Question about Philco 841205 Turntable
Streched CD drive belt
Where can I get a new CD player drive belt? I have a Philco Turntable, CD with Cassette. #841.205
  • 104 Answers
Turntableneedles.com has about 450 belt sizes in stock. your unit is too new to have this listing yet as the belt should not have failed already so when you call be ready with the length of the old belt. Don't worry that it is stretched, a new size will be calculated that is about 3-5% shorter.
Posted on Feb 11, 2009
My philco turntable CD with cassette player arms messed up
Need more information and a detailed description of what the problem is.
Dec 28, 2016 | Philco Audio Players & Recorders
On my Philco Turntable CD with cassette the CD player does not close all the way. If you manually close it, it does not play
You are describing too problems, won't close all the way, could be a bad loadind belt. the second issue it will not play, the timing gear is out of sync, or the laser pickup is not functioning, you will need to take it to a service shop for assessment.
Jun 02, 2012 | Philco (R) Classic Turntable CD Shelf...
Philco turntable belt
See this video. I might help you.
Apr 23, 2012 | Philco (R) Suitcase CD Shelf System
The turntable on my philco cd cassette and turntable unit does not turn. how to i access the belt, etc. to see whats wrong?
I had a similar issue with my Crosley turntable that I recently picked up... and after digging up the manual online all I had to do was lift up on the tone arm and move it to the right (past the holding mechanism) until it clicked, and voila, the turntable started spinning again.
I hope this helps!
Sep 18, 2010 | Philco (R) Classic Turntable CD Shelf...
How to turn on turntable on Philco Turntable CD Player
Just pull the arm back a little bit, the turntable should then start.
Apr 20, 2009 | Philco (R) Classic Turntable CD Shelf...
Philco turntable cd with cassette player all i get is the cassette playing nothing else works where can i get it fixed here in washington state
just find a local electronic repair shop near you
look in the phone book for electronic /electronic repar shop
i have had to repair these before and the selector chip has failed because of a resistor letting to much current and voltage go into the chip , repair cost $40-$50 depending on the dammage
Oct 29, 2008 | Philco (R) Classic Turntable CD Shelf...
Philco turntable CD with cassette
Most of these are blet driven and the belt is probably slipping. This is a relatively simple repair if you have the correct belt. I'm in Massachusetts, so I don't have any particular recommendations for you. The belt will cost around $10.
Dan
Mar 21, 2008 | Philco (R) Classic Turntable CD Shelf...
Philco suitcase turntable / cd belt drive
Place the rubber band around the turntable and put a paper clip, bent up behind the rubber band. Start the turntable on it's spindle and you will be able to view that drive spindle on the right side, slowly pull the rubber band with the paperclip and drop over the drive spindle. remove paperclip and push turntable down seating it and replace the lock snap.
Jan 27, 2008 | Philco (R) Suitcase CD Shelf System
Philco Turntable/CD with cassette
Sounds like a classic case of beltitis-most cd players incorporate a small belt attached to a motor and gear on the front of the unit,it either has went bad,bad meaning stretched out or it could be broke in two.Just because its new to you doesnt mean that it didnt sit in a hot warehouse for months before it was put on a retailers shelf.When rubber is subject to heat for long periods of time it breaks down the chemical which keeps elasticity.check that first,if the belt appears or seems to be in decent shape then clean the gear and belt with some isopropyl alcohol,environments like a restaurant which most likely have a lot of grease in the air can slowly built up on the parts inside causing things to slip,might as well spray some wd40 in there,if that isnt the case any of the above then you either have a bad motor ore bad motor ic,ok well good luck and have fun hope you get it going,i just found one in the dumpster that somebody was throwing away because the cd player does not work,good for me im a bench tech,the optic lens assembly is bad,for ten dollars i can replace it with a brand new one to keep this ****** rockin,bye
Jan 08, 2008 | Philco (R) Classic Turntable CD Shelf...
Philco 841205 Turntable Logo
575 people viewed this question
Top Philco Audio Players & Recorders Experts
 Grubhead
Grubhead
jason
Steven Wander
Steven Wander
Are you a Philco Audio Player and Recorder Expert? Answer questions, earn points and help others
