Question about Whirlpool MH7140XF Microwave Oven
WON'T LIGHT UP
Upon opening the door to my microwave, I heard a click and the instrument panel went completely out. I checked to see if the fuse had kicked off but it hadn't so I don't know what the problem is. However, nothing works on it....fan, lights, keypad
  • kdurham04 Jan 14, 2009
    i checked to see if the fuse had kicked off but it hadn't......
  • Anonymous Mar 03, 2009
    I opened the door to my microwave and everything went blank. We tried resetting the breakers, but they weren't off. A time or two, it came back on and then went out again when we opened the door. Seems like it may be a short, but we aren't experienced in this type problem.
Did you check the fuse box?
Posted on Jan 13, 2009
Samsung Over-The-Range Microwave Oven just went out, wont come on at all.
Hello Terrell,
If "wont come on at all" means no light when door is open, no clock, nothing, then assume complete loss of power to that circuit.
These are often powered by an isolated circuit with its own breaker. The first place to look is your power distribution panel and see if you can find a tripped breaker.
If yes, then reset the breaker and see if the microwave has lights, clock, etc.
If no breakers are tripped, the actual microwave plug is often in a cabinet above the microwave. Sometimes, these may get pulled out while moving items in and out of the cabinet, so check that too.
If unsuccessful, microwaves also include an internal line and/or thermal fuse which fail due to overloading. Also, the control panel can go bad or become unplugged from slamming the door, etc.
If you do have lights, clock etc., then a faulty door latch will prevent operation of the microwave generator.
Unfortunately, will need additional information to properly identify the potential.
I hope this helps.
Jan 10, 2018 | Samsung Microwave Ovens
Suddenly microwave stopped working
(would really like more info- digital number dead as well?)
(assuming completely dead) Could be a couple of things:
- blown fuses (inside, relatively easy to replace, std size avail at Raioshack) <-- most likely
- cut/loose power cord connection inside.
- (unlikely but worse case scenario) Door was closed crooked- one tong hit one door switch before the other- causing a short circuit internally that "self destructs" the microwave to prevent it ever operating with an open (or even crookedly ajar) door, irradiating any users. Typically it just blows the fuses, but if fuses blow immediately upon replacing and turning power on, then possibly one of the switches fused or melted internally, and needs to be replaced.
Jan 28, 2014 | Whirlpool MT4155SP Microwave Oven
No Light and the turntable is not working
Open your microwave completely unscrewed but make sure it is disconnected from the power; check all the other fuses inside, if it doesn't fix the issue then take it to a pro to get this fix.
Jan 03, 2014 | Emerson MW8102SS 1100 Watts Microwave Oven
My magtag over-the-range microwave (Mmv4205baq) is completely dead. It's not very old, can it be repaired?
It's probably the internal fuse.You will have to take the microwave down so you can remove the housing to get at the fuse.(I will probably install an accessable panel mounted fuse holder if this ever happens to mine-already did it on the little microwave I carry around on my work truck to heat up my lunch).
Dec 17, 2012 | Maytag MMV4205 Microwave Oven
I have a Haier microwave and tonight after heating some food, I went to close the door and upon closing it, the carousel started turning and it won't shut off.
It sounds like one of the door switches has become defective, each must be disconnected on the one side and tested with a digital meter using the ohms scale.
Jun 07, 2012 | Haier Microwave Ovens
We heard a "buzzing" sound and it stopped when I
I had a similar problem. Everyone said must be the magnatron or the fuse ....turned out to be a burned out (visually melted) thermal cut out switch ($12) on the top side of the microwave. Had to get down inside the top of the microwave. The cut out switch was tucked away right up against the the microwave box. Hard to diagnose your problem without looking at the unit in question though, could be several different things. However, my philosophy when it comes to repairs...start with the cheap stuff first!
Jan 10, 2011 | Frigidaire FMV145K Microwave Oven
Panasonic Microwave oven - cooking operation stops afer 2 seconds
Sounds like a short in the microwave circuit. One or more of the following four components has failed -
Transformer
Magnetron
Diode
Capacitor
Repair is not for the amateur, unless you know how to take things apart, and put them back together EXACTLY as the were found.
Parts are available on the Net, and you can get the P/N's off the old components to identify suppliers of the new ones.
Don't try and measure resistance of the diode. It's impedance is far too high to get a good reading. They're cheap anyway. Always replace the capacitor, they're cheap too. No way to test the magnetron, and the transformer is not easy to test either.
Jan 16, 2009 | Panasonic NN-S952 Microwave Oven
Microwave stopped heating after being cleaned (could be co-incidence). Besides not heating appeared to run properly. Let sit for a day hoping something was wet and would dry, tried heating glass of water...
If it went dead almost immediately after pressing the Start pad, that's usually a shorted high-voltage capacitor.
If it went dead a few seconds after pressing the Start pad, that's usually a failing high-voltage transformer.
If it goes dead or blows the breaker when you plug it in or open or close the door, then there's a problem with a door switch or door switch mount.
But you might replace the fuse and do another quick heating test to see if it blows again. If so, you'll need to do some checks.
Here are some links you or someone you know can use for test help, but read their safety warnings first:
http://www.gallawa.com/microtech/cap_test.html
http://www.gallawa.com/microtech/diode.html
http://www.gallawa.com/microtech/xformer.html
We're happy to help and we appreciate your thoughtful rating of our answer.
William E. Miller, AS-EET
prototech@usa.net
http://www.microwavedisplay.com
May 12, 2008 | Microwave Ovens
Microwave Power Blew Out - Kenmore Elite Model 721.63763300
This is usually caused by either a bad door switch, a loose door switch mount, or a problem on the control panel.
Even though a door switch clicks, it may still be bad inside. Its continuity must be checked.
Switch or mount trouble can be caused by slamming the door or by opening the door while it's cooking without hitting the Stop pad first.
If you someone you know decide to look into it, we have critical information on safety, disassembly and door switches at our site, and our link is at our listing here on FixYa: http://tinyurl.com/yzjozk
There should also be a very helpful "mini-manual" hidden inside the unit behind the control panel. It's very helpful when troubleshooting.
You can find helpful exploded view diagrams and order parts by entering your full model number here: http://tinyurl.com/gv383
Mar 09, 2008 | Microwave Ovens
GE Spacemaker microwave XL1400
This is usually caused by either a bad door switch or a loose door switch mount.
If you or a friend decide to look into it, we have critical information on safety, disassembly and door switches at our site, and our link is at our listing here on FixYa: http://tinyurl.com/yzjozk
Feb 20, 2008 | GE JVM1440 Microwave Oven
Whirlpool MH7140XF Microwave Oven Logo
57 people viewed this question
Top Whirlpool Microwave Ovens Experts
William Miller
William Miller
Chuck
Are you a Whirlpool Microwave Oven Expert? Answer questions, earn points and help others
