Question about Mitsubishi WS-65807 65" Rear Projection Television
Add hdmi port to mitsubishi ws-65807
Can I add an hdmi port to a ws-65807 rear screen projection tv?
    Top Expert:
  • Mitsubishi Master
  • 14,553 Answers
I doubt it as it was never designed for that kind of input, Component works best on this set and it should have only one HD input for a box marked in the menu as DTV.
Posted on Dec 13, 2012
SOURCE:
SOURCE: Mitsubishi WS-65611
My mitsubishi 65611 is about 4 years old - I am getting a green overlay color on the screen can you advise what this might be?
Posted on Jun 08, 2008
ctf1800
  • 4402 Answers
SOURCE: mitsubishi rear projection tv won't turn on
know problem of bad caps.
http://www.chrisandnat.com/Projects/BlinkingTV/blink.htm
http://www.jeremyburns.com/Mitsubishi-Green-Blinking-Light-Fix.pdf
http://www.fixya.com/howto/h159332-mitsubishi_dm_board_repair
http://hdtvoice.com/voice/showthread.php?t=32186
replace DM
Picture of bad caps
http://www.auctioncreations.com/wd62525a.JPG
The DM board is the one with the digital connectors on the back panel. If you already have it appart, you may as well check the caps on all of the boards. The caps that go bad are typically Jamicon brand caps in 1000 uF and 330 uF values. There are also a couple of 3300 uF caps in the PS that cause problems.
Posted on Jan 08, 2008
sabreusa
  • 271 Answers
SOURCE: cant find part #stk-392-570 for mitsubishi
The correct part number is STK392-570.
You can buy them online, they're all over the NET..
You need to know what you are doing before touching this part. This part is located in a dangerous area of the TV. Warning High Voltage can Kill.
Good luck
N Sabre
Posted on Nov 08, 2009
ladywinn
  • 5138 Answers
SOURCE: I have a WS-65807 Mitsubishi Big Screen HD TV and
No, you need to replace your convergence ICs STK392-570 Call Mats Electronics 1-800-628-1118
Posted on Dec 31, 2009
SOURCE: ws-65807 65" mitsubishi rear projection tv
Mitsubishi rear projection tv 48 in now has no color all of a sudden- what can be fixed?
Need to dis assemble a ws-65807 tv to move
go here and sign up for a 7 day use ($5) and download the service manual (and schematics and pcb layouts) for your tv
http://www.free-service-manuals.com/members/
Jan 19, 2011 | Mitsubishi WS-65807 65" Rear Projection...
Can you easily seperate the top and bottom of the ws 65807 for moving?
Yes. I have the ws-65809, which is virtually the same model. There are 4 rubber plugs that come out on the sides of the TV. under these are four screws. WARNING! You must disconnect the wires connected to the screen before removing the screen or removing the top half of the TV. If you don't the wires will rip out. I believe they disconnect with 2 clips.
May 14, 2010 | Mitsubishi WS-65807 65" Rear Projection...
MITSUBISHI WS-65807. TV WON'T POWER ON AND PICTURE WAS NOT ALIGNED PROPERLY.
Good Day;
Your TV has "poor" connections on the Convergence IC's. Please get repaired B4 you have total part failure and more costly repair.
Good Luck, big IRISH.
Sep 28, 2008 | Mitsubishi WD-52725 52". Rear Projection...
Mitsubishi Model VS60607 Big Screen TV
There is a store called Big Screen TV Replacement Parts on EBAY that sells screens.
May 27, 2008 | Mitsubishi WS-65807 65" Rear Projection...
Mitsubishi ws-65807 no sound or picture
Check for coolant spill in corner of signal PC board = from leaky
CRT seal = bad CRT...........................T.
Apr 24, 2008 | Mitsubishi WS-65807 65" Rear Projection...
Mitsubishi WS-65807 and blue-ray compatibility
that tv set is only good enough to receive a 1080i signal at the DTV INPUT. unless you can change the output of the blue ray it will be outputting 1080p
Mar 01, 2008 | Mitsubishi WS-65807 65" Rear Projection...
Ws-65807 65" mitsubishi rear projection tv
For this unit and the addition of the secuity features of Blu-Ray, the 1080i you set can handle is through the component input from a DVD player or an XBOX. In the configuration menu of the PS3, change the resolution to 1080i and see if your set will reset to it. The 1080i on the Blu-Ray is only possible on the HDMI cable as far as I could find, again due to the security restriction. The Mitsu is not going to run it in 720p due to the PS3 is running component and cannot control sync to this set.
Aug 01, 2007 | Mitsubishi WS-65807 65" Rear Projection...
Open Questions:
See all Mitsubishi WS-65807 65" Rear Projection Television Questions
Mitsubishi WS-65807 65" Rear Projection Television Logo
184 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
