Question about Empire GWT-25 Wall Mounted Panel Heater
Pilot light does not reach thermocouple
We have a brand new Empire MV145 heater, the pilot light does not reach the thermocouple and does not stay lit when control knob is released. The service man has bled the line and checked the fuel pressure. Adjusting the small brass screw per the troubleshooting instructions does not remedy the situation. Heating the thermocouple with a separate flame allowed the heater to fire up.
  • jeffncarol_3 Jan 15, 2009
    Thanks, for the advice. The local serviceman suspected the same thing, but it still did not work. He contacted Empire and they are sending a new pilot light - including the orifice I presume.
  • Anonymous Mar 15, 2014
    the pilot kept going off so we replaced the thermocoupler . even after replacing that part we could still get a pilot flame (even if it wouldnt stay lit) but now we cant even get a flame .... any ideasz?
  • Empire Master
  • 3,238 Answers
The pilot oriface is blocked it needs cleaning out ,
Posted on Jan 14, 2009
I have an empire dv-60-18pp that the pilot won't stay lit...why?
Thermocouple problem. make sure it is in the flame. make sure it is not covered with patina. if it still wont work replace thermocouple.
Jan 30, 2015 | Empire Heating & Cooling
Pilot won't light.
If you try but the pilot won't stay lit, you probably have a bad thermocouple. It is a small probe located in the pilot that has either two wires wrapped in a metal jacket going to the gas valve or one copper tube also going to the gas valve. To get to it, you will have to open up the burner chamber and drop it out. Take the thermocouple to a good hardware store or fireplace shop for a new one.
Mar 13, 2011 | Empire DV-215 Direct Vent Natural Gas...
PILOT FOR EMPIRE WALL HEATER WONT STAY LIT. I HAVE ALREADY REPLACED THE THERMOCOUPLE
are you sure the problem is with the thermocouple? is the pilot sharp and blue? it is unconnon for the magnet in a gas valve to go bad but it does happen. place the thermocouple in the valve and with it in front of you heat it with a match or lighter for 30 sec. now try and light the pilot quickly. if it lights the the problem would be the pilot, if not then the valve. is this a milivolt system or hydrolic t stat.
Jan 29, 2011 | Empire DVC-35 Wall Mounted Panel Heater
I have an Empire gas heater. It does not stay lit. It will go out after about 30 minutes to two hours. When we first started having this problem if you set it where it wasn't completely level it would stay...
Look at your thermocouple. Is it glowing red from being heated by the pilot flame? Is the pilot flame blue or yellow? You may have a dirty pilot orifice that is not heating your thermocouple enough to keep it lit after the burner cycles off. A yellow flame will eventually burn the tip of the thermocouple, which causes more frequent problems and eventually it will not work at all. If you have a can of compressed air with attached straw, use it to blow out the pilot orifice (with the gas off) where the pilot flame usually burns. Then examine the tip of the thermocouple and see if it is still round and smooth. Jagged or irregular tips mean it should be replaced. A blue pilot flame and a new thermocouple should do it. Hope that fixes it for you. Douglas
Jan 04, 2011 | Heating & Cooling
Pilot light will not stay lit on a empire gas heater model uh 1050 fsp natural gas
clean pilot light or replace thermocouple check thermocouple is tight at the nut end
Aug 08, 2010 | Heating & Cooling
My reddy 30 heater will not stay lit after starting, I have held the switch down for longer than 30 sec, but it just want stay lit
The thermocouple is what tells the gas valve to supply or not supply gas. Several things can cause the thermocouple to malfuntion.
1. pilot light jet is clogged and will not allow the pilot light to reach and heat the thermocouple. Repair by cleaning the pilot light jet out.
2. corrosion on the thermocouple which will also not allow the flame from the pilot to heat the thermocouple properly. Repair by sanding the thermocouple lightly with sandpaper
3. Thermocouple is bad and needs replacement.
Mar 25, 2010 | Heating & Cooling
Pilot light wont stay lit when button is released
If the thermocouple is being well covered by the pilot flame, then it sounds like the thermocouple or thermopile is bad (a thermocouple and thermopile both perform the same way, but are entirely different devices. I am unsure which yours has.
Also, make sure all connections from the t-couple of generator are snug tight to the gas valve. There may also be a temperature sensor that has tripped that prevents the pilot from remaining lit. Follow the thermocouple/thermopile tubing to locate any inline sensors that may be open, preventing the signal reaching the gas valve.
Let me know if I can help more. I have not been able to find any information on this specific unit, so will have to speak in general about what to look for.
Dec 16, 2009 | Empire ECS HearthRite HB20T Heater
Empire DV-210: Pilot light will light and stays lit, but when I
The thermocoupler is no good. It's that bulb sitting in the pilot flame. when it goes out it shuts everything doen in the main valve. It has to be kept hot by the pilot, that's how it know whether or not it is safe to open the main .
Oct 07, 2009 | Reddy Heater-10-12-15,000 Btu L.P.
You need to replace the pilot safety switch which is usually a Thermocouple. It is connected by a thin tube from the gas valve to a bulb near the pilot burner. It should be available at Home Depot or online.
Ray
Dec 17, 2008 | Empire ECS HB06M HearthRite Heater
Open Questions:
Heating & Cooling Logo
461 people viewed this question
Top Empire Heating & Cooling Experts
Paul Carew
vance jones
Dan Webster
Dan Webster
Are you an Empire Heating and Cooling Expert? Answer questions, earn points and help others
