Question about RCA D52W20 52" Rear Projection HDTV-Ready Television
I have rca d52w20 rear projection hdtv moniter-does not come on
Power light comes on blinks 3 times then goes off.tv never comes on,this started awhile ago at first after third time of trying or after unplugging set for about 5 minutes it would stay on but now it won't come on at all,would it be better to just get a new tv?or is this set worth fixing?on back panel it has manufactured in 2004
  • fernie 3 Jan 16, 2009
    • the problem is that the green light blinks three times and theres nothing
I just changed the 3 capacitors cp150 2200 16v and cp114 35v and cp120 35v. the set seems to working good now. not to hard to do if you know how to solder. take the back off the tv and they are on the board that is on the bottom left.
Posted on Jan 16, 2009
Rca d52w20 tv power button blinks doese not come on.
If the light flashes 3 times then goes out thats usually caused by the CP150, CP120 and The CP114 capacitors. You can get the repair kit by that same name at www.tvrepairworld.com and the kit also has the CD with instructions.
Dec 18, 2009 | RCA HD52W56 52" Rear Projection HDTV
My 52 inch rca tv power button blinks on and off
my rca tv will not power on power button blinks four times
Aug 17, 2009 | RCA D52W20 52" Rear Projection HDTV-Ready...
RCA D52W20 gets power but won't turn on
Hi, thank you for visit fix ya.
Common problem on thi tv.
Capacitors on power supply bad.
Replace this:
2200uf 16V, 220uf 16V. Upgrade to 35V.
Located on power supply- deflection board.
(picture)a57b905.png Thank you
Jul 21, 2009 | RCA D52W20 52" Rear Projection HDTV-Ready...
RCA D52W20 52 in. Rear Projection HDTV power light blinking
Liz, yes it is a power supply problem, better question is; low voltage or high voltage power supply ? count the blink code, it should repeat the code, once you have the code call your local tv shops and give them the model number of your tv and the blink amount and they`ll tell you price to fix, gl, video-tek
Jun 05, 2009 | RCA D52W20 52" Rear Projection HDTV-Ready...
TV picture went out.
power supply problem check capacitors...caution
high voltages..large capacitors retain nasty charge for a long time.........
Feb 24, 2009 | RCA D52W20 52" Rear Projection HDTV-Ready...
Rca d52w20
it should if you can get one most have been on back order. the board with the ihvt on it is the one to replace
Feb 23, 2009 | RCA D52W20 52" Rear Projection HDTV-Ready...
My rca d52w20 projection tv wont turn on
It could be as simple a 3 capacitors in the power supply.Location CP120,CP140 and CP114.
Jan 13, 2009 | RCA D52W20 52" Rear Projection HDTV-Ready...
RCA rear projection TV power light blinks for a few seconds but
Look on Deflection board If cp150 capacitor is puffed up on top it is bad there is 3 caps to replace cp150(,2200uf 16v ) cp114,cp120.(220uf 35v). The SSB board can also shut set down.
Jan 04, 2009 | RCA D52W20 52" Rear Projection HDTV-Ready...
RCA 52 inch D52W20 hdtv ready television
Replace 3 capacitors cp150- 2200uf 16v ////cp114 and cp120---- 220uf 35v. buy caps at Radio Shack.
Dec 29, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
RCA D52W20 52 in. Rear projection hdtv problems
can you tell me if the light blinks when you press power? If so let me know and I can help you diagnose the problem.
Jun 29, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
RCA D52W20 52" Rear Projection HDTV-Ready Television Logo
112 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
