LG and order the door spring removal tool. There are 2 of them.
Jun 15, 2011 | LG WM1814CW Front Load Washer
I have a LG front load washer seem to leaking front area. Hoses OK Need o see what causes it to leak
you will need to narrow down where the water is leaking from. under the door...? behind the bottom drain door..? underneath machine..? behind machine..? leaks can be found in many areas.
May 16, 2011 | LG WM-2277HW Front Load Washer
Front door leaks at the bottom
Make sure that the door is clean and free of any build-up of soap and fluff. The door seal forms part of the outer drum seal and this will need replacement if the above suggestion does not solve the problem.
Jan 17, 2011 | LG WM1814CW Front Load Washer
LG washer Model # WM1814CW problem code UE
UE=Imbalance error
load too small
appliance tilted
laundry clumped to one side
non distributable object in tub
May 20, 2010 | LG Washing Machines
Spin cycle appears to be broken. washer just hums
Humming can indicate a stalled motor...If a coin is jammed in the pump impeller it will often do what you describe...Check via pump filter access door...Good luck....Nomess
May 08, 2010 | LG WM1814CW Front Load Washer
LG WM1814CW Front Load Washer rubber seal on front door collects water underneath and now has black mold, and a strong odor, like cigarette smoke.
Use some detergent plus baking soda and mix it in with the water--rub it around (with an old toothbrush) to loosen the mold. Let sit for a while, then wipe water, mold, and cleaner away. Finally, rinse with clean water and wipe dry. Leave the door ajar to air out after each wash. It will help to remove the standing water each time. Don't poke a hole in the seal to drain the water out, because water will then run out of the bottom of the washer.
Sep 28, 2009 | LG WM1814CW Front Load Washer
Have a LG Tromm wm2688hnm and is leaking water? Does anyone know what causes this and how do you fix it?
If leaking from the bottom it could be a number of things and you would have to remove the back panel to start. Then do the rinse and spin and using a flashlight try to locate the leak. Have towels handy. For us, in our 5 yr old LG - the bellow (the black large tube connected to underneath the tub) had holes in it. A $10.00 part online.
Jul 04, 2009 | LG WM1814CW Front Load Washer
Water leak from the top rear inside
You do need to; probably one of the pipes has come loose, can be re-fitted or replaced if broken.. Simple fix.
Mar 16, 2009 | LG WM1814CW Front Load Washer
LG wm1814cw washer is leaking from the front
Did you check the door bellow. I know you said it's not the door but if you really open that rubber pull it back and check it from top to bottom. let me know I'll keep thinking.
Jan 13, 2009 | LG WM-2277HW Front Load Washer
LG WM-2277HW Front Load Washer Logo
239 people viewed this question
Top LG Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
